02-19-2010, 06:36 AM
#181 | |
House Ape
Oddometer: 2,178
David
David I'm tryin' ta think, but nuttin' happens! --Curly |
02-19-2010, 06:58 AM
#182 | |
Unwitting Accomplice
Oddometer: 10,833
![]() Tank is currently at Line-X. Should be done today....
fotomote |
02-20-2010, 07:18 AM
#183 | |
Greg
Oddometer: 1,556
CASCADE EXPEDITIONS WABDR Tours & More. PSSOR - Dualsport Training & Adventure Camps. |
02-20-2010, 06:45 PM
#184 | |
Oddometer: 2,375
The heavy stuff was in the panniers and the Kolpin was low enough not to give a top-heavy effect. That was the load I took on our desert run in September last year. The bike was nothing short of brilliant across the dunes/soft sand and made the trip so easy compared to the 1150/1200s on the trip. I will probably not use this setup again as I think larger panniers and less stuff on the rack is the way to go in the future. This is my prefferred luggage setup, with the Kolpin in place from now on.
"I'm a thousand miles from nowhere,Time don't matter to me, Cause I'm a thousand miles from nowhere, And there's no place I'd rather be!! Bigem screwed with this post 02-20-2010 at 06:52 PM |
03-13-2010, 11:16 PM
#185 |
Oddometer: 10,833
Well, my previous bike was an R1150GS. I got tired of having to worry about my next gas stop after 150 miles. I heard about a slightly dented Adventure tank that could be had cheap. Bought it for $100 plus another $15 to ship it. The tank was silver, bike was yellow. Painting meant body work and worrying about scratches so I went bedliner.
Linky Fast forward a few years and big crash later and I want another bike. The F800 GS looks like it will fit the, erm, "bill" apart from the relatively short range (200-ish miles). So when I buy the bike I buy a TT tank through the dealer and prepay installation. 4 hours. They took a bit of a bath on that, IIRC the total time was closer to 12. So here it is. Same bedliner, for similar reasons, plus there isn't a good crashbar set that I know of that would protect a painted TT tank. ![]() ![]()
fotomote |
03-14-2010, 03:21 AM
#186 | |
2 Wheelers By Choice.. =]
Oddometer: 200
03-14-2010, 02:47 PM
#187 |
Oddometer: 181
That tank setup looks great! I like the functionality of the Rhino Liner Finish. I am ordering this same unpainted kit next month, but was looking at the more conventional satin black finish.
Did you go with heavier front springs for this extra weight? Was any special primer used in the application of the Rhino Liner? I can't see the kit's fuel line disconnects in the photo. Where were they installed? Do you have any close up photos of the finished tank? Thanks,
2013 R1200GS W White, Enduro Pkg, Comfort Pkg, CC, Spoke Wheels |
03-14-2010, 05:00 PM
#188 | |
Oddometer: 10,833
One major issue: At about 40 mph a whistle starts. I've got all the likely candidates taped up with gaffer's tape this afternoon and will check the results tomorrow. Cheers!
fotomote |
03-14-2010, 05:17 PM
#189 | |
North Forest Rider
Oddometer: 3,654
03-14-2010, 06:09 PM
#190 |
Oddometer: 181
I will be interested in your findings about the whistle. More photos appreciated.
03-14-2010, 09:20 PM
#191 |
Oddometer: 980
One question... since the TT tank is higher than the stock tank and the TT tank is connected to the stock tank, how do you fill it? Do you fill the stock tank all the way to the top, close the cap and then fill the TT? I have visions of gas seeping out of the stock filler once the TT is filled! What am I missing?
03-14-2010, 10:59 PM
#192 | |
Oddometer: 10,833
fotomote |
03-14-2010, 11:30 PM
#193 | |
Oddometer: 980
03-15-2010, 12:51 PM
#194 |
Oddometer: 181
Touratech clearly states in their instructions when using the tank to turn the petcocks off until the main tank is in reserve as indicated by the flashing low fuel warning. I would have concerns about overflowing the main tank and flooding the vapor canister if you have the petcocks open with a full main tank and full TT tank. My procedure will be to turn off the petcocks when filling up both tanks and turn them on only after going to reserve (main tank). I will leave them on until refueling again. Leaving them on even overnight shouldn't be a problem if they were only turned on after the main tank went to reserve. At that point both tanks should equalize level without threatening to overfill the main.
One extra I am working on is an inline solenoid fuel cutoff valve so I could control the fuel transfer while riding. Saves having to stop when reaching reserve on the main tank. All you have to do is throw a switch. Wire that to switched power and the fuel transfer line automatically closes when turning off the engine. This is an extra safety factor when fueling or parking. Looking forward to extending the "bandwidth" of this bike
03-15-2010, 05:40 PM
#195 | |
Oddometer: 10,833
fotomote |
