Old 01-09-2010, 12:23 PM   #16
simmersonwheels
Asleep at Switch
simmersonwheels's Avatar
Oddometer: 116
ummm, yeah... back to the shims
Originally Posted by simmersonwheels
If the shim isn't perfectly square, might it damage the valve or cause galling or wear? Also, how critical is the factory surface?
When Suzuki introduced the RMZ250K4 they gave this warning about the shims on that model-
TAPPET SHIM
q
Forged, 7.5 mm OD tappet shims.
q
Selection range: 2.50 - 3.50 mm.
q
To prevent damage to the surface treatment
at the top surface of the valve stem, only
use tappet shims specified for the RM-Z250.
If the surface treatment is damaged, the
valve will fail. Do not use 7.5 mm OD sintered
metal shims that are available from
the aftermarket or specified for some
Kawasaki models. Do not use 7.5 mm OD
forged shims specified for GSX-R models
as the surface finish is slightly different and
the adjustment range is not suitable (1.20 -
2.55 mm).
Now I have never seen a warning for the DL shims, but why risk damaging the top end to save a few bucks? I'm not saying that I know what the valve/shim surface treatment is, I'm saying that because I DON"T KNOW I would rather not take the chance......Once surface hardening is damaged a part fails incredibly quickly.
If it's in the specified range, leave it alone, if you need a shim, just by one. I mean you are only doing it every 20000 kms anyway....
Simon
I've never heard or thought about "compensated wear",(Not saying it is or isn't valid). I think in this case the issue was that the shim hardness and surface finish are being chosen to work properly with the valve stem finish/hardness.
In the 2 examples in the Suzuki tech intro, both have titanium valves, which of course the DL does not.
I'm certainly not saying lapping WILL cause damage, I'm just commenting that for me the perceived benefits of "Perfect incremental" adjustment, and saving money on shims are not remotely worth potential damage of the valve train. If a valve did let go, the motor is likely toast from an economic standpoint.
Over the years I've seen lot's of unusual failures that trace their origins to seemingly inconsequential ideas that "seemed like a good idea at the time"
Simon
simmersonwheels is offline   Reply With Quote
Old 01-09-2010, 06:34 PM   #17
996DL
Buell me
Oddometer: 2,189
Oops, thought I had wandered into Jo momma or an oil thread or something.
996DL
996DL is offline   Reply With Quote
Old 01-10-2010, 01:49 AM   #18
duckrider
duckrider's Avatar
Oddometer: 993
Well since I'm on Mr. ultra sensitive's ignore list maybe I can post without a junior high school name calling response or a mini tantrum . A "prefect" valve adjustment (I would call it an "accurate" adjustment) has nothing to do with noise reduction. It's just that in a 4 valve motor they seem to run smoother if both intakes or exhaust valves in a cylinder are adjusted to have exactly the same clearance, thus opening at exactly the same time. I generally set them half way between min and max specs.
I think Joel is misinterpreting what I said about setting the closing clearance on Ducati valves. Ducks have no valve springs. one lobe and rocker opens the valve, one lobe and rocker closes the valve. The engines are happiest with less than .001 clearance on the closer. This almost always requires lapping the shim. If it is set at say, .004, the valve is slammed into the seat by inertia It's better to take the valve all the way to the seat mechanically. Again it has nothing to do with noise. After all, the dry clutch is loud enough to cover any valve noise.
duckrider is offline   Reply With Quote
Old 12-07-2010, 07:52 PM   #19
spibbie
sportster barbarian
Oddometer: 92
Some posters question the wisdom of adjusting valve shims with sandpaper, water and flat cast iron. Japanese wet sharpening stones too.
I have to admit I have my doubts. But I tried it.
I used sandpaper, water and flat iron to adjust the valves on my ninja 250. at 8k miles. It has run perfectly since. now at 25k, 2nd check after sanding the shims. clearances are right where I left them, 17k ago.
It worked for me.
spibbie is offline   Reply With Quote
Old 12-07-2010, 11:34 PM   #20
pjensen641
pjensen641's Avatar
Oddometer: 334
Only thing I can think of about surface treatment etc is that the shim might be case hardened rather then through hardened. If case hardened, lapping could cause you to get in to the softer base material. Dunno, seems like such a small part that case hardening is unlikely.
pjensen641 is online now   Reply With Quote
Old 12-08-2010, 05:36 AM   #21
cristi-mic
cristi-mic's Avatar
Oddometer: 95
I did the same operation on my TDM850 engine (installed in the Super Tenere) and I must tell that the steel is not that hard (and surely not surface hardened). A piece of sandpaper and a few minutes of 8-pattern grinding is enough to reduce thickness to the required values.
The only thing is that thickness will not be exactly the same (bigger in the center), but that's where the valve stem contacts the shim, so not a big deal.
http://cristi-mic.blogspot.com/
cristi-mic is offline   Reply With Quote
Old 04-06-2011, 06:25 AM   #22
spibbie
sportster barbarian
Oddometer: 92
It worked for me.
Still running perfectly at 32k miles when I sold it.
Old 04-06-2011, 12:02 PM   #23
Jeff B
Socially Awkward
Jeff B's Avatar
Oddometer: 5,659
For statistical purposes the last two times I had to make shim under bucket adjustments, both times I was lucky enough to only have switch shims around like Gustavo mentioned.
And if you want a parallel lap, then figure 8 motion is the way to go. I used occasionally lap the seats in diesel fuel injection nozzles and fig 8 motion is how we did it. Your mic will confirm it.
Jeff B is offline   Reply With Quote
Old 04-06-2011, 08:06 PM   #24
codyrides OP
The Milkman
codyrides's Avatar
Oddometer: 107
I know that there was a lot of differing opinion on the subject, so I wanted to give it a year and see what was up.
In my case, I had a 21k mile year with a TAT, Iron Butt, and 2 big mountain touring rides in the mix. While doing the winter maintenance, I took the covers off and found that my clearance had not changed at all.
In the case of the DL650, my experience indicates that hand lapping my own shims was an appropriate alternative. Other's mileage may vary of course, but I am satisfied that this method stood the test of time for me and for my bike.
Cody - "The Milkman Delivers"
08 wee - mine
05 DR200SE - wife's
codyrides is offline   Reply With Quote
Old 04-06-2011, 10:10 PM   #25
Tosh Togo
Oddometer: 1,594
Actually...some valve shims are harder on the surface than the parent metal a few thousandths beneath the working surface. I've had to adjust shim thickness that way on three different engines so far, and in two cases the resulting clearance was short lived.
Not all are that way, but some are, and I've no idea how to tell them apart. The factory has no need to make the shims owner-adjustable, so....
It depends on how thick it is, and how much you lap off to get your desired clearance. It'll work, at least for a while, and maybe to the next valve-inspection interval, but if it were my bike I'd re-check the valves that get the massaged shims after a thousand miles or so... it's better to have a small surprise in the shop than a bigger one while you're riding.
Tosh Togo is offline   Reply With Quote
Old 04-07-2011, 11:03 AM   #26
duckrider
duckrider's Avatar
Oddometer: 993
At 20k miles I had one valve that was a bit tight. I lapped a few thou to set it midway between the specs. Checked it again at a little over 50k and there was no measurable change.
Old 04-07-2011, 05:23 PM   #27
tomatocity
Retired and lovin' it
tomatocity's Avatar
Oddometer: 794
The shims used for a KLR650 are sequentially .002" different and I have seen, I believe Ford SHO, shims that are .001" different.
Tim
2012 Yamaha Super Tenere #027, 2005 KLR, 1993 Chevrolet S10,
tomatocity is offline   Reply With Quote
Old 04-09-2011, 09:53 AM   #28
batmo
Just a Rider
batmo's Avatar
Oddometer: 112
That maybe true..but I had you on a toe line for some of those miles.
batmo is offline   Reply With Quote
Old 04-09-2011, 10:56 AM   #29
duckrider
duckrider's Avatar
Oddometer: 993
Yea, but only the first few miles were in the snow (Bad side stand switch that now lives in the landfill)
Times are GMT -7.   It's 09:40 PM.
