Old 09-27-2010, 10:24 AM   #301
blaine.hale OP
blaine.hale's Avatar
Oddometer: 3,267
Originally Posted by LasseNC
Have you adjusted the caliper? Or is that wear from before the teardown? Looks like it could grab alot more on the disc :)
Caliper doesn't have any fluid in it yet because it failed to work after rebuild when I put fluid in it...bug number 1 that I need to sort out.
Some other bugs (maybe you guys can throw in suggestions)
-The boyer ignition doesn't like to cut off when the key switch is turned off on some pre-79' models (mine) so the solution was to remove either the red wire to the positive lead on the battery or the red wire on the positive leave on the coil. Removing either of these renders the ignition unit dead...a catch 22. So I need to devise a kill switch or ask the Boyer guys a better solution (I do not want a kill switch.)
-Master cylinder is not getting fluid at all through it. It's not pumping down the line and not gravity bleeding. I need to just pull the unit entirely and work with it off the bike. Suggestions on what to look for would be lovely.
-Clutch lever sensor isn't working. I probably just have the wiring backwards or the sensor itself is dead.
That's literally all the bugs I've had from this...not bad, eh? I'm sure I'll find more after riding it a while and after break in.
Things that still need replacement:
-My shotty /7 seat
-The blown, crusty rear shocks (buying ohlins)
-The crusty starter (going with the motorad toyota one)
-Air house covers (they're from 2 different bikes and someone hand drilled them)
-A few rubber bits here and there to make it perfect.
This coming weekends work:
-Time the ignition to full advance
-Sync carbs
-Factory torque all bolts
-Clean out and fill the drive shaft with fluid
-Run it at 3500rpm for a while to break in the engine
-Ride it 136 miles back to Atlanta :)
This about wraps it up gentlemen! Been the most fun and rewarding thing I've done. I blew my budget big time and I'm not the least bit upset about it, this is my dream bike and I'd do anything to get it where I want it. I love this bike and building it only made me love it more! There will be a few ride reports, videos and pictures as I add the last few bits later in fall but for now...it's almost done!
Thank you all for the input and definitely speak up more about potential issues you see!
See ya'll at Barber Vintage Weekend! (I'll be on the r90)
1974 BMW R90 /6 | 1968 Bultaco Matador MK3 | 1973 BMW R75 /5 Toaster LWB | 1966 Ducati 250 Monza | 1976 Ducati 860 GT | 1977 Moto Guzzi LeMans 850
blaine.hale is online now   Reply With Quote
Old 09-27-2010, 10:31 AM   #302
LasseNC
XSessive!
LasseNC's Avatar
Oddometer: 1,076
Got some more info on that starter? I have a squeeling Bosch unit, might be going out soon.
Old 09-27-2010, 10:56 AM   #303
blaine.hale OP
Oddometer: 3,267
It isn't cheap. I'm still considering someone rebuilding mine, but having something that pulls less off the battery and weighs less is more appealing to me:
http://www.motoelekt.com/ignition.htm
So here were the pics before I rode it yesterday. The fairing and side panels aren't on. Also, the old /7 seat is on ... bleh
Yay crooked bracket! (I'll fix later)
Old 09-27-2010, 11:25 AM   #304
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
what's up with the wheel/front cover alignment in this picture? is something amiss there or am i dreaming?
also, i have the nippon denso starter and it's been great.
Originally Posted by blaine.hale
bmwblake is offline   Reply With Quote
Old 09-27-2010, 11:53 AM   #305
blaine.hale OP
Oddometer: 3,267
The steering isn't turned straight and the angle of the picture, more than likely.
Old 09-27-2010, 01:06 PM   #306
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,651
Straighten out that SS brake line, sonny!
/nitpick
crazydrummerdude is offline   Reply With Quote
Old 09-27-2010, 05:21 PM   #307
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,670
Very nice job
Hope to see it in Tellico at the fall rally.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is online now   Reply With Quote
Old 09-28-2010, 03:55 AM   #308
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,666
I particularly liked how once started, it nonchalantly tilted it's headlight to the camera in a little "hello boys" pose!
boxerboy81 is offline   Reply With Quote
Old 09-28-2010, 08:35 AM   #309
blaine.hale OP
Oddometer: 3,267
Hahahaha, finally, someone noticed it!!
Old 09-28-2010, 08:57 AM   #310
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,643
that's a nice lookin' bike, man. Heckuva good job
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 09-28-2010, 12:57 PM   #311
BrianCa
airheads and stuff.
Oddometer: 24
What are the handle bars that you are using?
BrianCa is offline   Reply With Quote
Old 09-28-2010, 01:07 PM   #312
blaine.hale OP
Oddometer: 3,267
Magura "europa" bars ordered from Bob's BMW.
I'm looking for something with about an inch more rise or less of a dip down. The stock S bars would be great.
Old 09-29-2010, 09:42 AM   #313
mykill
odd
mykill's Avatar
Oddometer: 1,168
I believe the red wire should go to the + on the coils. The + on the coils comes on when the ignition is on and turns off when the ignition is off. the - side is the "spark trigger"
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 09-29-2010, 09:44 AM   #314
blaine.hale OP
Oddometer: 3,267
That's how it is set up currently. There is also another red wire that goes to the positive lead on the batter and has an in-line fuse. If I pull the lead to the batter, I get no power even if the ignition is on. If I pull the other wire going to the coils, same thing. If I leave both on, I get continuous power, when the ignition is off even.
I need to fiddle with it more this weekend to try more possibilities.
Old 09-29-2010, 09:56 AM   #315
crazydrummerdude
Wacky Bongo Boy
Oddometer: 7,651
Ya know, something about (our) '74 alloy signals..
When I see a nice BMW like yours, I start mentally drooling, then I remember I've got one (er, a few), too!
Although a little dirtier.
Times are GMT -7.   It's 04:55 PM.
