Old 01-06-2010, 07:59 PM   #16
zenben
all roads are one
zenben's Avatar
Oddometer: 595
Originally Posted by P B G
Be forewarned, in all likelihood, the special wrench is not going to get them off, if they haven't been loosened in however many years (20? 30?) There's a good chance they are stuck and will need to be destroyed in removal.
But there's always a chance you get them free, and from here on out you can crack them loose yearly and apply antisieze.
I wouldn't risk it. If you've never had them off, then cut them loose and buy two new ones at $30 each.
In a pinch, you can use the old ones you cut loose to install the new ones with either chain grip or channel grip pliers.
If you don't take this advise when removing the left one, then DO consider it on the right. They always seem to seize on the right side for some reason.
If you are exerting what seems like a lot of force to remove the collar, it is probably b/c you are ripping the threads off the cylinder head.
zenben is offline   Reply With Quote
Old 01-06-2010, 08:09 PM   #17
Grider Pirate
Grider Pirate's Avatar
Oddometer: 1,686
Won't fit older style exhaust nuts.
I bought this one, and it fits my '88 and '95 exhaust nuts fine. It WILL NOT fit the older exhaust nuts with bigger fins. I don't know what the changeover year was, but I know the /5 fins are too big.
Jim
Please don't tell Mom I'm a pilot. She thinks I play piano in a whorehouse.
http://griderpirate.smugmug.com/
http://www.youtube.com/my_videos?feature=mhum
Grider Pirate is offline   Reply With Quote
Old 01-06-2010, 08:16 PM   #18
SUVslayer OP
SUVslayer's Avatar
Oddometer: 883
I'll give it a try, keeping in mind DON'T FORCE IT. Either way, I'll need this tool for next year, so I might as well start there.
Jim
I should have noted, it's for my '93 GS.
SUVslayer is offline   Reply With Quote
Old 01-06-2010, 08:26 PM   #19
elmontanero
Practicing...
elmontanero's Avatar
Oddometer: 1,883
Went through the same set of worries on my G/s with pushrod seals, went with the above wrench. I read all about the heat gun.
Someone, Bless their soul, piped in to put the wrench in place with the lug in place and just start up the engine. I did, and the wrench nearly fell of it's own weight to loosen the nut. Before I could not budge the thing... Your results may vary of course, but you've got the bike right there and it knows how to get hot on it's own.
"And if we have food and covering, with these we shall be content."
elmontanero is offline   Reply With Quote
Old 01-06-2010, 08:47 PM   #20
SUVslayer OP
SUVslayer's Avatar
Oddometer: 883
That's funny. It's so obvious there's no way I would have thought of that.
Old 01-07-2010, 05:27 AM   #21
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 6,054
.... 'cept "in theory" you want the nuts to get hot faster, and expand more, than the threads.....
.... but then, nobody ever accused reality of knowing about theory.....
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 01-26-2010, 04:05 PM   #22
SUVslayer OP
SUVslayer's Avatar
Oddometer: 883
It's been a little hard to set time aside to work on this, but I'm finally getting into the meat of the matter.
I managed to borrow an exhaust wrench (thanks Mykill!!) but was unable to loosen the nuts. So I bit the bullet and cut them. I was lucky to find a replacement set in Long Beach for a mere $10 each, which seemed a DEAL.
I used a dremel, some files and a screw driver to get them off. And I didn't destroy the threads, despite my heavy handedness!
The offending matter that started all this:
Definitely time to clean things. This is the inside of the heads:
The dangly semi-snot is I think the old seal. Don't think it was doing much.
The push rod seals looked ok, but were rock hard.
So now I've got to clean things up. I've read a wire brush, and even a wire tip for the dremel will work. I'm just concerned about scratching things. Is brass better than steel? Any suggestions? Also, I generally use kerosene to clean things. Is this a reasonable solvant to clean the heads and cylinders, or should I use something else?
Another crummy SoCal sunset
Old 01-26-2010, 05:32 PM   #23
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,091
When the carbon has been loose and flaky, I've used the rounded end of one of those double-wide hacksaw blades to gently scrape off most of it. Then finish with a wire cup brush or a 3M abrasive wheel (the black sponge looking thingy). Trick is not to scratch anything.
Hardened deposts I've just gone straight to the cup brush or wire wheel and patiently polished it out. Be very careful to stay away from gasket or o-ring surfaces.
I've never decarboned a piston in the cylinder so as to avoid pushing carbon down between piston and cylinder wall. That's just me, though.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 01-26-2010, 06:24 PM   #24
SUVslayer OP
SUVslayer's Avatar
Oddometer: 883
Thanks Mark. I'll look into those.
Cylinders are off, so no cleaning pistons in the bores. I did notice while cleaning out the holes in the case where the push rod seals go some clear, stretchy O's... I would guess it was sealant, except they were such perfect bands (think thin, clear, circular rubber bands). I'll take some picks and post. Is there anything that goes on the push rod seals that would do this??
Old 01-26-2010, 06:26 PM   #25
SUVslayer OP
SUVslayer's Avatar
Oddometer: 883
Looking at the seals themselves, there are ridges on the part that goes into the case - that's what probably created the "rubber bands." What kind of sealant is used here?
Old 01-26-2010, 06:39 PM   #26
mark1305
mark1305's Avatar
Oddometer: 6,091
I've read of some folks using a small bit of RTV on new pushrod seals, and read from others not to. I haven't had to do that job yet on my ST - still only weeping enough to wipe off the oil film after every few rides.
Mark J
Merritt Island, FL
Old 01-26-2010, 06:45 PM   #27
danedg
Horizontally Opposed
Oddometer: 6,771
They really don't look that awful....you REALLY don't want to scratch or gouge 'em in any way...new gaskets and seals and button her back up...
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic, '78 Honda Hawk...... the Axles of Evil!
danedg is offline   Reply With Quote
Old 01-26-2010, 06:55 PM   #28
KhaoSanMan
Airhead
KhaoSanMan's Avatar
Oddometer: 605
A Question
After talking to my local mechanic, I am left with the question...
why take off the nuts every year to add anti-seize?
wouldn't this just add to the number of times that the threads could get boogered?
why not just wait until you NEED to take them off and deal with cutting them then?
I guess at 30$ each they are not cheap, and preventative maintenance is a good thing in that sense. I however, have yet to take them off once and therefore am wondering what's the point if I have to take a risk just to prevent exactly what I am risking?
KhaoSanMan is offline   Reply With Quote
Old 01-26-2010, 07:05 PM   #29
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,606
I guess if they don't come off easily, wait to take them off until you need to. Then once you replace the nuts that you had to cut off, remove and anti-seize them yearly so you never need to cut the new ones off.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 01-26-2010, 07:17 PM   #30
I GS 1
I 90S I
I GS 1's Avatar
Oddometer: 651
I agree. They do need anti-sieze but I wouldnt take them off unless I had to - you can get a bit of thread breaking away at any stage causing the problem. They are also not always a problem to get off. I recently found that with a heat gun I was able to get a pair off that had been in place for about 30 years (1975 R90S)
I GS 1 is offline   Reply With Quote
Times are GMT -7.   It's 09:31 PM.
