Old 12-01-2011, 08:25 AM   #1141
JMo (& piglet)
Gone a bit Baja
JMo (& piglet)'s Avatar
Oddometer: 4,447
Originally Posted by Brodovitch View Post
True, but I thought that the 449 had a hydraulic clutch (nothing against cables - apart from the fact that they remind me of my cable-destroying XR250 many years back oh the grief)
So have they mated the 449 cylinder & head to GX cases?
I'm not totally up on the G450X/Husky 449, other than a passing nerd at them when I've been in a workshop - but yes, it would seem they both ran/run a hydraulic clutch in enduro spec...
However, possibly that was one of the weak points in a rally configuration? - being that the G450/449 clutch is on the end of the flywheel and runs much quicker that a regular clutch, I understand they had overheating issues... and that heat may well have transfered to the slave cylinder of the hydraulic actuator - essentially reducing/losing clutch control?
Using a cable would mean they retain clutch action for longer?
As for the engine internals, I only know what I've picked up fro chatting to Si - the G450X engine was reworked for the application in the 449, and many (all?) of the shortcomings addressed, based on the feedback they collated from campaigning the G450X in enduro (and to a lesser extend rally raid).
I'd still go with a Yamaha or KTM mind you... they also look prettier!
Jx
JMo (& piglet) is offline   Reply With Quote
Old 12-01-2011, 09:38 AM   #1142
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,952
I am going through clutch issues with my LC4 motor with a hydro clutch.. If I could switch to the older cable style I would.. nothing but extra problems with the hyrdro including: master piston going bad, holes in a clutch hose, O rings on the slave wearing out and the heat and uneven pressures that you mention.. then you have the extra force it takes on your forearm to work the thing.. If I build another motor I will use older 02 cases..
wrk2surf is offline   Reply With Quote
Old 12-01-2011, 10:56 AM   #1143
Brodovitch
Team ⌘R
Brodovitch's Avatar
Oddometer: 3,171
Appreciate the insight Jenny, that's more technical knowledge than I can handle
My mechanic contests the 511 in the local enduro championship
in conditions known to fry clutches (tight, technical trails leading to full-on
MX style special tests), will ask him if he has had any issues.
Myself, I prefer the hydraulic alternative the more recent bikes offer.
Have been stranded too many times in my earlier years on XRs and DRs,
and found myself constantly routing spare clutch cables alongside the
operating ones.. changing was a real pain in the ass as my
hand always got fried when trying to hook up the spare behind cylinder heads,
plus they would always slacken when the engine got on the hotter side
in more brutal enduro conditions..
I am quite the luddite when it comes to new technology on dirt-bikes,
but the hydraulic clutch was a welcome addition when it was introduced
TALES FROM THE BIVOUAC
TWOONEZERO
Brodovitch is offline   Reply With Quote
Old 12-01-2011, 11:39 AM   #1144
690RR
Location: Norway or some exotic country with a lot of sand
Oddometer: 109
There are few problems with Husky's, lads were desperately trying to re-do rear fuel tank after Marocco, as all this weight was cracking attachments.
Earlier this year, in Abu Dhabi, mechanics were changing exhaust every second day, as all packing was gone after 2 days in desert. One of the reasons was build of system, second is 13.000 revs, probably highest from all engines out there.
And one interesting thing, this engines turns wrong way, which means, when you twist throttle on normal bike, rear will be forced down, when you do it with Husky, rear lifts up and affects traction.
690RR is offline   Reply With Quote
Old 12-01-2011, 12:10 PM   #1145
doyle
RallyRaidReview-ing
doyle's Avatar
Oddometer: 23,857
Wouldn't it be more the mass/forces of the rear wheel affecting the torque/direction of force rather than the relatively light engine internals. Quite obviously the rear wheel turns in the 'normal' direction. (unless that Husky is a handful in reverse.)
RallyRaidReview - @RallyRaidReview
doyle is offline   Reply With Quote
Old 12-01-2011, 12:16 PM   #1146
schattat
schattat's Avatar
Oddometer: 1,445
AFAIK the new Husky/BMW hyrbrid runs the 26L subframe tank that MecaSystems offers for the Honda CRF450X. All the mounting points (on the sides and beneath the seat) seem to be identical.
Source: FB - Speedbrain
Source: Rallye Management Services
RNS - Rallye Navigation Solutions
Yamaha WR450F Rallye Spec
schattat is offline   Reply With Quote
Old 12-01-2011, 01:53 PM   #1147
Trang
... 2nd last to the Sweep
Trang's Avatar
Oddometer: 1,093
Wow !!!
... should we let BC61 know?
http://www.advrider.com/forums/showp...&postcount=173
"I still haven't worked out why all these people are here, but all I can think is there's a small amount of craziness left in an increasingly sanitised world and they want to be part of it"
Russ Malkin 2006
Trang is offline   Reply With Quote
Old 12-01-2011, 03:29 PM   #1148
tehdutchie
tehdutchie's Avatar
Oddometer: 1,883
Originally Posted by huskyte610e View Post
Wow !!!
Nope, he runs a REAL Husky :) Above is a BMW (on steriods :))
tehdutchie is online now   Reply With Quote
Old 12-01-2011, 03:43 PM   #1149
Trang
Trang's Avatar
Oddometer: 1,093
So, the CRF rear tank will suit a G450X frame, but not the TE449 frame.
... my list of interchangeble brand bike parts, just got another disclaimer.
Russ Malkin 2006
Old 12-01-2011, 04:26 PM   #1150
BC61
BC61's Avatar
Oddometer: 1,276
The Speedbrain BMW frames pictured above have been highly modified. The rear down tube is at a different angle, the rear shock is mounted differently and the rear swing arm now has a linkage that is different than the Husqvarna.
I'd love to have had the time and resources for trial and error of adapting other kits.
BC Moto Adventures https://www.facebook.com/pages/BC-Mo...2554006?ref=hl
My experience at Dakar 2012 www.bc2dakar.com
BC61 is offline   Reply With Quote
Old 12-01-2011, 04:42 PM   #1151
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,151
How's the bike coming along Bill ?
30 more days until go time
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 12-01-2011, 05:08 PM   #1152
BC61
BC61's Avatar
Oddometer: 1,276
Getting closer, still have all the added electronics to wire up, plumb the extra tanks then take it all apart again for final assembly.
Old 12-01-2011, 05:30 PM   #1153
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,151
No rush, lots of time left
See ya in a few weeks
Roaming Rally 2015
Old 12-01-2011, 11:46 PM   #1154
troy safari carpente
Team f5ool
troy safari carpente's Avatar
Location: "Pearl of the sound" - f5ederation of scandwegia
Oddometer: 20,861
Question It does what-a-who which way now...?
I've read through that one three trimes now Eskil... and I'm still not quite sure what you mean... Care to give it another shot for us...?
+1... yep, that's what I am trying to grasp also... 690RR's explanation seem's sort of "backwards" to me... I'll explain;
Regardless of the design configuration of the engine (right side/leftside output shaft) or the rotational direction of the internal components of the engine - the countershaft sprocket turns and drives the chain in a direction so as to rotate the rear wheel and provide forward motion (otherwise - as Doyle pointed out - you'd disappear backwards of the start podium fairly rapidly! ).
The forces exhibited on the rear wheel by the drive train - torque - affect the rotational mass of the rear wheel; which in turn has an effect the rear suspension. If you turn the throttle and increase the rotational torque of the rear wheel, this has the effect of forcing the rear wheel down - raising the rear suspension... If you chop the throttle and decrease the rotational speed of the rear wheel (decrease torque) this in fact causes the rear suspension compress slightly.
There is a common missaprehension that increased torque causes the rear suspension to compress; which is not the case. Under acceleration the rear suspension of a motorcycle does compress significantly (coincidently, the front rises*)... but this is due to the simple transfer of the weight bias (mostly the rider) for or aft. *Conversely - the opposite is true under braking (where the rear tends to lift and the front compresses).
The effect that drivetrain torque exhibits over the compression/rebound characteristics of the rear suspension IS one of the major factors that Horst Leitner's patented AMP Link system attempted to address and is one of the things that BMW's G 450X swingarm axle mount/countershaft drive system also is designed to remedy.
But as to why the Husqvarna seemingly defies physics and does the reverse is a mystery to me... but most likely a wording missunderstanding or I am missing something in 690RR's explanation?
CONTENTS MAY SETTLE DURING TRANSPORT...
troy safari carpente is offline   Reply With Quote
Old 12-02-2011, 12:10 AM   #1155
fetid_swamp
fetid_swamp's Avatar
Oddometer: 746
torque effect?
go for a fang in an old swing axle vw beetle/baja/buggy/country buggy that has the conventional setup and then go for a fang in one that has reduction hubs fitted such that the transaxle spins in "reverse".
under throttle the conventional one squats while the one with the reduction hubs stands up.... to its stops.
dont know what this proves but it did remind me of many happy times fanging the old volksies.
RE the bmw/husky, i thought having the pivot and the cs at the same point just minimised the torque effect (squatting under accell). no idea really.
Standing on the front lawn, shirtless, arguing with meth head neighbours while surrounded by bemused cops with dogs and tasers at the ready, his mullet gently blowing in the breeze.
fetid_swamp is offline   Reply With Quote
Times are GMT -7.   It's 12:08 AM.
