Old 01-07-2010, 06:17 PM   #16
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
you must have ridden a newer bike or an asian bike.
mine's the same. wear thicker boots and you won't notice.
datchew is offline   Reply With Quote
Old 01-07-2010, 06:21 PM   #17
Stagehand OP
Imperfectionist
Stagehand's Avatar
Oddometer: 26,993
OH CRAP YOU ARE RIGHT
the "take out your earplugs and discover the new noise" effect
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 01-07-2010, 06:22 PM   #18
Stagehand OP
Imperfectionist
Stagehand's Avatar
Oddometer: 26,993
Originally Posted by bgoodsoil
we're all so used to rigging stuff that actually buying the right part never even gets considered as an option
NO doubt I'll have to modify it to fit
Old 01-07-2010, 07:03 PM   #19
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
My play is the same too. Well, somewhat less due to the shortened lever I use
Not only that, both ball sockets are secured by pin locks which make it practically impossible for the ball to unseat itself from the socket.
Originally Posted by mark1305
BTW, this is the first bike I have ever seen with the shift linkage rod having right hand threads on both ends. Its nice in that it makes it impossible for the rod to unscrew itself and drop the center section on the road somewhere. But to adjust it one either has to disconnect one of the ball joints, or pull the shifter off the pivot and rotate the whole thing.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 01-08-2010, 08:10 AM   #20
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,082
I know what you mean and agree about the ball joint clips. Just for clarity, what I was referring to is other bikes I've had where the adjuster has right and left threads and works like a turnbuckle. I've seen it more than once on the track and amost had one on my Ducati unscrew itself after the lock nuts vibrated loose. Long enough between shifts, and suddenly the center link is disconnected or totally fallen off.
My ST can't do this because its right hand threaded at both ends - I presume its stock, unless a PO made up a new center link himself using two right hand ball joints. (I have found some other home-machine shop gadgets on this bike that have had to be "corrected", though.)
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 01-08-2010, 08:24 AM   #21
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
Yup, it is a good design by BMW (both right hand threads). The pins only secure the ball and socket union, nothing else
OCJ
92 R100GS-PD Euro
07 R1200GS
Old 01-08-2010, 10:19 AM   #22
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,549
The Germans were thinking when they put the pins in the design, it allows the joint to be serviced/ greased, some other bikes that have ball joint type linkage have a crimped fit on the ball and cant be serviced and as you know well the grease manages to go away over time and the socket wears, i had a bike with the crimped type wear and fall out of the socket on a trip 700 miles from home and i used 4 zip ties to hold the thing together till i made it back, had to buy a new linkage rod ends.
ChromeSux is online now   Reply With Quote
Old 01-08-2010, 04:06 PM   #23
Ricklesss
Ricklesssssssss
Ricklesss's Avatar
Oddometer: 148
Aren't those ball joints supposed to have rubber gaitors over them?
I could have sworn my 89 GS had them, and they dry rotted off, then when I went looking at fiches for them, I didn't see them...
Or am I imagining it? (it has been a while since I've looked into it)
RicklessssssssssS
Ricklessssssssss in Oregon
"Never ride faster than your guardian angel can fly."
"And no matter what, what ever you do, NEVER chase camels faster than your guardian angel can fly...
Ricklesss is offline   Reply With Quote
Old 01-08-2010, 04:31 PM   #24
opposedcyljunkie
Heavyweight Boxer
Oddometer: 4,776
Maybe you're referring to the earlier airheads which didn't have ball and socket linkage joints. AFAIK, they were the only ones which had a rubber gaiter. The later ones and the GS had a completely different ball-socket
linkage.
From my GS:
OCJ
92 R100GS-PD Euro
07 R1200GS
Times are GMT -7.   It's 07:09 PM.
