Old 05-15-2012, 04:56 PM   #526
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,593
Originally Posted by Beater View Post
Who undrilled these?!
crazydrummerdude is offline   Reply With Quote
Old 05-16-2012, 09:33 AM   #527
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,079
Originally Posted by blaine.hale View Post
Yes, I have those lovely solid disks. Beater sold me a drilled one, I just need to blast it before it goes on my clean bike
I want to see pix of you undrilling the new one.
I like the solid discs because they don't score up like the drilled ones.
Old 08-20-2012, 03:24 PM   #528
blaine.hale OP
blaine.hale's Avatar
Oddometer: 3,065
Bout to take the r90 on this route for 2 weeks:
View Larger Map
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 08-20-2012, 10:53 PM   #529
scoester
Oddometer: 22
You are about to ride through some of the prettiest country anywhere... My back yard. If you are coming through Butte, which it looks like you will be close. I would be happy to buy you a cold beverage.
Have fun and have a great trip.
scoester is offline   Reply With Quote
Old 09-17-2012, 02:00 PM   #530
blaine.hale OP
Oddometer: 3,065
Thought you guys might like to see how the r90 is doing and where it has been.
It's been carbon fouling the left spark like mad...my best guess is weak spark over there. I'm putting the points back on now to further bisect the issue. My Hoske exhausts arrived, just need to go pick them up and install them.
Just got back from a 2 week trip through the rockies, check out all the pictures here:
HALEMOTO TUMBLR
*side note: I hate that front fender!
1974 BMW R90 /6
Old 09-21-2012, 08:34 AM   #531
blaine.hale OP
Oddometer: 3,065
I've got a line on r90s forks with calipers for mega cheap.
Stay tuned to see if that works out and if I'll finally have sufficient braking!!
1974 BMW R90 /6
Old 09-21-2012, 09:20 AM   #532
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,165
That would be the primo score. Those units are getting rare. You may also want the 17mm undertank MC but the addition of a handlebar MC would be a step up.
---Albert Einstein
Old 09-21-2012, 06:12 PM   #533
crazydrummerdude
Wacky Bongo Boy
Oddometer: 7,593
We're going to stay '74 R90 twins, then, because I have some dual-disc sliders/calipers in a box waiting to be a winter project.
Old 09-24-2012, 04:24 PM   #534
blaine.hale OP
Oddometer: 3,065
R90s fork legs are on their way along with 2 40mm ATE calipers l, all in great shape for $120 total.
Looks like I may need a 17mm MC kit, a splinter and another stainless line to make this all complete....oh yeah, and one more drilled disk.
1974 BMW R90 /6
Old 09-24-2012, 04:39 PM   #535
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,165
There's a splitter on Ebay right now, was yesterday, for a buy it now price. I was tempted to get it but I'm pretty broke.
---Albert Einstein
Old 09-24-2012, 11:34 PM   #536
chasbmw
Oddometer: 2,109
If you want brakes that work, either adapt your existing MC or best of all buy a 13mm twin throttle cable handlebar mounted MC. BMW were very conservative when designing the master/slave ratios, resulting in very wooden brakes, a 13mm is just about perfect for brakes that have feel and power.
Charles
Charles
1971 Commando Fastback
Old 09-25-2012, 07:41 AM   #537
blaine.hale OP
Oddometer: 3,065
I will never ever ever ever go to a handlebar mounted MC, I'm afraid.
I don't like hacking up stock parts to make something work and still not look elegant or stock. I also don't weigh more than 125lbs, which means the 1 r90 disc brake isn't THAT bad, especially with braided lines, 40mm pot and a fresh master cylinder rebuild. The stock r90s set up should be fantastic :)
1974 BMW R90 /6
Old 09-25-2012, 08:01 AM   #538
Kai Ju
Kai Ju's Avatar
Oddometer: 1,815
Now that you've said that I'll chime in. Like you I didn't want to destroy the clean lines of the under tank M/C so I converted mine to dual disc by plugging two lines into the stock 14mm M/C. I used a banjo bolt instead of a compression fitting. I had to machine, read file, to get a good seal surface for the copper gasket but I'm very happy with the results.
Lever is a bit soft but brakes come in early in the travel and feel quite strong and progressive.
Here is a pic of the master cylinder banjo bolt setup:
Kai Ju is offline   Reply With Quote
Old 09-25-2012, 08:28 AM   #539
ontic
Oddometer: 1,069
Fantastic is a relative term with airhead brakes...
err, let me try that again..
It is fantastic that I have twin Ate's on my R90 and it is also fantastic that you are about to have them. Dramatically improving brakes to 'sufficient' is fantastic.
Given you are rebuilding the system at the same time I think you should be pretty happy- and probably end up with better brakes than me.
On that note though, what rotors are you going to use? I love my rusty cast iron ones. They suit the charm of my 90.
Me- if/when my undertank dual output master cylinder needs work I am probably going to switch to the handlebar master cylinder. I dont' mind hacking stock parts at all, and I am not drawn to keeping stupid stock systems (like the cable to undertank MC) just for the sake of keeping it stock. The only thing that needs to be hacked is the right hand lever/perch thing, and really, given that it wears out where the throttle cam gear sits, it is kind of a (long) service item anyway (and is still currently available new).
No biggy for me, YMMV.
My friend Charlie (the guy who drew up that great 74 90/6 electrical diagram you liked)(now Brun on adv) has done a handlebar mounted magura master cylinder on the /5 controls. Similar to what has been posted here before by others but a bit more refined and much nicer execution IMO. Looks fantastic to me. Elegant and good enough to be stock, I hope he posts some photos soon.
Actual fantastic brakes? My hacked to buggery G/S with its full 'modern' (10 years ago is modern right?) KTM brembo master cylinder, braided line and (only two pot) caliper with a single 320mm rotor... now that feels fantastic. I don't need any more brakes than that thank you very much.
My twin disc R90 does stop perfectly well and sufficiently when asked to, I just feel there is something (a lot) lost between the cable and hydraulic system.
Anyway, you're bike is a beauty and I'm sure you're going to be really happy once you get them sorted.
1974 R90/6
1981 R80G/S
1994 XLR250R
ontic is offline   Reply With Quote
Old 09-25-2012, 09:10 AM   #540
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,165
I regretted the suggestion of the 17 mm MC right away but it got away from me. I am always thinking the single disc MC isn't right for the dual set up. And I've finally come to realize that I've been wrong.
It's true the stock BMW dual disk set up on the S and other Ate bikes with dual disks used a 17 mm MC. If you go smaller there will be firmer and better brakes. I'm afraid if I go too small there will be too much travel and this is the other side of the coin that can really cause problems. Some riders do use a 13 so the single disk 14 should be OK. I would still check carefully. If you have warped disks the lever travel will be more and too small will be a problem. Since you already have the 14 I'd try to use this. Then you'll know where you want to go from there.
I like Kai Ju's twin hose set up. Much neater and less space than a splitter.
---Albert Einstein
disston screwed with this post 09-25-2012 at 09:16 AM
Times are GMT -7.   It's 03:26 AM.
