Old 01-04-2010, 12:33 PM   #1
DSM8 OP
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,148
Talking 990 Aux HID
So taking a page from some of the other offerings for aftermarket lights to use on the 990/950 platform I went a slightly different route since I cant use the great kit put together from one of the forum members (dustjunkie) currently for sale due to location of the EFI brain.
I ended up using these: http://www.niterideroffroad.com/cm.shtml
And they installed like this, right onto the existing cross bar under the headlight. Since I removed the ABS I am using that circut to power the lights.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
WWW.DSM8.whereamiriding.com
DSM8 is offline   Reply With Quote
Old 01-04-2010, 01:11 PM   #2
KTRMN8R
Inmate
KTRMN8R's Avatar
Oddometer: 1,111
Cool2
Not bad,... does the ABS circuit take up the accessory wires that are on the 950's for your 990 application?
KTRMN8R is offline   Reply With Quote
Old 01-04-2010, 01:20 PM   #3
DSM8 OP
DSM8's Avatar
Oddometer: 3,148
I have no idea, there was an unused 40 amp circut down by the right foot under the skid plate, this was for the ABS, I just used that since the ABS is no longer on the bike.
Old 01-04-2010, 01:28 PM   #4
KTRMN8R
Inmate
KTRMN8R's Avatar
Oddometer: 1,111
Cool2
If you look behind the headlight/ windscreen(when they are removed),... 2 minute job,.... you may find that you have 2 additional circuits not being used. They will be marked ACC1 & ACC2 one is a switched hot & the other is constant. You can tell which is which be using a multimeter & cycling the key,... who knows,... may help with future farkeling
Old 01-04-2010, 01:30 PM   #5
DSM8 OP
DSM8's Avatar
Oddometer: 3,148
Oh those, i know about them already have heated grips hooked up to one. I didnt want to use that for the HID since there are two ballasts. The other one I used was a 40amp; so that was more than enough without stressing the fuse block or such.
Old 01-05-2010, 08:00 PM   #6
MommysLittleMonster
MommysLittleMonster's Avatar
Oddometer: 778
post some pics of them at night! i would love to see how they look
05.5 KTM Adventure S
03 KTM 625 SXC
www.BBFabrication.info
Beef up your KTM Adventure subframe!
http://advrider.com/forums/showthrea...2#post13099772
MommysLittleMonster is offline   Reply With Quote
Old 01-05-2010, 08:27 PM   #7
Qwik
Two Wheeled Addict
Oddometer: 5,234
Website shows them as discontinued!
Speed bumps never seem to make me go any faster
Qwik is online now   Reply With Quote
Old 01-08-2010, 07:17 PM   #8
DSM8 OP
DSM8's Avatar
Oddometer: 3,148
didnt realize that was the case, still have to get out and take pics, it doesnt light up the nite like some of those kits do. It really fills in all the dark spots left there from the EU headlight in both low and high beam. More like a fill in light for the first 75feet out in front of you like a flood.
Times are GMT -7.   It's 09:14 AM.
