Old 11-06-2012, 06:56 PM   #586
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,651
Doesn't sound like diaphragms to me - when those tear, the bike runs fine up to 4-5k RPM where it bogs down and won't go beyond 60mph.
crazydrummerdude is offline   Reply With Quote
Old 11-06-2012, 09:25 PM   #587
Kai Ju
Kai Ju's Avatar
Oddometer: 1,910
The only reason I mentioned diaphragms is because it sounds like the right cylinder isn't pulling at all, as if the slide wasn't lifting. Usually that's the diaphragm.
The check that blaine performed on the carbs seems to eliminate the slides/diaphragms as the culprits but doesn't explain why the right side's not pulling.
Kai Ju is offline   Reply With Quote
Old 11-06-2012, 11:39 PM   #588
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,219
I have had bad diaphragms that ran poorly much sooner that 4-5 K. Mine was practically running on one cylinder.
New diaphragms, huh? Where did you buy said "new" diaphragms?
The only way to know is take the slides out of the carbs and hold rubbers up to strong light. Stretch the rubber and look for pin holes.
---Albert Einstein
Old 11-07-2012, 05:49 AM   #589
blaine.hale OP
blaine.hale's Avatar
Oddometer: 3,267
I'll check those out tonight. The diaphragms are BMW stock parts, if I recall. They came in the little carb board BMW stamped round container.
One thing I forgot to mention is, unless i've done a proper highway or 20 mile run on the bike to get it properly warmed up, the right side plug will come out dry and black.
My left side is just perfect...I can't even force it to be outside of perfect without trying really really hard haha.
1974 BMW R90 /6 | 1968 Bultaco Matador MK3 | 1973 BMW R75 /5 Toaster LWB | 1966 Ducati 250 Monza | 1976 Ducati 860 GT | 1977 Moto Guzzi LeMans 850
blaine.hale is offline   Reply With Quote
Old 11-07-2012, 06:13 AM   #590
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,606
Did you try switching ignition wires left to right, right to left just to eliminate that?
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 11-07-2012, 06:17 AM   #591
blaine.hale OP
Oddometer: 3,267
Yup, that was in the diagnosis steps I took. Granted, I didn't run them on a full warm up crossed. It just immediately blacked out a new plug.
Old 11-07-2012, 09:11 AM   #592
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,279
It's always possible to swap carbs side to side, though it seems everything else has been eliminated and it's gotta be the carb. These bings are just too simple, and I keep coming back to plugged low speed circuit. I've never run nylon fishing line through the passages, but that sounds like a good next step. It has to be something previously unnoticed, so look closer. Look deeper!
Old 11-07-2012, 09:16 AM   #593
blaine.hale OP
Oddometer: 3,267
You know...something as simple as swapping the carb sides could bisect the issue right down to a binary "is it carbs, yes/no" answer. That at least would give me something to go on.
Didn't know you could actually do that or if it would have some bad effect.
Old 11-07-2012, 09:57 AM   #594
Airhead Wrangler
Adios Mexico
Oddometer: 6,606
If you're confident it's not ignition, I'd just go after the carb on the offending side with carb cleaner AND compressed air until it decides to work. Mine never worked quite right after a couple rebuilds until Solo Lobo lent me his berryman's dip can and I left them in there about double the recommended time and then blew them out with compressed air.
Old 11-07-2012, 10:46 PM   #595
Wirespokes
Wirespokes's Avatar
Oddometer: 8,279
I'm with AW on this. I've been wanting to get an ultrsonic for carb cleans - supposed to be THE best!
Old 11-08-2012, 05:16 AM   #596
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,611
Blaine, I have an ultrasonic cleaner. It's a little guy, so you have to flip the carbs. But I also have my bings newly rebuilt sitting on the shelf. It where the 50 pilots came from. you could also disassemble the carbs and go visit Nathan and throw them in his big ultra cleaner. Does a good job. Let me know, I'm going out there monday to do some sorting, I could take the bodies and chuck them in for you.
10 year old gas...
Uploaded from the Photobucket iPhone App
hardwaregrrl screwed with this post 11-08-2012 at 05:25 AM
Old 11-10-2012, 01:13 PM   #597
blaine.hale OP
Oddometer: 3,267
Words don't even need to accompany this image.
Old 11-10-2012, 01:36 PM   #598
crazydrummerdude
Wacky Bongo Boy
Oddometer: 7,651
Interesting. I'll have to re-read your symptoms. I had two bikes with torn diaphragms and the symptoms were as I described on this page.
Well, now you know!
Old 11-10-2012, 01:57 PM   #599
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 10,219
Progress !!!
---Albert Einstein
Old 11-10-2012, 02:32 PM   #600
blaine.hale OP
Oddometer: 3,267
Progress, but not a resolution.
Upon initial crank, did just fine and felt like I had two cylinders and really smooth and strong pull again.
After warm up on the interstate and slow down back down, it immediately went back to losing a cylinder and back firing (all left side still.) Even stranded me on the side of the interstate for a minute or two while I tried to get her started again.
I still suspect carb issues. I haven't gotten time to swap the carbs and see if the issue transfers, just had to time to swap the flimsy, thin diaphragm in there for a healthy one.
Also, the carb does not rotate when loosening the plastic elbow and just having the engine side tight. Those rubber boots on the engine side are new, too, but I'm going to pull and swap and inspect them.
Times are GMT -7.   It's 02:10 AM.
