Old 08-21-2013, 10:03 PM   #361
Goofy Footer
Oddometer: 564
LED Lighting
Please correct me if I'm wrong but I believe I must float the ground for DC conversion or get an aftermarket stator such as TrailTech to run a LED headlight such as the Baja Designs Squadron right?
Must I also float the ground to run an auxiliary LED light such as the ADVmonster M60 or Cyclops Motorsports light canon if it's wired to the battery?
I have an 06 WR (250f everything should be the same as the 450). I'm looking at options for more light. LED is the future imho.
Goofy Footer is offline   Reply With Quote
Old 08-23-2013, 10:57 PM   #362
Rider 101
Wannabe adventurer
Rider 101's Avatar
Oddometer: 1,084
congratulations!
Welcome to the world of blue bikes! Great choice.
I have a modified Whipps that came of a DR250. with a bit of stainless flat bar and a tig welder it came up ok. I will dust it off tomorrow and take a few pics. I bolted it through the seat bolts, made spacers and used side plate bolts and also put a bolt through rear guard. It is the perfect size for a 4 litre Rotapax jerry can.
Originally Posted by Farmer Roy View Post
just bought myself a new WR450
what are people doing about carrying luggage etc in the way of racks & frames for soft panniers
any photos or comments on home made solutions would be great also
cheers
Rider 101 is offline   Reply With Quote
Old 08-24-2013, 03:29 PM   #363
Farmer Roy
Farmer Roy's Avatar
Oddometer: 381
yeah cheers for that, thanks
looking forward to the WR, cant wait to get it home, plan is to sell both the DR & XR and set the WR up as a light adventure bike / bush bike
Farmer Roy is offline   Reply With Quote
Old 08-25-2013, 01:23 AM   #364
Rider 101
Wannabe adventurer
Rider 101's Avatar
Oddometer: 1,084
wr450 rack
Farmer Roy,
check this one. Looks better than my home made.
http://www.promotobillet.com/catalog...roducts_id=291
Old 08-25-2013, 01:49 AM   #365
Rider 101
Wannabe adventurer
Rider 101's Avatar
Oddometer: 1,084
forgot to mention
Forgot to mention I had decided to give the 450 a run. It has been sitting for a couple of months. Fuel tap on, pull the choke, hit the button,,,,, nothing. Flat battery. Time to swing the leg. Bike fires up but won't idle. Bugger, time to pull the carby apart. 5 hours later after much cursing it is back together and fires up first kick. The carby was full of green gunk. The brass jets were covered in green to the point where iven the main jet was blocked. I had to use an oxy tip cleaner to get rid of the crap.
Moral; don't leave stale fuel in the carby.
I was a little surprised at the green corrosion. Have I managed to put some of that shitty E10 in the tank without realising or is it just our top class premium ( 98RON) fuel here in Oz.
Old 08-25-2013, 07:37 PM   #366
Deseret Rider
Deseret Rider's Avatar
Oddometer: 248
How to carry stuff
cheers
Take a 3/4" length of PVC pipe----heat it across the middle with a heat gun until it is soft and pliable-----bend it across the back fender just behind the seat. Let it hang off on either side to the desired length. Zip tie it in place at the back and on each side. Glue a PVC T on the bottom and a reducer---run a piece of 1/2 inch PVC forward---using the heat gun to form it and bolt that to the frame/subframe junction. Now, what you have is a carrier to which you can affix some soft bags or duffles. The advantage of this home made system is that you can carry the load below seat level--- Those nice racks that carry the load high---above seat level are a problem for short legged guys like myself-----My system works---allows me to swing my leg up over the saddle and ---it didn't cost anything since I had the PVC scraps lying around anyway. Pictures at 11:00
Deseret Rider is offline   Reply With Quote
Old 08-26-2013, 01:24 AM   #367
Rider 101
Wannabe adventurer
Rider 101's Avatar
Oddometer: 1,084
interested
I will be interested in your photos. I am always looking for home grown ( made ) solutions.
Old 08-26-2013, 06:26 PM   #368
Deseret Rider
Oddometer: 248
Pnoto's at 11:00 or maybe not?
I may need a short course on how to imbed photos's here---lacking that I could PM them to anyone who wants them and whose email address I can find.
I'll shot the photo's in the morning and try to have them ready to send mid morning. I'm not sure I know how to get them to show here though?
I am pleased with this setup----right now I have saddle bags on them---but I also have some weather proof duffles which I use when I need larger capacity than the Saddle bags.
Old 08-26-2013, 07:40 PM   #369
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,183
You need to host the images somewhere, like Photo Bucket. Then get the link from Photo Bucket and paste that link directly on the page you're typing onto. No need to use the buttons & tabs above the page, they aren't needed anymore. It's very simple, "after" you've figured it out.
GlennR is offline   Reply With Quote
Old 08-27-2013, 04:59 PM   #370
Deseret Rider
Oddometer: 248
http://s586.photobucket.com/user/Des...g.html?filters[user]=91423359&filters[recent]=1&sort=1&o=0
http://s586.photobucket.com/user/Des...g.html?filters[user]=91423359&filters[recent]=1&sort=1&o=1
If you look closely at the photo taken from behind and up under the fender you can see the PVC pipe hanging down on either side and tie wrapped to the plastic panel--- You will have to use imagination to see how the pipe was formed into a U shape with the closed end resting on the fender just aft of the seat and touching the seat. You can then imagine that the inverted "U" will focus the weight of whatever you attach to it on the subframe. The "T" on the bottom provides a tie point for the bottom on the bags (or duffles or whatever you are using). Notice also that there is an 'extension' from the T which extends forward and is formed and attaches to the frame---on both sides. This PVC simple 'frame' provides a very simple but strong and stable base. You can expand a little on this design if you desire--maybe provide a double bar on the bottom to act as a sort of floorboard---and then attach a set of Wolfman or Ortleib type duffle bags. Walmart also has a waterproof folding duffle similar in design to the Wolfman style.
In my case I use a set of saddlebags (as pictured) for day trips---and switch to the duffle style bags for multi day rides.
my whole plan for using this style of a carrier is simply to keep the load low and off the top of the bike. This allows me to get my leg up and over the saddle which is hard to do if there is anything tied higher than the saddle.
Old 08-27-2013, 05:01 PM   #371
Deseret Rider
Oddometer: 248
Pictures at 11----
Not sure that I did that right-----can anyone find tho pictures that I was trying to imbed in my last message? I may not have followed the instruction correctly-----??? but will still email the pics to anyone who still wants to see them.
Old 08-27-2013, 05:14 PM   #372
Deseret Rider
Oddometer: 248
Maybe this time?
These photo's if they come through will coordinate with the text that I've included in my prior message.
Old 08-27-2013, 06:28 PM   #373
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,183
Desert Rider,
Good job. I like your simple & cheap solution.
Old 08-28-2013, 03:39 AM   #374
Rider 101
Wannabe adventurer
Rider 101's Avatar
Oddometer: 1,084
like it
Deseret,
like your improvisation. I will be looking to mod my 450 so I can use it a little more. There is some great rough camping in my part of the world an I would like to make the most of them while I can.
Old 08-30-2013, 12:55 AM   #375
Farmer Roy
Farmer Roy's Avatar
Oddometer: 381
Deseret,
umm, pickiing up my new 450 on monday
plan is to lightly 'adventurise' it also
will hav to compare notes ay
Times are GMT -7.   It's 07:17 PM.
