Old 01-03-2010, 04:27 PM   #1
codyrides OP
The Milkman
codyrides's Avatar
Oddometer: 107
Wee valve shim lapping by hand How To
So I was asking around about doing the valve adjustment on my K8 wee in this thread.
I ended up getting some excellent responses and suggestions. Particularly from duckrider, who suggested that I lap my own shims. So much more accuracy than using the factory .5 MM increment replacements, or even the illustrious .25 MM shims that were hinted to exist. Duckrider’s solution was simple. Use 400 grit wet/dry sandpaper on a flat surface, lubricate with WD 40 and grind slowly away.
Well I thought about it and it dawned on me. I don’t need the sand paper, I have another tool for the job. A few years back I studied Japanese food at a Sushi Bar. Two nights a week after my day job. One night in the kitchen, and one night behind the bar. One of my biggest tasks was to learn not just how to use the variety of blades at my disposal, but how to keep them razor sharp. And how to do it without ruining the shape, the bevel and the balance of the blade. That is when I was introduced to Japanese water stones. They are very much like whet stones I had seen before but are lubricated with water rather than oil. For this job, I decided to use my 800 grit cutting stone and my 6000 grit polisher.
First I tried a back and forth motion on the cutter, but found that that lapped it unevenly.
I settled in on a circular motion.
I made sure to lap the side that was factory marked to avoid them being mis identified in the future.
I measured after every 30 seconds or so of lapping.
Since my Mic is in inches, I converted all my measurements to SAE and went from there. Here, my target shim thickness was .067 inch. It started at .0705. Getting there.
Right as I approached the mark, I switched to my polisher to give the shim a mirror finish. Sorry, no pics of that, my little digicam just couldn’t capture it.
After the polish grind, I washed the shim in alcohol, then WD40, then oil before re-installing it.
So as of right now, I have done the entire rear cylinder, and re-installed everything except the valve cover. Here are my old and new measurements (converted back to MM).
I1 - .089 -> .178
I2 - .102 -> .178
E1 - .203 -> .279
E2 - .203 -> .279
I should get the front done next weekend, and have this task behind me.
Big thanks to everyone that had helpful suggestions. They made it really easy to do.
Cody - "The Milkman Delivers"
08 wee - mine
05 DR200SE - wife's
codyrides screwed with this post 01-03-2010 at 10:15 PM
codyrides is offline   Reply With Quote
Old 01-03-2010, 06:22 PM   #2
tedder
irregular
tedder's Avatar
Oddometer: 8,797
This reminds me of why I'm happy to have the shim kit.
tedder is offline   Reply With Quote
Old 01-03-2010, 06:54 PM   #3
AtlantaViking
AtlantaViking's Avatar
Oddometer: 923
Nice. I saw your other thread and I think its great that you posted your results. I'm going to use the sandpaper method when the time comes as I don't have any sushi tools laying around.
I really like the idea of not having to leave and go hunt the shims once you've done your teardown. Just do it all in the shop at once.
Good Stuff!
AtlantaViking is offline   Reply With Quote
Old 01-03-2010, 10:05 PM   #4
tomatocity
Retired and lovin' it
tomatocity's Avatar
Oddometer: 795
The sanding method is quite ingenious and precise though I am a simple person. I learned how to adjust motorcycle valves with a KLR and the KLR community is known for its Tech Days and sharing resources. Does the V-Strom community have Tech Days? Luckily I have a friend that has V-Stroms and we share resources. Yesterday (Saturday) we adjusted the valves on my DL1000 and installed heated grips. He has a shim kit and the local dealership helps keep the shims stocked evenly. I learned about the valves and he learned about fastening grips.
Soon we are going to we are going to remove, empty, and refill our forks. I have done KLRs and he has done V-Stroms. I have a siphon tool for mearsuring fluid level and he has never filled forks like this before.
Sharing time, knowledge and resources can be as quick to do multiple V-Stroms as to do just one. Now throw in the fun factor and we have a winner.
End result is the shim kit and a couple guys saved some shims from being sanded and polished. Good or bad, probably does not matter.
Tim
2012 Yamaha Super Tenere #027, 2005 KLR, 1993 Chevrolet S10,
tomatocity is offline   Reply With Quote
Old 01-03-2010, 10:33 PM   #5
tedder
irregular
tedder's Avatar
Oddometer: 8,797
Yep. A friend and I have had a combined 7 DL650s, one of us usually has spare parts or the tools to do something specific.
Old 01-04-2010, 07:03 AM   #6
Night_Wolf
Leg Humper
Night_Wolf's Avatar
Oddometer: 8,088
Added to the Wee Strom Index
L 51.01.900 / L W 114.05.900
"That road less traveled is a toll road, and sometimes the charge is more expensive than we ever expected. Most of the time, it's a one way road. Make the decision, hope for the best, and start traveling. Carry lots of coins." PecosBill
Pick good friends and you'll never be lacking Family Me
Night_Wolf is offline   Reply With Quote
Old 01-04-2010, 08:05 AM   #7
greywolf
Unpaved road avoider
greywolf's Avatar
Oddometer: 984
A figure 8 pattern seems to do the best job of keeping the shim surfaces parallel. I used to be against the practice because of warnings of removing case hardening but it's hard to argue with the success of the practice and the dearth of problem reports.
Pat
in order of ownership
1971 Honda CB350, 2 1973 Honda CB500s, one was stolen, 1974 Can-Am 175 TNT, 1978 Yamaha XS11, 1978 Honda CX500, 1975 BMW R90S, 1983 BMW R65LS, 2005 Suzuki DL650 totaled, 2007 Suzuki DL650A, 2012 Suzuki DL650A
greywolf is offline   Reply With Quote
Old 01-04-2010, 04:02 PM   #8
Gustavo
Motociclista Errante
Gustavo's Avatar
Oddometer: 2,286
I1 - .089 -> .178
I2 - .102 -> .178
E1 - .203 -> .279
E2 - .203 -> .279
You haven't taken the front apart yet? Sometimes the shim you need is the one you take out of another valve. Not sure that's going to be the case here, but it could save someone some time if you check all shim sizes first and then replace/sand them as needed.
I'd also recommend people ask their dealer about shim replacement. I know several places that will simply swap your wrong-sized shims for ones with the dimensions you need at no cost. It may not be as accurate as custom sanding but it takes 5 minutes instead of a whole weekend.
Gustavo
Gustavo is offline   Reply With Quote
Old 01-04-2010, 08:37 PM   #9
tedder
irregular
tedder's Avatar
Oddometer: 8,797
It's even easier if you have a friend with a full kit.
Old 01-05-2010, 01:27 AM   #10
simmersonwheels
Asleep at Switch
simmersonwheels's Avatar
Oddometer: 116
Wow, I saved a couple of bucks!
If the shim isn't perfectly square, might it damage the valve or cause galling or wear? Also, how critical is the factory surface?
When Suzuki introduced the RMZ250K4 they gave this warning about the shims on that model-
TAPPET SHIM
q
Forged, 7.5 mm OD tappet shims.
q
Selection range: 2.50 - 3.50 mm.
q
To prevent damage to the surface treatment
at the top surface of the valve stem, only
use tappet shims specified for the RM-Z250.
If the surface treatment is damaged, the
valve will fail. Do not use 7.5 mm OD sintered
metal shims that are available from
the aftermarket or specified for some
Kawasaki models. Do not use 7.5 mm OD
forged shims specified for GSX-R models
as the surface finish is slightly different and
the adjustment range is not suitable (1.20 -
2.55 mm).
Now I have never seen a warning for the DL shims, but why risk damaging the top end to save a few bucks? I'm not saying that I know what the valve/shim surface treatment is, I'm saying that because I DON"T KNOW I would rather not take the chance......Once surface hardening is damaged a part fails incredibly quickly.
If it's in the specified range, leave it alone, if you need a shim, just by one. I mean you are only doing it every 20000 kms anyway....
Simon
simmersonwheels is offline   Reply With Quote
Old 01-06-2010, 10:39 PM   #11
duckrider
duckrider's Avatar
Oddometer: 993
Originally Posted by JoelWisman
These to wears are designed to counteract each other. This is finetuned to be in ballance by the finish on the shim in many engines.
Come on Joel, I think you are putting us on. You are saying that some engineer at Suzuki somehow calculates the distance that a valve will tulip or recede into the seat in a given time and then designed a valve train that will wear at the same rate to make up that distance.
duckrider is offline   Reply With Quote
Old 01-07-2010, 07:55 PM   #12
duckrider
duckrider's Avatar
Oddometer: 993
Well, engineers at BMW do exactly that
Maybe so, but it's hard to imagine them running an engine on the dyno for the equivalent of tens of thousands of miles with different alloys and surface treatment of cams and buckets it hopes of getting them to wear at the same rate as valve recession. After all, people expect valves to need adjustment at some point.
I would think that if BMW engineers had any spare time they would put it into making a bullet proof final drive as people do not expect failure of the FD. Also they would not release what would appear to be a beta version of a bike as they seem to have done with the GS800 with failures of axles, chains, wheel bearings, fuel gauges, fuel injection glitches, clutches, etc.
On a different note, anyone buying a shim kit should make sure that they are factory shims, not after market from some mystery source. If they are examined with a high power glass some have really crude finishes.
Old 01-07-2010, 08:47 PM   #13
DaveM
Rider
DaveM's Avatar
Oddometer: 50
OK since I work on cylinder heads all day I will tell you that the engineers dont design for equal wear but minimum wear within the cost constrants of the design. Some materials or coatings that work great are just to costly to use.
They will run new designs long enough to measure the wear so as to come up with the recomended check/adjustment interval
DaveM
DaveM is offline   Reply With Quote
Old 01-08-2010, 07:30 AM   #14
duckrider
duckrider's Avatar
Oddometer: 993
lol. Your an ass hole
Now there's an adult response, but face it Joel, if you make shit up to impress us with your vast knowledge you are occasionally going to get busted for it.
Old 01-08-2010, 10:06 PM   #15
swingset
Got the knack.
swingset's Avatar
Oddometer: 10,808
Nothing he said warranted that response...are you sure you know who the asshole is?
The Rant-Fu blog & podcast ->Rant-Fu
swingset is offline   Reply With Quote
Times are GMT -7.   It's 06:00 PM.
