Old 01-15-2010, 03:13 PM   #1
rwiles OP
Oddometer: 81
HELP ! Airhead GSPD Paralever Fairing R&R
RE: A previous post about a fogged-up headlight shell, I might need to remove the front fairing from my 1994 R100GSPD. Anyone know how? Anyone done it? Is it a bitch?
One of my manuals says that the fairing comes off intact, and is then worked on and serviced upside down on a bench (guages, dash-bulbs, etc) and to unbolt the Roo bars from the frame (downtubes), and then take out the big mutha allen capscrew in the middle bottom front of the Roo bar, and lift it off. Two-man job. The manual says that the harness(s?) disconnect from each other. Izzat so? Is it a bitch?
Does one remove it intact? Or disassemble it piecemeal off the bike. It doesn't appear that is possible.
Of course, the speedo cable has to be undone, and that is a bitch in itself.
Any other issues? Better ways?
rwiles is offline   Reply With Quote
Old 01-15-2010, 03:54 PM   #2
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,051
You can pull the wind screen, unbolt the turn signal, remove the screws and take of the side fairing seperately and leave the center section of the fairing... access to the headlamp shell will still be difficult, but that may be an easier way to tackle this job.
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 01-15-2010, 03:59 PM   #3
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,287
Start cursing now; maybe you'll finish by the time the bike is back together.
Old 01-15-2010, 04:09 PM   #4
jackd
Oddometer: 3,055
I did my headlight removal ('94 R100GS) without reading the book so I am going to ignore their suggestions and give you my two bits. I've been in this area several times and this is what I do. You might get away with only pulling the side fairings off and leaving the center faring in place - no Roo bar removal required. Undo the tach cable on the L/H side as that is now right in front of you - be careful because the fitting on the back of the tach is plastic. Undo the knurled hold down nuts for the speedo & tach and remove them completely. You should now be looking at the back of your headlight through the holes formerly occupied by your gauges.
The headlight frame is a two piece affair and is somewhat delicate. The forward part is a frame mounted to the fairing/Roo bar. The headlight bulb is attached to a rear frame which is mounted to the front frame by two delicate adjustment assemblies (one for up/down, another for left/right). These adjustment assemblies break easily (I was in there initially because one of mine was broken and a P/O had bodged a repair). I would not try to split this rear frame from the front frame in situ because you might break it. I would remove the bolts holding the front frame from the fairing/Roo bar and take it out as a complete assembly. All in all, an tedious job and I am a mechanic by trade.
When you have the headlight assembly out on the bench, give the adjustment mechanisms a look over for wear/damage. Now is the time to replace the bits that break - BMW sells them still. Some guys put the springs on the headlight adjustment screws, but I chose to cut them in half before I installed them because I figured they were putting too much strain on the delicate mechanicsms. So far no problems. Just take your time and this can all be done in a few hours. I hope that this isn't too muddled.
Old 01-15-2010, 06:07 PM   #5
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
I chose to remove the lower left spring because the headlight won't point down as much with a spring even when fully-compressed. What a PITA to go through the fairing twice!
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 01-16-2010, 02:32 PM   #6
Toyanvil
Toyanvil's Avatar
Oddometer: 1,690
http://www.advrider.com/forums/showthread.php?t=541946
2004 BMW 1150 GS-1993 BMW R100GSPD-2009 Yamaha TW200 1961 Sunbeam Alpine.
Life is like riding a bicycle, to keep your balance you must keep moving.
Some people try to turn back their odometers. Not me, I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. Hell, some of the places I’ve been there weren’t even roads!
Toyanvil is offline   Reply With Quote
Old 01-16-2010, 09:00 PM   #7
Grider Pirate
Grider Pirate's Avatar
Oddometer: 1,686
I ran through every curseword and phrase I ever knew a dozen times while changing ONE bulb in the intsrument panel!! A pure f'ing joy to work on!
Please don't tell Mom I'm a pilot. She thinks I play piano in a whorehouse.
http://griderpirate.smugmug.com/
http://www.youtube.com/my_videos?feature=mhum
Grider Pirate is offline   Reply With Quote
Times are GMT -7.   It's 03:51 AM.
