Old 01-18-2010, 07:04 PM   #1
A.Vern OP
One Man Wolf Pack
A.Vern's Avatar
Oddometer: 974
What's the best Tire Iron?
I need a set for home and for when $#@! happens on the road...
How these look for 30 bucks? 8 1/2", 11" and 16"
http://www.motorcycle-superstore.com...px?sst=RR|4456
A.Vern is offline   Reply With Quote
Old 01-18-2010, 07:07 PM   #2
Cumminsman76
befuddled
Cumminsman76's Avatar
Oddometer: 8,575
Have you seen the ones that double as wrenches?
STURGIS ride report.
2009 R1200 Gelände/Straße Abenteuer
A GS is like chlamydia, it grows on you whether you want it to or not. WhiteManFlail
Save $5 on Smugmug "1alkVgTNLEuyQ"
Cumminsman76 is offline   Reply With Quote
Old 01-18-2010, 08:12 PM   #3
peterman
cop magnet
peterman's Avatar
Oddometer: 13,464
Usually, the ones I left at home when I "find" a flat tire,,
I like my Motion Pro irons, longer is better if yer old and weak.
peterman
___________________________
"Your God, your rules,,YOU go burn in hell!" LLV
peterman is offline   Reply With Quote
Old 01-18-2010, 08:30 PM   #4
tricepilot
El Gran Payaso
tricepilot's Avatar
Oddometer: 8,558
Motion Pro
4 of these (come in pairs of two):
Plus this
Along with this:
Then call it a day
tricepilot is offline   Reply With Quote
Old 01-18-2010, 08:41 PM   #5
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,569
I use three of these.
Flashmo is offline   Reply With Quote
Old 01-18-2010, 09:26 PM   #6
DirtMerchant
DirtMerchant's Avatar
Oddometer: 1,464
I've got a set of these Motion-Pro irons and they work well but I'd trade the 8.5 and 11 for another 16"
2011 R1200RT Polar
DirtMerchant is offline   Reply With Quote
Old 01-18-2010, 11:06 PM   #7
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,342
I have 2 clones of the 16" (and the MRP wheel stand). That and a bead breaker is all I need.... along with the trail bead buddy, a valve core tool, soap, talc, and probably some other things I've forgotten about.
On the road I use plugs. If that doesn't work I'll use my credit card.
marchyman is offline   Reply With Quote
Old 01-19-2010, 08:44 AM   #8
kirkkw
Oddometer: 110
http://www.motorcycle-superstore.com/2/9/205/4456/ITEM/Motion-Pro-Assorted-Tire-Iron-Set.aspx?sst=RR|4456
This is the set I use - actually I have 2 sets, one each on different continents - they work just fine.
The important issue is to keep the far side of the tire off the shoulder.
Ken
kirkkw is online now   Reply With Quote
Old 01-19-2010, 09:27 AM   #9
TNC
Candyass Camper
TNC's Avatar
Oddometer: 4,622
I like the spoon-shaped models...like the Motion Pro...better than those sharp, pointy models. I've experienced less tube puncture heartburn with the spoon versions. People are different, however, and most of tire changing comes down to a great degree of technique. A decent amount of length goes a long way in easing the pain for many DOT tires...and even some gnarly pure off road tires. For the more dirt worthy DS bikes like the WR250R, KLX250, and such, longer tire irons can be challenging to pack or carry. I ended up finding a convenient place to attach my 14" tire iron to my bike while carrying the 2 smaller spoon-style levers in my rack bag. At home, I use 2 very long automotive spoon-style levers that are about 18" and 24" long respectively. They were purchased from a truck stop/service station supplier outlet, and they are freakin' stout.
TNC screwed with this post 12-15-2010 at 09:43 AM
TNC is offline   Reply With Quote
Old 01-19-2010, 09:44 AM   #10
Krabill
Krabill's Avatar
Oddometer: 4,840
I carry two 8 1/2" irons with me on the bike at all times, but use long ones at home.
I can get by with the little ones and carry those just because they are easy to stuff away somewhere on the bike. The longer ones are definitely easier to use, though.
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 01-19-2010, 12:16 PM   #11
TwilightZone
Oddometer: 2,955
I use two 16" motion pro's with a shorter model for dealing with 'fine stuff' at home. I carry (2) 11" models plus an 8" in my motorcycle tools.
Lube is king, along with understanding the 'drop-center' motorcycle rims.
TwilightZone is online now   Reply With Quote
Old 01-19-2010, 12:32 PM   #12
markjenn
Oddometer: 10,395
I've got twenty or thirty tire irons of various sizes in my shop toolboxes but almost always use the 16" Motion Pros, especially on tubeless street bike tires. You need 3 of them to make thing easiest. But they're probably overkill for dirt bike tires.
For a tubeless street bike toolkit, I plug so don't carry tire irons. For a bike with tubes, I carry the shorter 8" or 10" ones depending on the space on the bike. The ones with rounded teardrop ends look like they would result in fewer skinned knuckles and I may look into getting some.
- Mark
Old 09-30-2011, 04:32 PM   #13
_cy_
Oddometer: 6,056
long is best at home, but what's the best tire iron to carry with you?
couldn't find any to suit me, so took two harbor freight ($5 ea) 24in tire irons.
then ground them down to correct thinness for motorcycle tire use.
_cy_ screwed with this post 09-30-2011 at 04:40 PM
_cy_ is online now   Reply With Quote
Old 09-30-2011, 05:10 PM   #14
Wuwei
Oddometer: 1,108
And the answer is........Stubby Tire Tools! Love these things. They don't mar the rim, are lightweight, easy on the hands, grip the beed well, and provide all around goodness in removing or putting on tires. Have not used them with tubed tires, but they work great on sportbike tires.
For my part, I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to move. Robert Louis Stevenson
Wuwei is offline   Reply With Quote
Old 09-30-2011, 06:30 PM   #15
_cy_
Oddometer: 6,056
they look excellent! which model is best for taking along?
standard stubby is 12in vs 8.5 for backpacker
Times are GMT -7.   It's 07:27 AM.
