Old 01-31-2011, 06:28 PM   #376
elite-less
As above, so below
elite-less's Avatar
Oddometer: 548
I miss dry pavement.....
elite-less is offline   Reply With Quote
Old 01-31-2011, 06:28 PM   #377
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,131
Looks mighty fine.
Old 02-01-2011, 12:25 PM   #378
orphan-eddie
orphan-eddie's Avatar
Oddometer: 40
the bike looks so nice! its what I want to do to my R90.. .now I have a lot of infor I need to get mine in shape! glad you started this thread! thumbs up for sure!
"If I had more money, I would buy more rad s#@t!"
orphan-eddie is offline   Reply With Quote
Old 02-01-2011, 01:06 PM   #379
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,526
Nice job, Blaine!
Old 02-08-2011, 07:21 PM   #380
DJones
DJones's Avatar
Oddometer: 171
Blaine,
What did you figure out on your front suspension. I am doing mine, got progressive springs from Hucky, and noticed they are shorter than the ones I took out. Origonal springs = 577 mm and replacements = 554 mm, almost an inch shorter.
My forks did not have any preload spacers on the top caps, but 1 inch shorter would make em dive.
DJones is offline   Reply With Quote
Old 02-08-2011, 07:33 PM   #381
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,131
Originally Posted by SDVET View Post
Blaine,
Did they come with any plastic tube preload spacers? Usually just experiment with the tubes starting long and gradually shortening them until you get the spring rate you're comfortable with.
If you'd like to pass those old stock springs along to someone who'd appreicate a smoother ride, let me know!
cheers,
Lornce
Old 02-08-2011, 07:33 PM   #382
blaine.hale OP
blaine.hale's Avatar
Oddometer: 3,171
Blaine,
This issue kind of just worked itself out, honestly. I don't have issue with sag or terrible dive anymore. I do suggest making or buying spacers though, I do have them installed with my progressive springs.
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 02-08-2011, 07:35 PM   #383
blaine.hale OP
Oddometer: 3,171
I should probably add this to my thread as well. Still having some carb balance issues and not getting the full power out of the engine. The ignition is set slightly retarded because the carbs just won't stop acting up and idle way too high. I'm reaaaally debating buying a set of mikunis and just being done with it.
1974 BMW R90 /6
Old 02-08-2011, 07:40 PM   #384
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,131
Stick with the Bings until they're right, Blaine. Nothing going on there that can't be resolved with a bit of thoughtful effort.
Start a thread. Lots of opinions available to you on this site.
Old 02-09-2011, 09:33 AM   #385
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,195
Resolve the issue with the Bings first! High idle is caused by air leaks - look for a loose intake spigot or tubes or damaged jet o-rings. Mostly what I've found are damaged o-rings.
After having gone through everything like you have it can be frustrating going through it again. But check those o-rings - they've tripped me up enough times that's where I go first when it runs rough.
Old 02-09-2011, 10:06 AM   #386
blaine.hale OP
Oddometer: 3,171
Thanks for the tips. I've actually replaced all the o-rings twice now just because I thought the same thing. There's an airleak somewhere because one carb acts like it's sliiiightly on choke. Checked and double checked all the boots and made sure they all we're clamped and sealed but just can't seem to pin point the issue. I've replaced about 90% of the internals too including jets, atomizer etc.
1974 BMW R90 /6
Old 02-09-2011, 11:29 AM   #387
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
have you checked the metal spigots where the carb boots attach to the heads? if those aren't tight you can get an air leak there.
bmwblake screwed with this post 02-09-2011 at 11:43 AM
bmwblake is offline   Reply With Quote
Old 02-09-2011, 05:54 PM   #388
hardwaregrrl
ignore list
Oddometer: 7,526
Try the WD40 leak finder trick. spray until you notice an idle change so you can at least find the leak. The WD40 will block it long enough for the idle to change.
Old 02-09-2011, 06:20 PM   #389
mfp4073
mfp4073's Avatar
Oddometer: 2,455
Starting fluid/ether works too and doesnt leave stuff as oily.
1974 BMW R90/6 Bettie #1, 04 Triumph Bonneville
Originally Posted by Martin Blank
loner, lonegunman, get it. That’s the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is offline   Reply With Quote
Old 02-10-2011, 06:02 AM   #390
blaine.hale OP
Oddometer: 3,171
Ooo. That's one thing I can try this weekend.
1974 BMW R90 /6
Times are GMT -7.   It's 05:33 AM.
