08-24-2011, 04:07 AM
#466 | |
über-n00b
Oddometer: 285
Larger than life and twice as ugly! My photos: stewie.smugmug.com |
08-24-2011, 04:47 AM
#467 |
Oddometer: 1,025
it is a crazy suggestion RT bars look very strange on a non faired bike.
I ran my bike like that for a couple of years after I took the fairing off. standard US wide bars are maybe OK but personally I would not want to go any wider. I actually find that Magura S bars are fine, behind a S fairing, especially if using a tank bag on a long trip.
Charles http://i46.photobucket.com/albums/f1...ps6e61ae2e.jpg R90s 1070 replica, R90/6 1971 Commando Fastback |
08-24-2011, 06:32 AM
#468 |
Oddometer: 2,315
Thanks guys! Ended up going with the standard US 5 inch rise bars. I'll put my euros back on after the trip.
I have the S fairing mounted with these now too, just not in the pics: ![]() Not bad for $35 on fleabay! The clutch cable was a bit too short but does actually work. I'm carrying a spare US length clutch cable with me on the trip incase that one decides to pop
1974 BMW R90 /6 1968 Bultaco Matador MK3 1973 BMW R75 /5 Toaster LWB 1969 Bultaco Bandido MK2 2013 Husqvarna Terra TR650 |
09-26-2011, 08:11 AM
#469 |
Oddometer: 2,315
Well, this may as well go down in the saga.
The thread on the end of the cam shaft that holds the points down sheered right off. This requires a cam replacement. Next, the bolt holding the rotor on the crank backed out at a 45 degree angle and seized. So I need to extract it some how and re-tap the threads. I let it sit for a month to mellow the pain and frustration and I'm ready to get to tearing it down this week. Come on by if you'd like to help and have a beer Atlanta folks! Guess I'm going to going at it every night this week from 6pm on. Maybe I'll have it down to the bottom end by the weekend and ready for Beater's most gracious spare bottom end donation!
09-26-2011, 10:47 AM
#470 | |
Shit for brains
Oddometer: 5,010
Aww Blaine. I hate to hear this. But it's also pretty cool that you've been given the parts to repair it!! I'd love to swing by one nite and offer up some moral support!!
09-26-2011, 11:39 AM
#471 | |
odd
Oddometer: 1,093
Never underestimate the laxative properties of motorcycling. |
09-26-2011, 11:49 AM
#472 | |
Oddometer: 2,315
Maybe I can find a bit more suited for drilling steel.
09-26-2011, 12:10 PM
#473 |
Oddometer: 2,315
Is it remotely possible to pull a cam without dropping the engine out the frame? I'm thinking maybe pull the jugs and just the front wheel then I can something in there to pull the cam out.
Also, what tools are used to pull a cam and/or crank?
09-26-2011, 12:11 PM
#474 |
Oddometer: 62
Snowbum cam tip fix
09-26-2011, 12:27 PM
#475 | |
Oddometer: 2,315
Also...drilling through that forged steel is ridiculously hard. I need a sharp bit, good oil and the right RPM. Lastly...I need to make some kind of jig to hold it right. No clue where to go with that one. *Edit: Looks like I can buy this sucker after work and maybe a decent metal bit http://www.homedepot.com/webapp/wcs/...ocStoreNum=159
1974 BMW R90 /6 1968 Bultaco Matador MK3 1973 BMW R75 /5 Toaster LWB 1969 Bultaco Bandido MK2 2013 Husqvarna Terra TR650 blaine.hale screwed with this post 09-26-2011 at 12:39 PM |
09-26-2011, 01:56 PM
#476 |
Oddometer: 931
Damn Blaine,
sorry to hear of your troubles. I hope you figure out an easier solution than pulling the cam. Some damn good wrenching skills you'll learn if you do though. With the single seat and the panniers you're bike is starting to look like a much cleaner and better lived sister (or at least cousin) of mine- I like it! ![]() Whatever you do, IMO don't get impatient and drill before you know you are at center- that harbour freight drill guide looks like it might be helpful. I wonder if you could somehow spin the crank and push the drill bit into it (with that clamp) and this way even if you have clamped a tiny bit off center the hole will remain at center (picture turning a wooden bowl on a lathe). Spark plugs out, crank it over with the starter, and push the drill bit in to the crank tip? I don't even know which way the crank spins though you might need a left handed bit.You wouldn't have to get the entire hole drilled this way, just a good start to locate it? Good luck, post pictures
09-26-2011, 04:27 PM
#477 |
More tacos than you
Oddometer: 5,197
Or you could just get a crank mounted ignition and forget the whole mess. As an added bonus you'd have a better ignition system too. You already have an enduralast so you could get one of these:
http://www.euromotoelectrics.com/EnD..._p/edl-ign.htm
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
09-26-2011, 04:40 PM
#478 |
lost in the '70s
Oddometer: 464
Blaine, I had a similar issue with my R90/6 many years ago, and I resolved it by drilling and tapping into the end of the cam and fitting a short threaded stud. I don't recall the cam material being extemely tough to drill into, although it may have had a surface hardening that took a bit of patience from memory. I had a friend help to line up the drill-bit by eye.
'76 R90S silver smoke '75 R90/6 hybrid "Don't worry, it's not loaded." last words of Chicago's Terry Kath before shooting himself in 1978 |
09-26-2011, 06:29 PM
#479 | |
Oddometer: 2,315
I bought a pretty neat drill guide...it may come in handy later with other stuff as I don't have a drill press! I also bought the correct bit and tap/die kit. If I could afford a crank mounted system I would buy one and be done with it! I love easy solutions sometimes haha. Unfortunately, buying my first home has my fund tied up the next few months. :( Even when I get this little bit resolved, I still have the crank bolt to deal with. Hopefully I have a spare one and the right tap to clean the thread when I manage to get it out. I'm drilling tomorrow. I'll keep ya'll posted.
09-26-2011, 07:01 PM
#480 |
odd
Oddometer: 1,093
I'd buy a Boyer over bits.
