Thread Tools Rating: Thread Rating: 46 votes, 5.00 average. Display Modes
Old 01-02-2010, 05:34 PM   #1
farmerger OP
Snowed in Adventurer
farmerger's Avatar
Oddometer: 520
Skid Steer Loaders vs Track Loaders
I need the collective's input here. I'm thinking of switching from a tractor to one of these units on my 40 acre hobby/horse farm. Need it to do manure, plow snow, move dirt, plant fence posts, grade the yard, etc. Any opinions would be much appreciated.
I'm kind off leaning toward a track loader as in the spring and sometimes the fall the mud here can get pretty nasty. However, the local Bobcat dealer said the track loaders slide all over the place on hard pack snow and ice, which if true would be a deal breaker on the track loader. It's got to be able to plow/push/blow snow, that's a must.
So lets hear it.
Thx.
Crashin' like Ewan!
Billy Connolly - "If women are so bloody perfect at multitasking, how come they can't have a headache and sex at the same time?"
farmerger is offline   Reply With Quote
Old 01-02-2010, 05:45 PM   #2
Carlo Muro
Supercàzzola
Carlo Muro's Avatar
Oddometer: 2,120
keep in mind that track loaders have a different track than bulldozers. They don't have the "teeth" that a dozer does because they need to turn a lot.
It would also depend upon whether or not you need to move it around from location to location. I've not seen many track loaders small enough to tow behind a 3/4 or 1 ton pickup.
Carlo Muro is offline   Reply With Quote
Old 01-02-2010, 05:54 PM   #3
KLboxeR
Back in the game again
Oddometer: 3,650
I used to have a skid steer for my tree service but I went to a medium frame 4wd Kubota. Other than the skid steer's ability to lift more weight and fit in tighter spaces, the tractor wins out wrt usefulness in every way.
-easier to maintain
-3 point/pto attachments are cheaper
-detachable loader
-easier to transport
-less damage to finish lawn areas
-selectable 4wd
-if you put a set of chains on the front, it'll go places where a ss would get buried
-better on hills
-tires last longer than skid steer tires/tracks
-more economical per hour of use
-easier to get on/off the machine
-less stressful for the operator (skid steers can be noisy/bumpy/hot/cold to operate unless you have quite a few expensive options)
YMMV, but I think the tractor is much easier to live with and is much more productive if you're not doing full on excavating/construction work.
Chris
KLboxeR is offline   Reply With Quote
Old 01-02-2010, 08:16 PM   #4
nwcolorider
NWCOLO
nwcolorider's Avatar
Oddometer: 2,570
Ditto
I just got rid of my Bobcat, 763. I had the auger, snow blade, bale fork, but also went to a medium size Kubota. After a week, I could not be happier. Easier to use on the snow, I can move bales with ease. Much smoother. Better on the side hill. I also have a wide variety of 3 point implements that I can use, that are cheaper to get than the Bobcat attachments. I have used the tracked bobcats on the snow and they do not work as well on snow as the bobcat. Kinda spooky on the hardpack as they will slide.
Civilization exists by geological consent, subject to change without notice.
Will Durant
http://nyoast.weebly.com/
nwcolorider is offline   Reply With Quote
Old 01-02-2010, 08:20 PM   #5
subybaja
subybaja's Avatar
Oddometer: 2,889
+1
My dad uses his loader/hoe to dig out 8-foot snowdrifts in the winter. A skidsteer wouldn't touch them.
My buddy who works line maintenance for an equipment rental outfit hates the tracked skidsteers. They throw tracks constantly, which are a bitch to get back on. I've helped him on jobsites, and there's nothing quite as fun as laying in 2 feet of mud/swamp, trying to lever a slippery rubber track back on with a 10' bar.
subybaja is offline   Reply With Quote
Old 01-02-2010, 08:34 PM   #6
Cumminsman76
befuddled
Cumminsman76's Avatar
Oddometer: 8,575
Have you looked at Bobcat toolcats? But a tractor would probably be better.
STURGIS ride report.
2009 R1200 Gelände/Straße Abenteuer
A GS is like chlamydia, it grows on you whether you want it to or not. WhiteManFlail
Save $5 on Smugmug "1alkVgTNLEuyQ"
Cumminsman76 is offline   Reply With Quote
Old 01-02-2010, 09:36 PM   #7
farmerger OP
farmerger's Avatar
Oddometer: 520
You guys are trying to talk me out of a new toy, yikes! But it's not working. I have a couple of reasons for switching, the main one being that in a skid steer I will be able to see my bucket all the time. My depth perception isn't the greatest, and although I've gotten a lot better with practice, I want/need to be able to see the front of the bucket. Also, although my tractor is just about the right physical size for my acreage, it lacks in lift capacity; not to mention that driving around with a bucket full of dirt on a tractor over uneven ground is kind off tipsy. I would think a skid steer would be a lot more stable with a full bucket.
I'm a little perplexed by the comments that a tractor is better at snow removal. Unless you have one with a front mounted snow blower, I don't see how a tractor can compete with a skid steer. Not too mention that with the skid steers its real quick to change from a front mounted snow blade/blower to a bucket. It takes a bit more time and effort to retool a tractor. And driving backward with a 3 pt mounted snow blower is a real pain in the neck.
I saw the new Toolcats, way cool, and way expensive.
I appreciate your comments, so please keep them coming. I doubt you'll talk me out of ditching the tractor, so let's keep it to comparing skid steers vs. track loaders. I was thinking this afternoon, maybe the best way to go is a skid steer with aftermarket tracks for the soft stuff.
Crashin' like Ewan!
Old 01-03-2010, 02:19 AM   #8
fullmonte
Reformed Kneedragger
fullmonte's Avatar
Oddometer: 5,167
Have you considered a Takeuchi TL150 tracked skid steer? Close in size and weight to an 863 Bobcat so it can be pulled by an F250. I've operated all kinds of skid steers by Case, New Holland, Deere, and Bobcat. The TL controls seemed more intuitive and the machine is much smoother to operate, in addition to the added stability of the tracks, which negates the wheel bounce encountered in rubber tired skid steers. Demo one and see what you think.
"If you are looking for the typical ride to a restaurant, eat tacos, hold the middle finger over the food, stop and take a picture of a gravel road type ride, you probably won't be interested." - dlrides
"A guy I know was the lead researcher for the University of Utah federally funded study of cellphone and texting use while driving. He found that your twice as dangerous as a drunk while using your cell phone and I think it was up to six times worse if the driver was texting."-dakardad
fullmonte is offline   Reply With Quote
Old 01-03-2010, 06:51 AM   #9
2whlrcr
gooligan
Oddometer: 6,107
I've got a similar operation to yours. I had the same thoughts too. I think the bottom line is, if you need one piece of machinery to do it all, a tractor is the best choice.
I've got a 4wd 38hp Kubota with a loader and blade on the back. I put chains on the rears for snow removal (although I'm tempted to put front chains on too, for better traction and steering). I can also do plenty of light dirt work with this combo. And a Bushhog goes on the back in the summer for mowing. I also turn my manure with it. I do have an old AC D17 that is dedicated to pull the spreader.
I would like to have a skidsteer sometimes to do the light jobs or work in confined areas. But I manage to get by with my main tractor. If price isn't any concern and you've got plenty of room in your machine shed, then go crazy.
2whlrcr is online now   Reply With Quote
Old 01-03-2010, 07:07 AM   #10
Nailhead
Painting by numbers
Nailhead's Avatar
Oddometer: 6,144
I respectfully disagree. In the course of 10 years of construction work, I have used a skid steer as a loader, trencher, fork lift, post-hole digger, tree spade, concrete shooter, concrete breaker, log skidder, log lift, and crane. Add to these uses like concrete saw, sweeper, and backhoe, and I can't imagine a tractor as versatile. Also, they are MUCH more maneuverable than even a center-articulating tractor, and more compact.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 01-03-2010, 09:01 AM   #11
HowlingMad
drags knuckles
HowlingMad's Avatar
Oddometer: 1,352
Originally Posted by farmerger
... I doubt you'll talk me out of ditching the tractor, so let's keep it to comparing skid steers vs. track loaders. I was thinking this afternoon, maybe the best way to go is a skid steer with aftermarket tracks for the soft stuff.
Seems people have missed your request, so I'll see if I can answer it more directly. I have some time in both, although my experience in a Bobcat goes back at least 12 years to the days of the X86 line. I have a lot of time in the 763 and the 963, their biggest at the time and much smoother than the 7 and 8 series. From there we went to an early Cat 257 like this one:
(Except not a B model)
After running the MTL, I can't imagine where the soft tire model could be better with one exception: road work or hard surface (yard work, materials etc).
Here are the things I really enjoyed about the machine that I feel are better than the skid steer:
-Quick - it's amazing how much faster this machine scoots around. I've used it countless times for shuttling material around a job when bigger machines were available because of the speed, maneuverability and impact.
-Ergonomics - My experience with the Bobcat is old, so perhaps this has changed, but the Cat style joysticks, foot accelerator (as well as static throttle) made for more precise control and comfortable workday. The amount of effort required felt more like you were driving with your mind than your body. Sounds silly, but it's huge if you use the same machine every day.
-Impact - Neither will be as delicate on a lawn as a tractor, but you can't argue with a lower PSI on the ground of the tracks. Turns are always an issue, but I'll take the MTL over the wheeled loader any day when it comes to customers lawn.
-Stones - Again, my experience with the Bobcat is old, but the CAT had more balls all around.
If memory serves correctly, ASV pioneered this technology and CAT bought the bottom ends and technology for their machines the first few years of the MTL.
If you plan to keep your tractor, then perhaps having another tool that is more different from your tractor (tracks vs wheels) will give you a better range in your toolset.
Good luck put up some pics of what you finally buy.
Edit: just found this, an interesting read.
HowlingMad is offline   Reply With Quote
Old 01-03-2010, 10:36 AM   #12
cagiva549
whats a cagiva
Oddometer: 2,454
There are hundreds of attachments for skid steer and if you want something different build it , cant say that for tractors and track loaders are obsoleate , from 5 to 10 grand for a set of tracks in as little as 1500 hours . If you must you can bolt a set of tracks on a skid steer with tires . Its not as good as real tracks but a lot cheaper in the long run .
I swore off bobcat after replacing axel seals and bearings in one years ago , now I only work on Case machines and a well kept 1845 is the best in my opnion , not the easyest to access the pumps but very tough little machine . The XT is still good but the new ones like the 450 are a plastic pile of crap . SEYA
David H
00 Cagiva GC
04 9 fiddy
05 ST3 duck
07 KTM 450 EXC
86 Goldwing my geezer ride
cagiva549 is offline   Reply With Quote
Old 01-03-2010, 12:04 PM   #13
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,784
Originally Posted by cagiva549
SEYA
What does that mean anyway?
'06 KTM 950 Adventure S
'12 Ram 2500, Cummins, 6-speed auto, Laramie Longhorn, RamBox
"The bouncer is a bulldog who looks like Wilfred Brimley and the password is 'diabetus'"-Stefon, SNL character
DakarNick is offline   Reply With Quote
Old 01-03-2010, 07:25 PM   #14
mrmurph
mrmurph's Avatar
Oddometer: 363
Another thing you might consider is a skid-steer with the track attachment for when it's really muddy. I had one (Bobcat) for 5 years and used the rubberized drive-on tracks in extremely muddy conditions or when I needed to protect a customer's surface when wet . It's a compromise, but if you don't need the tracks all the time, it's a good solution...I prefer the skid-steer whenever possible. FWIW
Common sense isn't very.
Murph
Motorcycles, Cars, Guitars.....
mrmurph is offline   Reply With Quote
Old 01-03-2010, 08:17 PM   #15
varaman
Oddometer: 408
I have one of those things. Straight 1845. No C or otherwise. A 1981 model. Other than a tandem pump re-seal, alternator, water pump, starter, tires, and general maintenance, it's been a great machine. They were a little noisy back then, but built much more solidly than the new offerings.
Terry
varaman is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 02:55 PM.
