Old 01-20-2010, 09:52 AM   #31
NEVERLOST
NEVERLOST's Avatar
Oddometer: 949
real world question
Does having ABS reduce insurance cost on a MC?
If yes, then I think it may be mandatory
NEVERLOST is offline   Reply With Quote
Old 01-20-2010, 10:04 AM   #32
vsnqust
Oddometer: 39
Laugh Off road forgetting abs
I have abs on my f800gs.. and I must admit I have had some close calls
when I forgot to turn it off going into the dirt from the tarmac... I just read the way to pull the seat and unplug it.. I did not know about this.. but I wish
there was a way on the bike to toggle the setting so I could put abs on when
wanted versus having it on all the time and having to switch it off... So if you get abs try and remember to turn it off.. I forget all the time!! Though having it on the tarmac is great!!
vsnqust is online now   Reply With Quote
Old 01-21-2010, 12:54 PM   #33
NEVERLOST
NEVERLOST's Avatar
Oddometer: 949
great checklist
i also check oil, tires, blinkers headlight
Old 01-21-2010, 04:08 PM   #34
biker128pedal
Super Lurker
biker128pedal's Avatar
Oddometer: 3,125
Not with State Farm. But glad I have it even though I don't think it has saved my but YET.
Wee Strommin along.
biker128pedal is offline   Reply With Quote
Old 01-22-2010, 06:47 AM   #35
3rdGear
3rdGear's Avatar
Oddometer: 50
25 years of riding without ABS, F800 is my first with it. Have noticed it kick in a couple times that I would have more than likely laid the bike down. On a 460+ pound bike, it's a fine feature. Worth every penny.
3rdGear is offline   Reply With Quote
Old 01-22-2010, 12:05 PM   #36
Rick West
Function not Farkles
Oddometer: 1,222
25 years of riding without ABS and you were ok. Then get an bike with ABS and twice you would have more than likely laid it down without the ABS.
Have you changed your riding style because of the ABS?
KTM 990 - The only real "dual" sport in the big Adventure bike class
Rick West is offline   Reply With Quote
Old 01-22-2010, 01:27 PM   #37
Motoriley
Even my posing is virtual
Motoriley's Avatar
Oddometer: 2,685
A BS story
He never said he hadn't crashed in 25 years......
04 Toyota Sienna, new wipers for 2011!!
Electricity (120 AC), Indoor Plumbing, new kitchen tap for 2010!!!
Color tube TV, Microwave Oven (yes she rotates!),Washer & Dryer,Paved Driveway,
Website - http://www.apormc.com/
Vids - http://www.youtube.com/user/Motoriley?feature=mhum
Motoriley is offline   Reply With Quote
Old 01-25-2010, 01:12 PM   #38
lawe
lawe
Oddometer: 141
I defenitely think that the 800 should be bought with ABS.
But at the same time I must say I'm not 100% satisified with the feel of the ABS on my 800. I actually like the ABS on my 650GS thumper better. I allways has knobbies mounted and I think the ABS on the 800 don't really like those tires. Even on dry tarmac I stop the bike faster/shorter without ABS. But in real life You do not have the same control as during a controlled test and then I think the ABS pays off.
To all of You who want's to disable the ABS for You dirt weekends it's just to unattach the connector/plug under the seat. I allways do this since otherwise I often forget to switch the ABS off after a break.
Lars
Umeň, Sweden
BMW F650GS -05, F800GS -08
lawe is offline   Reply With Quote
Old 01-25-2010, 01:27 PM   #39
B-B
Oddometer: 156
I think of ABS the same as I think of my pistol.
Better to have it and not need it then need it and not have it.
B-B is offline   Reply With Quote
Old 01-25-2010, 03:16 PM   #40
Motoriley
Motoriley's Avatar
Oddometer: 2,685
Abs
I've heard that a skilled marksman can fire a bullet a shorter distance without a pistol......
Old 03-13-2010, 09:28 AM   #41
motojc
Oddometer: 32
I don't have a GS yet, but have ABS on my Xmoto, it give me confidence in the rain (by knowing it would), even though I only felt it in action once in an emergency situation (on dry). But I found it causing more troubles on dry. Like the current recall on Toyotas, I found it refuse to engage in a combination of situations: bumps, too much weight transferring to the front, once or twice leaning. It would either click click, or worse, can't pull the lever in. And most of the time I experience these were times I really needed the brakes. Imagine following a car onto a bumpy stretch of the road, he slows down but you can't, happens alot here on the bad streets of NYC...
So I guess it's not a fool proof switch, you still have to use caution to compensate. The only time braking really saved my life, I was on a non ABS bike and I braked so hard the back came up we stopped a hair to her bumper. The only time I actually went down was in the rain on my ABS bike cause I felt confident (low sided in a corner, not ABS's fault).
motojc is offline   Reply With Quote
Old 03-13-2010, 09:36 AM   #42
Motoriley
Motoriley's Avatar
Oddometer: 2,685
Abs
Was riding a rental for a week without ABS. Sure missed it when the roads got wet and slippery. Had a near panic stop and when I grabbed a handful of front brake it locked momentarily.....
When I get the occasional activation when braking over a bump it has never bothered me. I can brake so much harder with more confidence that I'm still stopping sooner.
Old 03-13-2010, 11:03 AM   #43
HMarc
Hoseur
HMarc's Avatar
Oddometer: 264
Read this article, written almost 20 years ago when ABS systems were not nearly so sophisticated as they are today:
http://www.ibmwr.org/prodreview/abstests.html
Then buy an F800GS with ABS.
You can always turn it off when you don't want it.
I've had bikes with ABS since 1992 or so (starting with a Yamaha GTS1000A) and ride quite a lot. The only time I've had the ABS kick in unexpectedly was on some wet cobblestones in a village in the Italian Alps in a rainstorm. So that's just once in 18 years.
But I love knowing that should some brain-dead cager run a red light as I'm about to enter the intersection, I can just hammer the brakes and use the majority of my attention trying to figure out what other options I have...
HMarc
HMarc is offline   Reply With Quote
Old 03-13-2010, 01:23 PM   #44
Mike.C
Stelvio Dreamer!
Mike.C's Avatar
Oddometer: 592
No need to muck around with wires to disable it for a days dirty activites. You can change the startup default to off by starting the bike with the button pressed, the default startup ABS off/on will then be the reverse of what it was before.
See this thread http://www.advrider.com/forums/showthread.php?t=552509
Cheers, Mike
Don't just look at it - Ride the bloody thing!
Mike.C is offline   Reply With Quote
Old 03-13-2010, 03:06 PM   #45
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
I tried that trick the last time I rode off road. Didn't work for me, no matter how many times I tried, nor how many variations on that theme I attempted. Every time I switched off the ignition, the next time I switched it on the ABS was in the standard default mode.
David
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks is offline   Reply With Quote
Times are GMT -7.   It's 03:42 PM.
