Old 05-12-2012, 07:35 AM   #511
blaine.hale OP
blaine.hale's Avatar
Oddometer: 2,296
Originally Posted by Airhead Wrangler View Post
This can be sticking ignition advance weights. I've also had one of my butterfly plates come a little loose in the shaft and it moved a little off center so it wouldn't seal well when the throttle would close. A quick chop and release of the throttle would center it again return it to idle temporarily.
Boyer electronic ignition
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 05-12-2012, 08:58 PM   #512
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 7,361
Make sure the carbs are adjusted and synched when the engine is hot.
And yes, it's normal when it's jetted and tuned right to need choke on start up. And mine all need a blip of the throttle to get em going.
Try cleaning the pads and discs to eliminate the squeal. Especially clean out the holes in the disc.
Old 05-14-2012, 08:23 AM   #513
blaine.hale OP
Oddometer: 2,296
Holes!? Man that's a luxury.
I guess I should sync the carbs at running temps. I usually crank it, get a steady idle at 900-1000 (I like it in that range) then adjust them. That may be what's getting me in trouble.
1974 BMW R90 /6
Old 05-14-2012, 08:46 AM   #514
Airhead Wrangler
More tacos than you
Airhead Wrangler's Avatar
Oddometer: 5,125
If you're just syncing your cables (off idle), then it doesn't really matter what temps you're at. For setting idle speed and mixture it needs to be up to temp.
Also, "running temp" does not mean adjust them after letting it idle for 5 minutes. Running temp means go take it for a ride for at least 20 minutes or so. Don't just idle it.
R80ST Gets The HPN Treatment
Ducati Pantah 500SL Rebuild
Seattle to TDF on an airhead
WTB R100R Mystic sidestand and mount.
Old 05-14-2012, 09:31 AM   #515
blaine.hale OP
Oddometer: 2,296
Haha, I definitely know that one. It also helps to run it for a while then put some shop fans on those cylinders while your idle and adjusting the things.
Also, just to clarify..I don't need to like full throttle gun it when starting, it is pretty much a blip. If anything, what you're saying is reassuring that mine isn't the only one that needs choke and throttle to start up.
Any recommendations on what to clean the pads and disk with? Also, a mirror polished shiny disk should not be the case, right? My disk seems to be shinier than a mirror (the pads are new.)
1974 BMW R90 /6
Old 05-14-2012, 09:59 AM   #516
Airhead Wrangler
More tacos than you
Oddometer: 5,125
If you DON'T need choke to start then you're running way rich. Sounds like you're fine
As for your brakes, you just need to break the glaze on them. Rough up both the discs and the pads with some medium grit, 150 or so, sand paper and they should bed in better and stop squealing. Any "unsightly" scratching on the discs will get wiped away before too long.
Old 05-14-2012, 04:11 PM   #517
Wirespokes
Wirespokes's Avatar
Oddometer: 7,361
Crud and oils are swept into the holes, then when the disc heats up under braking, that stuff can seep back onto the disc. I've used a drill bit (held in the hand) same size as the holes to clean them out, or a circular wire brush.
Old 05-14-2012, 04:14 PM   #518
Airhead Wrangler
More tacos than you
Oddometer: 5,125
I think he actually has the solid undrilled rotors.
Old 05-14-2012, 04:20 PM   #519
Beater
Scope Creep's Victim
Beater's Avatar
Oddometer: 2,215
Yep ... a '74.
Fred
'85 R80RT G/Sified
'91 R100GS Bumblebee
Airhead Zen: Ride-Maintain-Repair-Ride On.
Beater is offline   Reply With Quote
Old 05-14-2012, 04:22 PM   #520
Wirespokes
Wirespokes's Avatar
Oddometer: 7,361
Somebody stole your holes?
Old 05-14-2012, 04:27 PM   #521
Beater
Beater's Avatar
Oddometer: 2,215
Who undrilled these?!
Fred
'85 R80RT G/Sified
Old 05-14-2012, 04:37 PM   #522
hardwaregrrl
Shit for brains
hardwaregrrl's Avatar
Oddometer: 4,883
Have you adjusted the cam to center the caliper to the disc???
Old 05-14-2012, 04:47 PM   #523
blaine.hale OP
Oddometer: 2,296
I did upon the rebuild but it's something can circle back and check again.
Yes, I have those lovely solid disks. Beater sold me a drilled one, I just need to blast it before it goes on my clean bike
1974 BMW R90 /6
Old 05-15-2012, 07:28 AM   #524
blaine.hale OP
Oddometer: 2,296
Haven't posted pics in a while. I don't have my camera equipment currently so here's some phone pics :)
1974 BMW R90 /6
Old 05-15-2012, 09:12 AM   #525
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 5,027
I have seen arguments that the solid rotors were just as good but I can't get over the way they look maybe. They just don't look as sure as a drilled disk. I think there is an advantage in the rain with drilled.
---Albert Einstein
disston is online now   Reply With Quote
Times are GMT -7.   It's 11:49 AM.
