Old 04-30-2013, 01:45 PM   #616
endurists
endurists's Avatar
Oddometer: 60
[QUOTE=antonrally;21278448]Hello, from Russia
Just get my used one 2007 690 RFR and already test it in Russian desert rally Золото Кагана ( The gold of Kaganat)
/QUOTE]
Hi Anton, finally You got KTM
Just saw interview with You few months ago in russian magazine MOTO, You had light jacket and pants with KTM logo, but riding Honda Mecasystem bike.
Greetings from You neighbours - Latvia
As I know we have two 690RR here in LV
something unusual in woods
endurists is offline   Reply With Quote
Old 05-02-2013, 01:26 AM   #617
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,839
Ive got the fuel line windows on my tanks as well - question is can anyone else actually see the fuel level in their tanks? I can see anything different full, 1/2 full or empty!!!
Yellow suits the bike...
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 05-02-2013, 12:48 PM   #618
690RR
Location: Norway or some exotic country with a lot of sand
Oddometer: 109
Looks like you folks here been busy past few months :)
I finally broke the riddle of my different frame. According to lads from Mattighofen, there were only 2 prototypes of this frame. To me it looks like the second ended with Gerduro in Australia, but unconfirmed.
The frame is slightly shorter, softer in middle part of the frame due lack of one rib and lighter tubing, but a lot stiffer in head part. Different airbox position, lot more air for breathing due significally bigger breather hole over front part of air filter.
It was designed for Baja project, but never used there.
Btw, I know where is one complete Baja kit - fuel tank, wings, exhaust, etc.. Marc's mechanic have one, but refuses to sell, which I completely understand :)
690RR is offline   Reply With Quote
Old 05-02-2013, 12:54 PM   #619
Kirill Shubin
Oddometer: 16
Talking
Originally Posted by antonrally View Post
Hello, from Russia
It is a very powerful bike, easy to drive in sand dunes, but hard to pick up in sand if I drop it :)
I have to many questions about it, and hope to find answers here. Thank you.
Sorry for my English.
Great bike!
How about test drive? :)
Kirill Shubin is offline   Reply With Quote
Old 05-10-2013, 03:02 AM   #620
johnno950
Oddometer: 1,076
What rear shock is that?,resivoir on my bike is above high/low adjustment assembly,also what is that fitting (number 2 photo) behind cyclinder head hanging down in front of tank mount?
johnno950 is offline   Reply With Quote
Old 05-10-2013, 06:55 AM   #621
690RR
Oddometer: 109
The reservoir is turned because of 450 RR rear tank. Otherwise it is 690's Factory Trax.
The fitting is quick coupling for oil cooler hoses. Banjo bolts are difficult to access on 690 engine when changing engine.
Old 05-10-2013, 09:49 AM   #622
NovaMoto
Oddometer: 133
Beautiful machine, 690RR, absolutely beautiful.
NovaMoto is offline   Reply With Quote
Old 05-12-2013, 05:03 AM   #623
Evil Invader
Evil Invader's Avatar
Oddometer: 697
Fronttanks material
Ok, I've searched this thread and various others with no luck....
Busted one of my front tanks (450 rally ones) in the Hellas rally, and need to know what type of plastic they're made of. It's just a small crack, so hopefully I can just "weld" it together with some plastic weld...
Thanks for any help!
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813
M Motoadventures
Evil Invader is online now   Reply With Quote
Old 05-13-2013, 06:35 AM   #624
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,734
Gold foil airbox...guess that explains the price tag on these things
Seth S
Seth S is online now   Reply With Quote
Old 05-16-2013, 06:12 PM   #625
F650Dakar_Norway OP
What off-season?
F650Dakar_Norway's Avatar
Oddometer: 960
That's heat-reflective foil to keep engine heat at bay from air intake.
Most likely getting a 15mph speed advantage, and making bike the non-crashable ;-)
Norway
Current stable:
2010 BMW F800GS
2008 KTM 690 RFR
1994 Honda ST1100
F650Dakar_Norway is offline   Reply With Quote
Old 05-20-2013, 04:16 AM   #626
johnno950
Oddometer: 1,076
Question for 690rr
With the oil cooler,if it gets damaged and leaks can you plug the 2 banjo fittings on the engine caseings?,or do you require a bridge/loop line between the two oil galleries on the engine for oil flow.
Old 06-01-2013, 05:43 PM   #627
Pilbara
In the flow...
Pilbara's Avatar
Oddometer: 1,579
Should my frame look like this? :)
Pilbara is offline   Reply With Quote
Old 06-01-2013, 06:41 PM   #628
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,839
Any closer to fitting the 450 tank???
Pete
Old 06-01-2013, 11:06 PM   #629
Pilbara
In the flow...
Pilbara's Avatar
Oddometer: 1,579
Will be closer to being able to soon. Just got to wait for one at the right price.
Cheers
Pilbara
Old 07-16-2013, 03:55 AM   #630
Gerduro
Oddometer: 23
hi 690rr
yes i have also a different frame on my 690rr. Besides what you mention the the rear shock is mounted differently than on standard. how come the 450 rear tank fits in our mount, it does not look modified ???
Cheers
Gerduro is offline   Reply With Quote
Times are GMT -7.   It's 02:22 PM.
