Old 07-03-2013, 07:31 AM   #946
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,427
Originally Posted by Gordy View Post
You really should set up a detail shop! The bike is looking great!!!
I'll bring more stickers to TP for him.
FYI, 4 days of riding on the 300 with the HC head now. I absolutely love the power! I short shift that thing all day long. I torque around most of the ST in 2nd and 3rd gear. Pulling onto a logging road : "brup..brup..brup..brup..brup..braaaaaaaaaaa....."
We don't stop riding because we get old, we get old because we stop riding.
"Wisdom is knowing what to do next, Skill is knowing how to do it, and Virtue is doing it"
HellSickle is offline   Reply With Quote
Old 07-03-2013, 08:46 AM   #947
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,121
Every couple years I treat the bike to a facelift, it helps keep the showroom envy in check
That's exactly how I ride it with the SX head, I also dropped the rear a tooth to 13/49 pulls it nicely with the extra torque. Lower Rs = less flywheel effect = better st manners
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 07-03-2013, 10:21 AM   #948
guns_equal_freedom
Oddometer: 5,550
I have an 11 300 XCW with the SXS head too.
Here are some tips (if you have not done them) -
Moto Tassini V4 reeds
Leave the power wire plugged in (the switch is useless)
FMF Gnarly pipe with the Q4 silencer (spark arrestor equipped)
JD Jet Kit (or the kit / settings of your choice)
Red spring installed
Back out the Spring Guide until it's flush with the case
I wish FMF made the Snap for the 11 XC-W.
Have fun!
guns_equal_freedom is offline   Reply With Quote
Old 07-03-2013, 10:47 AM   #949
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,427
Have fun!
Don't all of the newer bikes come stock with V4 reeds? My '06 had the stock reed supersceded with the V4. The '11 appears to already have the V4.
My '06 really benefited from the Gnarly pipe. With stock pipe & head, the '11 had better torque than the '06 with Gnarly. With SX head, I'm quite happy with the stock pipe.
Re: jetting, I'm content with the KTM jetting chart. The PO on my bike went way leaner and the bike ran horribly. Stock jetting is crisp and very forgiving of altitude changes.
Old 07-03-2013, 10:56 AM   #950
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,035
KTM jetting chart? Where is this chart you speak of????
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 07-03-2013, 12:47 PM   #951
big adv
I need supervision
big adv's Avatar
Oddometer: 1,072
Back of the owners manual.....but go to the jetting forum on KTMTalk. lots of good jetting info there. Can be a bit much, but if you read through it, you will find it all.
BA
My dad's a TV repair man, he has an awsome set of tools. We can fix that!
big adv is offline   Reply With Quote
Old 07-03-2013, 12:50 PM   #952
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,427
You can find all of the owners manuals online with jetting tables. If your engine is reasonably close to stock they work great.
Old 07-03-2013, 02:02 PM   #953
guns_equal_freedom
Oddometer: 5,550
2011 XC-W 300 came with the V3.
2012 and 13 come with the V4.
You can't compare an 06 bike with an 11 bike even if they are both orange.
You need to check out KTM Talk or ask your local expert Jeff Slavens if the Gnarly will help your low and mid range.
To each his own on jetting.
Have you played with the power wire?
The spring?
The adjuster?
There's a lot of power in the 300 you can adjust to suit your riding style.
Old 07-03-2013, 02:26 PM   #954
HellSickle
Scone Rider
HellSickle's Avatar
Oddometer: 9,427
The spring?
The adjuster?
Ahhh.... Just different versions of the V-force? I misunderstood.
I put on the power wire switch. You are right, I see little difference with the SX head.
My point on the Gnarly pipe is that I already have a ton of low and mid range power. I don't see the need to dump a bunch of $$ on a new pipe + pipe protector. Perhaps adjusting the power valve for a higher engagement point drives the need for better low end?
I've played a little with the spring and I'm pretty happy with the yellow one at a medium setting.
Your point on riding style is spot one. Specific settings that work well for one person may be horrible for someone else.
Old 07-03-2013, 02:47 PM   #955
Gordy
Team Listo
Gordy's Avatar
Oddometer: 22,746
I've got a '09 and running the Gnarly pipe, stealth muffler, JD jetting, stock head, V4 reeds and (I think) 2 teeth more on the sprocket.
My bike has a ton of low end and I don't dink with the jetting at all from 5,000ft to high mountains of CO. I know I could maybe get it a bit cleaner running if I did, but why? It honestly runs great just about anywhere in any conditions.
I just need to ride it more lately.
Gordy is offline   Reply With Quote
Old 07-03-2013, 04:14 PM   #956
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,121
I've done all those mods except the V4, waiting on my V3 reeds to need replacement first, they're close. Switch is a waste of time, I never use the low setting unless I bump it. I prefer the stock pipe better than the knarly also, we ride enough desert that I don't want to loose the overrev. Stock pipe pulls a bit longer and I shift less out there. With the head I'm not lacking for any lowend, I actually like the way the gearing change tames it a little on the bottom. As for the springs, I have 2 settings, Green/2 turns in for extremly knarly 5moh kinda stuff. Red/flush for more open riding like the dez where I want to be on the pipe more.
Chris
Old 07-03-2013, 08:10 PM   #957
Gordy
Team Listo
Gordy's Avatar
Oddometer: 22,746
I can't even tell you which PV spring I have or where it's set! It's been the same for TorC/Socorro dez, 5 MOH, Moab, Sipapu, Southern, Jemez, Taylor Park, etc. Jetting too!
My bike rawks!!!!
Old 07-03-2013, 10:14 PM   #958
Joe Watson
Joe Watson's Avatar
Oddometer: 1,031
hhahaha I am the same too with my 300. I bought it the way it is now and don't intend to change it power wis!
Joe Watson is offline   Reply With Quote
Old 07-06-2013, 02:41 AM   #959
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
Just got a new to me 2010. First 2 stroke I have have since 2001.
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 07-06-2013, 10:26 AM   #960
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
Its a Two stroke nation.
"Hes not called the Angry White Man for nothing,much more fitting then the,Unicorn Clouds and Happy Trees Man".... UpST8
Theres a name for people without beards,"Women".
AWM is offline   Reply With Quote
Times are GMT -7.   It's 09:36 PM.
