Old 01-27-2010, 06:29 AM   #31
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,475
Originally Posted by KhaoSanMan
After talking to my local mechanic, I am left with the question...
why take off the nuts every year to add anti-seize?
wouldn't this just add to the number of times that the threads could get boogered?
why not just wait until you NEED to take them off and deal with cutting them then?
I guess at 30$ each they are not cheap, and preventative maintenance is a good thing in that sense. I however, have yet to take them off once and therefore am wondering what's the point if I have to take a risk just to prevent exactly what I am risking?
Properly maintained threads don't get "boogered" by taking them off and on. Removing the exhaust is standard for lots of airhead maintenance including on some bikes, oil filter changes so just leaving them until you need to cut them off isn't a great idea. Frankly I think You have a greater chance of damaging things by trying to remove siezed nuts and cutting than you do by regularily taking them off, cleaning them and applying fresh anti sieze.
JT
www.northwoodsairheads.com
www.jefftrappwindsors.com
"Between two explanations, choose the clearest; between two forms,
the most elementary; between two expressions, the shortest."
Between two motorcycles the simplest (DW)
Eugeni d' Ors (1881-1954); Spanish writer.
jtwind is offline   Reply With Quote
Old 01-27-2010, 06:59 AM   #32
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,073
Big +1.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 01-27-2010, 07:21 AM   #33
caponerd
Kickstart Enthusiast
caponerd's Avatar
Oddometer: 1,980
Originally Posted by mark1305
Big +1.
Yep. Mine come off for every other oil change (when I do the filter), and I've been doing that for 10 years now.
You just have to be careful to avoid over tightening when dealing with aluminum threaded parts. They don't wear out by themselves.
caponerd is offline   Reply With Quote
Old 01-27-2010, 02:53 PM   #34
I GS 1
I 90S I
I GS 1's Avatar
Oddometer: 645
I must say that I would caution people against taking that as a general rule. While I would agree that “properly maintained” threads usually don’t get “boogered”, they still can and some do. Of course you have to take them off on some models for some maintenance items, but the question is what to do if you don’t. It is a high heat application and the anti-sieze has to stand up to this. Not much thread area needs to “weld/oxidise” together to cause it to be pulled away and cause a major problem when you unscrew it. (I agree that with a well used nut, there is less chance of a bit of manufacturing scwarf being around/loose to cause the problem and that anti-seize is pretty essential on a new nut for this reason – but the “weld” problem can occur in a relatively short space of time.) The other things we need to think about are that in some applications it is recommended that you only use a nut or bolt once to maintain it’s strength properties – generally tightening and loosening is not good for nuts and bolts (eg. I would say don’t ever re-use a spoke unless it’s only to get you home), and that with the type of tool most of us use for airhead exhaust flange nuts we don’t accurately measure torque each time we tighten them up so each time we subject the molecular structure to a different effect. IMHO for what it’s worth
I GS 1 is offline   Reply With Quote
Old 01-27-2010, 03:48 PM   #35
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,213
I think you're over-analyzing this. Truth of the matter is that having the threads clean and slippery, with anti-seize applied, they don't have problems.
Hey, you've got to remember who designed these things - GERMANS! They were meant to last! If anyone can engineer something, it's them. (don't pay any attention to those self retracting side stands...) And they were meant to be re-used... often.
Anyway, it's born out in practice, that clean, anti seized exh nuts don't weld on. And definitely don't over-torque them! Torque only enough to stop any leaks. I've seen them so tight that the clamp ring left a squished band around the header.
Once that happens, no amount of torque will stop them leaking. One of the manuals calls for an ungodly amount of torque on those things (as if you could measure the torque anyway), but it should only take a few light raps on the wrench with a rubber mallet once it's hand tight.
Old 01-27-2010, 04:01 PM   #36
Martian
Oddometer: 1,104
Hell, I loosen both of mine at each oil change and apply high-temp anti-sieze before retightening them. I use HPMGuy's beautiful wrench with a 6" long 3/8" extension stuck in it and just snug it up. I never had them leak or gall or sieze or exhibit any other negative behavior.
Tom
Tom
'93 R100R
'02 F650GS sold)
'93 R100GSPD(sold)
http://frommars.smugmug.com
Martian is offline   Reply With Quote
Old 01-28-2010, 07:31 PM   #37
SUVslayer OP
SUVslayer's Avatar
Oddometer: 836
Quick update, since not a lot's happened:
Took the pistons off, since I've decided to get the juggies beadblasted. I know I'd regret it if I didn't get all the gunk and carbon off before reassembly. Now I'm waiting for new rings, since why not? let's do rings too - although, I have to say the one's I've got look pretty good. I don't think this motor's been apart before, but everything looks pretty good, including valve seats.
Anyway, took some scotch brite to the headers since I was bored and they looked pretty chunky.
And now I'm looking at the carbies and feeling real guilty for neglecting them too...
C'est la vive. Another minor job becoming... not so minor.
SUVslayer is offline   Reply With Quote
Old 01-28-2010, 09:10 PM   #38
Wirespokes
Wirespokes's Avatar
Oddometer: 8,213
I wouldn't replace the rings either - they can be a pain to seat sometimes. And besides, they tend to last a 100,000 miles anyway. So why bother? They're just way too easy to replace when it's time.
Get some spray carb cleaner. Put them over a pan and spray a little bit, then what drips into the pan, grab with a tooth brush and scrub. It won't take long to have them sparkling. Carbs clean up pretty quick. And if the bike was running fine, don't worry about rebuilding them. Leave em be, just clean them.
Old 01-29-2010, 05:25 AM   #39
Jasper ST4
Guest
Oddometer: n/a
I have a wrench branded "New Age", made in Canada. I bought it at least 20 years ago and have no idea where I got it, probably some rally info. I bought one at the Beemer shop last summer and took it back, it left marks on my new purty exhaust nuts! The Canadian item is aluminum and never left a mark so I'll stick with it, I don't know if they still make them.
Absolutely, make loosening and redoing anti-seize part of the regular maintenance. I do it annually now, I lost some threads once and almost lost a set the last time I took the pipes off, but I prayed, cursed and finagled them off successfully. They had high temp anti-seize on them but years of riding takes its' toll.
Old 03-02-2010, 07:04 PM   #40
SUVslayer OP
SUVslayer's Avatar
Oddometer: 836
So, another update, at long last. Guess I'm hyjacking my own thread here.
Ended up getting the heads, cylinders and pistons bead blasted at Angel City Cycle. They came back so clean, they make the rest of the bike look filthy and scummy. I've spent as much time wiping old caked grease and oil off as I have actually fixing things.
As part of that, JR installed new rings for me. Getting the cylinders over them turned out to be a bigger booger than I anticipated, since I didn't have a ring compresser.
It took quite a few tries, some sore fingers and plenty of cheap Costco beer to get the damn things on, but finally I got my technique down and they slid home. I almost (almost!) wished I had more cylinders to hone my skilz, but screw that. Two's enough.
Cheap costco beer.
Then it was time for the heads and rocker arms. That should have been easy, except one of the rocker arms had a bad bearing. I bought new bearings, figuring I could just slide the old one out since there was no lip or anything. WRONG. More blood, sweat and tears trying to get the darn thing out. Finally, I came up with a home made bearing pull to squeeze them out:
Basically, a long bolt, coupla big washers and a 14mm socket which was tailer made to slide into the rocker arm and push the needle bearings out.
Once I got those out and new ones installed (I submitted and took it to a shop to press the bearings in) it was short work to install them and adjust the valves.
Then the valve covers and carbs and it started looking like a bike again.
More Costco beer:
Meanwhile, while I was waiting for bead blasting and such, I monkeyed with the neutral switch to fix its leaking. And broke it.
dumb dumb dumb
Another day down, had to get a new switch. Cleaned all the gunk from under the tranny and installed the new switch.
You might be wondering what all that orange stuff is. Well, it's high temp gasket sealer, added in extreme quantities. I'd replaced my oil pan gasket and somehow thought I needed more of the orange stuff than I did. That had to come off and be redone. This poor dumb bike, I'm really cutting my teeth on it.
Finally, assembled the exhaust, oil cooler, and crash bars, and suddenly - wow! it was pretty much all done.
Screwing on a replacement to an original offender, with anti-seize:
I also cleaned up the airbox and disconnected the plumbing that routes the crank case effluent into the carbs. A little absorbing material was fitted to the bottom of the box to collect any oil that drips out. Thoughts on this? It was a suggested mod, to help minimize carbon buildup in the cylinders.
Finally, today I took it out for a spin. One side seems louder than the other, I think I need to check valve clearances, but otherwise, it seems to run pretty good. I'm baby-stepping it around while things settle in, but I'm just amazed it didn't blow up on me.
After the maiden voyage:
Best part of all - the pushrod tube seals don't seem to be leaking! This blew me away.
Of course, all this took about 8 times longer than it should have. But now the bike's starting to come together. In recent months I've had the drive shaft rebuilt (well, that was a while ago), replaced final drive bearings, new top end, new steering head bearings, new throttle cables, cleaned the carbs, and had the Ohlins rear shock rebuit. I need to slap new brake shoes on, which I'll do in the next week or so. Good to go for the dual sport ride in Death Valley end of March!
Old 03-02-2010, 10:19 PM   #41
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
Great job!
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 03-03-2010, 12:03 PM   #42
Droptarotter
Oddometer: 1,285
The bike looks great.....but.....I am not so sure about the absorbent mat in the airbox?
Is it held down with anything? My concern is what are the chances of it being sucked into the motor?
That red silicone is a No-No on any engine parts. Just think......... as much excess you see on the outside......there is usually that much excess on the inside. That silicone sealant does not mix well with oil.....so the excess could be floating around in your engine......hopefully it does not clog up any oil ports.
In the future.......for engine sealant use something like Yamabond or I like Locktite 515......both are designed for this type of application.
I hope these suggestions help.........you bike looks great none the less.
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is offline   Reply With Quote
Old 03-03-2010, 12:16 PM   #43
SUVslayer OP
SUVslayer's Avatar
Oddometer: 836
Cheers
It's high temp silicone for engine gaskets, but after I tried it it just seemed wrong. I took the oil pan off and scraped the crap off. Live and learn. I'll use something different next time. I'll change the oil after 500 miles and see how it looks.
As for the mat, I've got it stuck down, but I share your concern. It's gonna be a work in progress, and I'll have to see how it acts. I'm not concerned about it falling apart - it's pretty tough stuff. But flopping around and blocking an intake tube is a potential problem.
Old 03-03-2010, 12:35 PM   #44
squish
Out of the office.
Oddometer: 6,319
Originally Posted by SUVslayer
Another crummy SoCal sunset
Where in SoCal are you at?
I'm in Peeeedro.
On vacation for a spell
squish is offline   Reply With Quote
Old 03-03-2010, 12:59 PM   #45
SUVslayer OP
SUVslayer's Avatar
Oddometer: 836
miracle mile
Times are GMT -7.   It's 12:29 AM.
