Old 09-26-2011, 08:12 PM   #481
blaine.hale OP
blaine.hale's Avatar
Oddometer: 3,065
I have a boyer
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 09-26-2011, 08:15 PM   #482
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,476
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 09-26-2011, 08:16 PM   #483
TheReaper!
TheReaper!'s Avatar
Oddometer: 651
I've done several restorations mostly scooters , every time I finish one I swear I'll never do another .
Some how no matter what there is always one more thing ,and then another and another and
another etc etc . It takes a lot of patience which I often run out of , good job and try to stay patient .
TheReaper!
TheReaper! is offline   Reply With Quote
Old 09-27-2011, 07:39 AM   #484
blaine.hale OP
Oddometer: 3,065
Originally Posted by bgoodsoil View Post
I feel like I'm venturing into your realm of expertise Brad.
That's a good thing, I think?
1974 BMW R90 /6
Old 09-27-2011, 07:46 AM   #485
Beater
Dirty
Beater's Avatar
Oddometer: 3,194
Don't Buy From Brad!
Fred
'85 R80RT G/Sified <|> '91 R100GS Bumblebee (103K miles and climbing) <|> '73 R75/5 LWB
Airhead Zen: Ride - Repair - Ride - Maintain - Ride - Repeat
Beater is offline   Reply With Quote
Old 09-27-2011, 09:45 AM   #486
mykill
odd
mykill's Avatar
Oddometer: 1,160
I hear you aren't supposed to ride with Brad either.
What does one do with Brad?
But I digress.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 09-27-2011, 10:26 AM   #487
Beater
Dirty
Beater's Avatar
Oddometer: 3,194
Originally Posted by mykill View Post
I hear you aren't supposed to ride with Brad either. What does one do with Brad?
Just keep your eye on him ... from a safe distance of course.
Fred
Old 09-27-2011, 03:35 PM   #488
blaine.hale OP
Oddometer: 3,065
Ya'll should stop by tonight! I'm going to drill that cam and some how pull the bolt from the crank ;)
1974 BMW R90 /6
Old 09-27-2011, 04:13 PM   #489
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,462
...and some how pull the bolt from the crank ;)
I vote thread it IN a little bit. It should get all loose and wiggly when you thread it in a little. Straighten it out and carefully thread it OUT.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 09-27-2011, 06:30 PM   #490
blaine.hale OP
Oddometer: 3,065
Just finished the drilling and tapping of the cam. I don't think it came out PERFECT but we'll see when I crank it.
The crank bolt was stubborn. Turns out it wasn't boogering the threads, it was off the actual crank and was just bent so much that it was wedged against the rotor. Popped the rotor right off and cut the bolt head off and it slid right on out.
If I could find my spare rotor bolt, I could crank this girl tonight!
1974 BMW R90 /6
Old 09-27-2011, 06:46 PM   #491
Beater
Dirty
Beater's Avatar
Oddometer: 3,194
I have several Rotor Bolts on the shelf ...
Fred
Old 09-27-2011, 07:13 PM   #492
blaine.hale OP
Oddometer: 3,065
I've scoured my entire house. I'll be texting you!
1974 BMW R90 /6
Old 09-27-2011, 07:29 PM   #493
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,476
Crap! I wish I had seen this earlier.
You may get a Reckless Wreching charge for cam screwing According to MaxBMW that ticket'll cost you $257.77 plus bearings.
Old 09-28-2011, 10:02 PM   #494
blaine.hale OP
Oddometer: 3,065
The r90 is back up and running again.
It's running strong with the exception that it backfires pretty bad on deceleration.
Beater and I think it could be something to do with the newly drilled/tapped hole in the cam and the bolt be slightly off.
That sounds right, but the magnet plate for the boyer rotates off the cam so it shouldn't be going in an irregular shape though the bolt may be causing it to wobble ever so slightly?
The bolt head is slightly off when the engine is running and the cam is spinning...so I know it's not PERFECTLY centered.
Maybe it's just a bad ignition period and I should test out points to see if I get the same results?
1974 BMW R90 /6
Old 09-28-2011, 10:19 PM   #495
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,476
I could see that. Let's say the wobble on that points plate causes you to fire too late and you don't burn all the fuel. When your sparkplug's mounted all the way at one end of the cylinder that'd be easy, hence all that dual-plugging. Anyways, so that unburnt fuel goes into the exhaust pipe and blows up. Hey, loud pipes save lives right? :ymca It's your bike so you'd know better than anyone--does it pull as hard as before? If you're not burning all your fuel I'd think you'd notice. Your bike should be fully advanced by, what, 4,000 rpm? Maybe it has something to do with the timing going off during the advance?
Or say screw the timing and turn your idle mixture up. Maybe it's fuel-related despite the fact that you're having ignition issues. It doesn't take long to turn a screw and rule that out.
If this is a result of an off-center hole I think A-Dubb's got your answer--a crank mounted ignition. As it happens, we haven't had a good inmate review of the Enduralast ignition.
On the other hand, Backfire isn't such a bad nickname
bgoodsoil screwed with this post 09-28-2011 at 10:26 PM
Times are GMT -7.   It's 09:51 PM.
