01-16-2011, 03:19 PM
#91 | |
Oddometer: 186
![]() Hell yeah Highside! ![]() Vander, with a bigger rear wheel that SR would be perfect Nice shocks, didn't know that brand though, im going to think about it. Could use a fork upgrade aswell... it is good with this engine but with the extra weight of the 600 it is going to be too soft The same goes to the brakes aswell xD
01-18-2011, 12:17 PM
#92 |
Oddometer: 186
Bit tight, but with some effort it is almost there:
![]() ![]() Could anyone tell me if it is possible to run the XT600Z engine with the SR250 electric system or it would be better to get the cdi, voltage regulator, yada yada yada from the XTZ? I already have the wiring harness of the Tenere but those things are missing... Cheers
01-25-2011, 05:25 PM
#93 |
Oddometer: 186
Today:
![]() between the cuts will be the lower back engine mount for the 600Z ![]() almost there! ![]() how the bike is now ![]() it fits on the other side, but major changes will be needed to make it fit on this side too ![]() thats all for now
01-26-2011, 12:48 PM
#94 |
Oddometer: 505
yer crazy......
![]() in a good way, of course!
SRX600 SRX250 SR500 KLR650 |
01-27-2011, 11:06 AM
#95 |
Nice thinking outside of the box!
Let the world change you and you can change the world - Che Guevara |
01-28-2011, 03:33 AM
#96 |
Oddometer: 186
thanks guys!
main engine mount solved and aligned ![]() ![]() ![]() already i have the final looks in my head ![]() hell yeahhhh
01-28-2011, 06:08 PM
#97 |
Oddometer: 186
T'day;
perfect fit! ![]() the 600Z engine is a little bit shorter than the 250 because of the location of the starter motor ![]() my gf showing the new silencer position ![]() transmission offset is reduced to 1cm with the engine 1cm more to the right side, i'll try to balance it with the heavy stuff moved to the left side of the bike ![]() another problem, the front sprocket is welded to the nut ![]() thats all for today
02-02-2011, 10:41 PM
#98 |
Paint it black.
Oddometer: 12,861
I like your determination!!! Thanks for the link to your hot rod SR600.
02-04-2011, 09:35 AM
#99 |
2 squeaky wheels
Oddometer: 609
02-16-2011, 04:42 AM
#100 |
Oddometer: 186
Thanks, i already had seen that cafe racer :)
After hours and hours looking for rear shocks, i ended up ordering twin XT500 Wilbers with 365mm lenght and 105mm stroke ![]() Any ideas about the front forks? Taking care of the lower engine mount ![]() The main mount is ready with the bushings back from the shop ![]() Mounted with only one mount and it already stands stil ![]()
02-19-2011, 08:07 PM
#101 | |
Oddometer: 376
02-20-2011, 05:56 AM
#102 |
Oddometer: 186
Double craddle frame?
![]() ![]() mmmm, clean steel some minor modifications to the tubes and it is almost plug&play... gonna be using both front mounts for the tubes, of course :) |
02-25-2011, 03:29 PM
#103 |
Oddometer: 186
Upper engine mount
![]() XT500 replacement rear shocks (damn she's starting to look hot!) ![]() more stuff arrived today... kick starter shaft and 3aj rectifier ![]()
02-25-2011, 04:55 PM
#104 |
Oddometer: 1,623
Looking good, man!
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F |
02-26-2011, 04:40 AM
#105 |
Oddometer: 186
The hard part will be to make it all work
