Old 11-02-2010, 06:07 PM   #76
oc_nightmare OP
Oddometer: 188
I think i found the answer to the power issue
found a pic of the side of a XT/TT600, cut the engine and carefully placed it on the SR312 photo and well... it looks like the mounts are pretty much alike (if not the same). How hard can it be?
the Dual Sport SR600 project will start soon
oc_nightmare is offline   Reply With Quote
Old 11-02-2010, 07:39 PM   #77
crawler07
Oddometer: 60
Thats a cool bike! You have done some worthy mods for sure!I like your tool for removing the rocker arm pivots, I always used a slide hammer and a bolt that fit the end ,but what ever it takes! Cant wait to see whats next,
crawler07 is offline   Reply With Quote
Old 11-04-2010, 01:18 AM   #78
boingk
boingk's Avatar
Oddometer: 431
You've cut the top off of the engine - the cam housing projects a lot further up and will stop you from mounting the engine. Besides, I would not recommend that you put a 600cc engine into a very sedate 250cc frame.
I believe a cheap way to get a bit more power would be to advance the ignition a few degrees more. This is easily doable if its points, otherwise you'd need to go aftermarket.
A *real* solution to the power problem is to simply get a more powerful bike.
- boingk
'90 XR600R, '00 VTR1000F
boingk is offline   Reply With Quote
Old 11-04-2010, 07:42 PM   #79
oc_nightmare OP
Oddometer: 188
Oh well, i guess youre right, but on the other hand... could one make a XT600 look like a CL or like a Scrambler? Has someone done anything like that?
Old 11-21-2010, 06:39 PM   #80
oc_nightmare OP
Oddometer: 188
I guess, the engine is going to stay as it is now as im thinking on buying a road bike and keep this one as a scrambler. Today i introduced the wet mud to the SR312...
Carefull!
Now i see why the trail bikes have high mudguards, it is not cool at all to be on the sticky stuff with a locked front wheel!
Each step i did, there were arround 2 tons of clay in each of my boots!
after a lot of sweat and almost as a last attempt, i finally got out of the sticky stuff with the locked front wheel
On the last photo my hands were shivering because i was pretty much on my resistance limit
To add to that, soon after it started to rain, however the feeling that i was able to get out of there all by myself put a grin in my face for the rest of the day
Old 12-29-2010, 04:25 PM   #81
oc_nightmare OP
Oddometer: 188
- boingk
I guess it really is happening, im negociating a XT600Z engine for it... well, i'm crazy, but i promise that the frame is going to be veery reinforced to be able to cope with the 600cc engine and the suspension is going to be upgraded aswell. In order to keep my Zephyr 750 full stock, i have to direct my crazyness to the SR
More updates soon
Old 12-31-2010, 06:07 AM   #82
oc_nightmare OP
Oddometer: 188
Last ride of the year
I was suprised to see how deep the bike could go without dying, even without airbox
Happy new year, guys
Old 12-31-2010, 11:04 AM   #83
DCopp
Oddometer: 160
awesome thread!
DCopp is offline   Reply With Quote
Old 01-09-2011, 05:02 PM   #84
oc_nightmare OP
Oddometer: 188
Just picked this baby up
Old 01-13-2011, 06:17 PM   #85
oc_nightmare OP
Oddometer: 188
Today:
Had to go to work and couldnt do any real measuring but the engine mounts look very similar
Old 01-14-2011, 09:22 AM   #86
oc_nightmare OP
Oddometer: 188
Bit bigger than the stock one but i think it fits
Old 01-14-2011, 09:34 AM   #87
Brunow - 007
Bantam Fever
Brunow - 007's Avatar
Oddometer: 313
Good luck with the brake's
Working on the D14/4 Bsa Daily Driver .
Brunow - 007 is offline   Reply With Quote
Old 01-15-2011, 03:24 PM   #88
vander
full-time dreamer
vander's Avatar
Oddometer: 918
Very nice bike. I have been dreaming with the SR250 for some time with the purpose of building a scrambler.
I really like your bike!
You could try with longer suspension on the rear. Watch this from the spanish SR forum.
http://foroyamahasr.foroactivo.net/t...ambler-rodando
The shocks are made in Barcelona by BETOR.
http://betorspain.com/osc/index.php?...sort=2a&page=3
My idea was to make a replica (not exactly but inspired by) of the Minsk 125, so popular in Vietnam.
XTZ
vander is offline   Reply With Quote
Old 01-16-2011, 09:13 AM   #89
Highside>Lowside
Hairier Than Thou
Highside>Lowside's Avatar
Oddometer: 1,077
Keep in mind that the engine you are swapping in has much more power than the chassis was designed to handle.
Better use two bungees.
00 M944,95 620RXC,82 FT500,85 V65 Sabre,01 1150GS,82 XJ650r,91 XV920r,82 V50 Monza,77 TT500, R75/6, etc...
Highside>Lowside is offline   Reply With Quote
Old 01-16-2011, 11:06 AM   #90
brucifer
brucifer's Avatar
Oddometer: 2,557
If you do manage to cram that 600 engine in there, have you given any thought to where you'll put the external oil tank? What about the dual-carbs and air box assembly?
2014.5 Kawasaki KLR650 NE-2002 Kawasaki KLX300R-2002 Husky TE570-2001 Husaberg FE650E-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is offline   Reply With Quote
Times are GMT -7.   It's 10:38 AM.
