Old 01-26-2012, 09:57 PM   #151
taco jeff
DR650
Oddometer: 17
Nice!
I'm thinking of doing the 312 set up to my 1981 TT 250. Did the bigger valves work with the original valve seats? But, there is no replacement for displacement!
taco jeff is offline   Reply With Quote
Old 01-27-2012, 10:45 AM   #152
oc_nightmare OP
Oddometer: 188
yes mate, just machine the stock seats and you're on :)
two things i should have tried aswell were a nice camshaft regrind and another carb but maybe next time :)
oc_nightmare is offline   Reply With Quote
Old 01-28-2012, 10:44 AM   #153
taco jeff
DR650
Oddometer: 17
Thanks for the info about the valves and also the great build thread. I race my TT in the vintage motocross series and want to hot rod it.I also know of a XT 600 for sale cheap and like the looks of your"big block" SR! I do like the light weight of my TT so I just might keep it small. Did you use a stock base gasket when you did the top end on the 312? I have a great local cam company and I think more lift in the middle would be nice. More duration might let the valves kiss the piston with a thin head gasket...
Old 01-29-2012, 10:39 AM   #154
oc_nightmare OP
Oddometer: 188
yes, with a thin gasket and bigger valves you might have that problem but if so, you just have to machine the piston a little for extra gap between the valves and the piston. more duration would be great because it is still a 2 valve head and more flow would have a nice effect on the peak horse power i think :)
yes, the stock base gasket and o-ring are fine with the bigger sleeve, no problem there just beware of the copper head gasket thats too thin, mine leaked a little...
Old 07-31-2012, 06:55 PM   #155
oc_nightmare OP
Oddometer: 188
Yes it wasn't finished yet
TRX850 front suspension with 295mm rotor
Made a new oil tank
Corrected the chain offset
that's all for now
Old 08-04-2012, 06:39 PM   #156
oc_nightmare OP
Oddometer: 188
Old 08-05-2012, 01:51 PM   #157
nanno
Oddometer: 273
Nice welding!
Let the world change you and you can change the world - Che Guevara
nanno is offline   Reply With Quote
Old 08-10-2012, 03:22 PM   #158
oc_nightmare OP
Oddometer: 188
Thanks nanno :)
A couple of updated photos
preview
Old 09-24-2012, 04:35 PM   #159
regal7point5
Oddometer: 2
Project is looking good!!!
I sent a message on one of your youtube videos, but not sure how often you check in on them and figured this was a better place to post. Also might help some others contemplating this. My question is about the 312. Did you use a stock SR250 cylinder and resleeve it, or did you use a YFM350 cylinder? Can you put a YFM350 sleeve in a SR250 cylinder?? I am somewhat confused
regal7point5 is offline   Reply With Quote
Old 09-25-2012, 02:00 AM   #160
oc_nightmare OP
Oddometer: 188
Hi there mate, I already replied to your message on the youtube video but to answer your question, I used the SR250 cylinder bored to fit a custom sleeve. Beware though, the sleeve is only going to end with a 1,5mm wall and the cylinder wall will be paper thick, your machinist has to be really good not to cut through the alluminium.I don't see the need to use an YFM sleeve because it has to be machined on height and thickness, so a custom sleeve is cheaper, I reckon. The Cases were bored aswell
Here go some updated photos
the custom seat i made
cleaning the shed afterwards
the SR resting in the shed
my girlfriend testriding the SR
I guess that's all for now, I've ordered a new 39T rear sprocket because this one with 45T is waaaaayyyy too short. Going to paint the gas tank soon but don't know yet what colour will it be though
Old 11-23-2012, 04:15 AM   #161
oc_nightmare OP
Oddometer: 188
There ya go, all finished (for now). The fuel tank just had a small coating of metal varnish because I love the color of the steel and it was the cheapest option
My girlfriend aproved it as always
Old 02-17-2013, 02:51 PM   #162
regal7point5
Oddometer: 2
The bike is looking good! I missed out on a deal of a XT600 just last week...darn!
One more question on the SR312...did you use the YFM350 valvesprings too, or just reuse the stock SR250 springs? Not sure if one is better/stronger/different than the other.
I am slowly gathering parts and should be getting some real work done on mine soon!
Old 02-17-2013, 05:40 PM   #163
oc_nightmare OP
Oddometer: 188
I thought about the valve springs when I did the engine and assumed that because the warrior's not a revy engine, the valvesprings would be about the same compared to the stock SR ones.
I'm doing a welding certification (P24 steel this time) and haven't been home in a long time and now I really miss my big thumper
When I start earning some money, I'm going to redo the whole frame again (make space for an airbox and make a craddle) like I really mean it, stay tuned
Old 07-29-2013, 06:10 PM   #164
Bvander
Bvander's Avatar
Oddometer: 4
Nice work on the bike mate. It has been a bit of a guide for me to start planning some mods to mine. Thought I would sign up and say thanks for the info.
I am planning to stick a 83mm piston in which will give a 305cc displacement. I was wondering if you had to bore out your case to fit the 84mm piston in?
Bvander is offline   Reply With Quote
Old 07-29-2013, 06:29 PM   #165
Valleyrider
I Survived The '60s
Valleyrider's Avatar
Oddometer: 1,852
Very nicely done!!
http://www.flickr.com/photos/14934865@N07/
'07 1250 Bandit, '06 650 VStrom, '78 SR500E
'68 Yamaha DT1, '78 TT500 and no money
http://www.flickr.com/photos/48000856@N06/
Valleyrider is offline   Reply With Quote
Times are GMT -7.   It's 07:51 PM.
