Old 01-25-2011, 11:26 PM   #316
gr8ridn
gr8ridn's Avatar
Oddometer: 397
I guess I got a bit mixed up, you are right. What I modified was the washer between the tank and the bracket spacer. I brazed the inner washer to the tank rubber steel spacer. Now the washer is always lined up when I insert the rear bolts to the bracket. The washer used to fall away as I aligned the tank.
I like the stud with nut idea for the beak attachment. I will explore that mod, thanks.
2014 R1200GSAW
Racing Blue, Premium Group, DWA
gr8ridn screwed with this post 01-25-2011 at 11:34 PM
gr8ridn is offline   Reply With Quote
Old 01-26-2011, 09:19 AM   #317
Camel ADV
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,394
I agree the washers can be a hassle. Brazing them on seems like great idea, I'll have to use that one.
The beak bolts always seem like they are going in cross threaded. I haven't had it happen yet though. I thought short studs that are loctited in would work well as the studs pop through the beak holes and keep everything aligned and in place while you get the nuts started.
It's pretty tight in that area but hopefully there's enough space to get a socket for the nut. If you try it, post up some pics.
Camel Tank auxiliary fuel tank for F series BMW twins. www.Camel-ADV.com
AT-BZ-CA-CN-CO-CR-CZ-CH-FR-DE-GB-GT-HN-IE-JP-KZ-KR-LI-LU-MX-NL-NI-PL-RU-SV-UA-US
Camel ADV is offline   Reply With Quote
Old 01-26-2011, 02:02 PM   #318
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
alright you expert tank installers.... what all do I need to do before I install it? tank comes back from the painter today...
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 01-26-2011, 06:02 PM   #319
Camel ADV
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,394
What do I need to do as in other than whats in the instructions?
If so, I'd say the drain fitting shortening for sure. gr8ridn's suggestion of brazing the washers to the spacers seems like a winner.
Camel ADV screwed with this post 01-26-2011 at 08:48 PM
Old 01-26-2011, 07:19 PM   #320
Motorfiets
Motorfiets's Avatar
Oddometer: 2,997
If so, I'd say the drain fitting shortening for sure. gr8ridn suggestion of brazing the washers to the spacers seems like a winner.
aight sounds good... been kinda browsing what ya'll have said and am going to do the same just didn't know if there's other little tid bits of
Ben
My Photo's
Old 01-26-2011, 08:55 PM   #321
Camel ADV
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,394
I didn't really like the routing of the vent line on the aux tank. The fitting is on the left side and at full lock the triple tree just hits it. It hasn't split that hose yet but I really don't like the location. When I get home I'll likely re-route the hose from the left toward the middle of the triple tree, between the bar clamps then up and over the windscreen and back down the left side rather than the right. Clear as mud right? I'm sure you figure out what I mean when you see it.
I'll try to snap some pics of it and what I'll change when I have some time.
Cory
Old 01-26-2011, 09:56 PM   #322
Motorfiets
Motorfiets's Avatar
Oddometer: 2,997
Cory
Ben
My Photo's
Old 01-26-2011, 10:24 PM   #323
gr8ridn
gr8ridn's Avatar
Oddometer: 397
I will give it a try and report back. I am thinking about making my own studs and reducing the end that the nut threads onto. This would be similar to racing wheel studs that prevent cross threading. This way I won't put excessive strain on the tank by starting the nut cross threaded. I am thinking threaded rod turned down on my lathe. Of course the same thing could be accomplished with a grinder or file. Nice little project.
2014 R1200GSAW
Old 01-26-2011, 10:50 PM   #324
gr8ridn
gr8ridn's Avatar
Oddometer: 397
I would offer measuring and marking at least three times before drilling the original tank. There is little room for error when locating the fuel bulk head fittings. The measurements in the instructions were right on with my tank. There isn't much thread contact for the domed nuts that go inside the tank. I used blue loctite to insure the those nuts wouldn't back off in the field. That would be a major PITA to repair plus you would lose most of your fuel. The blue loctite will withstand gas immersion as long as it is fully cured. I gave it 24 hours before any gas was put into the tank. I also tested with gas for leaks at the bulkhead before installing the rear frame and tank. I think this could save some major time and increase confidence in the integrity of the work.
2014 R1200GSAW
Old 01-27-2011, 12:13 AM   #325
Camel ADV
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,394
You're not kidding. I had to buy longer bolts as I couldn't even get the nuts started. Not sure if my tank was a tad thicker in the specified drilling location or what the issue was but there was no way things were going work with the length of the supplied bolts.
Old 01-27-2011, 06:19 AM   #326
Motorfiets
Motorfiets's Avatar
Oddometer: 2,997
same here... what was odd was I found bolts in my shop that were maybe just 1mm longer so I used them. seems like the factory supplied ones are just cut a tad too short. Could this have something to do with the new and older gen tanks?
Ben
My Photo's
Old 01-30-2011, 11:50 PM   #327
Motorfiets
Motorfiets's Avatar
Oddometer: 2,997
HELP!!!!!!!!!!!!!!!!!! does part number 3 go back on with the kit?
the front fairing is driving me insane putting it together!!!! any help?
Ben
My Photo's
Old 01-31-2011, 03:39 AM   #328
Ducksbane
Quaaack!!!
Ducksbane's Avatar
Oddometer: 1,164
I too have found that an annoying little bastard when I have reassembled the beak. I went out to the garage and took a couple of photos (Its dark here). Hope this helps you work out how it goes back ...
"All that is necessary for the triumph of evil is that good men do nothing." - Edmund Bourke Irish orator, philosopher, & politician (1729 - 1797)
Ducksbane is offline   Reply With Quote
Old 01-31-2011, 07:05 AM   #329
Motorfiets
Motorfiets's Avatar
Oddometer: 2,997
bugger!! how the hell did that work for you?
Ben
My Photo's
Old 01-31-2011, 12:43 PM   #330
Ducksbane
Quaaack!!!
Ducksbane's Avatar
Oddometer: 1,164
Making sure I had it aligned right and patience!
If I remember right you have to get the "ALB" and the beak aligned, get one screw in, do up loosely then get the othe one started, and only then tighten it fully with other beak screws.
It would probably be pretty handy to be built like Vishnu ...
... but I hear he only works on Enfields!
Good luck!
Times are GMT -7.   It's 11:34 PM.
