Old 01-22-2010, 04:25 AM   #1
tandemlover OP
Oddometer: 5
BMW R100RT causing clothes to smell like exhaust
I bought my 1995 R100RT in Nov 09, and have only put a few hundred miles on it. Most rides are in the 50 mile range. This is my first BMW.
The bike starts and runs well, and my 35-40 MPG seems to be in line with what other owners noted in response to my earlier post.
My question now is: Is it normal for your riding suit to have a strong smell of engine exhaust after a ride? And I often smell the exhaust during a ride. I have tried having the fairing vents open and closed, but the result is the same.
There are no holes in the exhaust system, at least that I can see.
It seems like the fairing is causing a vacuum which is sucking the exhaust into it. I am concerned about the health effects of breathing the exhaust.
This can't be what every BMW / tourer owner experiences, so is my situation unique? Any ideas would be appreciated.
tandemlover is offline   Reply With Quote
Old 01-22-2010, 06:02 AM   #2
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 7,354
I've never owned an RT, but do have RSs and have ridden them for about 13 years now. Mine are also the earlier dual-shock versions. I've never had that problem with exhaust smell.
But that's like comparing apples to oranges. Your bike has a shorter exhaust system that could possibly contribute. But my brother did have a similar year RT and commuted 50 miles to work on it without this complaint. I rode it and never noticed such a problem.
I do think you should be getting better mileage, though. I'd think it should be getting at least 45 mpg. Even though it may be getting comparable mileage (to other similar age RTs?) the earlier model 1,000s tended to get anywhere from low 40s to sometimes over 50mpg. That means your engine (even though running well) isn't extracting full power from the charge and will have stinky exhaust. The fresh-air system (now removed, right?) was intended to burn that extra fuel, but in turn over-heated the head and exhaust valves which tended to warp them.
The ideal handling is to increase the compression ratio to 9 or 9.5/1.
But probably the biggest quesion is why the exhaust is being drawn in behind the fairing. Do you ride without luggage? I'm thinking luggage may make it more difficult for exhaust gasses to return to the quiet area behind the fairing - though luggage shouldn't be a requirement for exhaust-free riding.
Perhaps there are some oily or greasy parts of the engine that give off that smell when hot?
Old 01-22-2010, 07:27 AM   #3
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 4,429
Finding exhaust leaks:
The ole trick we used on cars was to hold a hand (rag!) over the exhaust, and listen for hissing.... of course you would have to close both sides, but the principle is the same.
But yes, a smell of exhaust on clothing would be a concern... and it does sound like you may have an over-rich condition. Have you pulled the plugs to take a look at the color of the electrode tips?
Nevertheless, whether it is a leak or the "station wagon effect", getting a strong smell of exhaust is not good for your clothes, let alone your lungs...!
bpeckm is offline   Reply With Quote
Old 01-22-2010, 10:03 AM   #4
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,403
this is not a problem
this is a feature.
On tap:Nada
Aging: 3 experiments in mead - blackberry, apple, and straight honey
datchew is offline   Reply With Quote
Old 01-22-2010, 10:11 AM   #5
Wirespokes
Wirespokes's Avatar
Oddometer: 7,354
this is a feature.
...to ward of mosquitoes?
Old 01-22-2010, 10:57 AM   #6
Beater
Scope Creep's Victim
Beater's Avatar
Oddometer: 2,212
Cologne ... to find the proper mate.
Fred
'85 R80RT G/Sified
'91 R100GS Bumblebee
Airhead Zen: Ride-Maintain-Repair-Ride On.
Beater is offline   Reply With Quote
Old 01-22-2010, 11:54 AM   #7
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 4,429
It does take a certain je-ne-sais-quoi, doesn't it..... the "proper mate" thing...
Old 01-22-2010, 12:02 PM   #8
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 845
Have both RS and RT and have not had this problem. If it matters, have OE windshield rather than anything higher.
RT fairing has been around since '79 and I have too, and have monitored BMW forums since forums began, and have never heard of this problem.
This is clearly not something that's a "design flaw," as BMW doesn't do that.
As others have noted, look for exhuast leaks, although yours is as new as they get and it might be surprising if there is one. Might also investigate carburetor tuning, looking for too rich, enricheners not coming off, etc. Latter also seems less likely given your reported fuel mileage. Of course there's no design or engineering involved in anything aftermarket, so suspect anything like that, i.e. aftermarket windscreen, exhaust, etc.
Obviously exhaust from the traffic around you is something you just live with.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 01-22-2010, 12:12 PM   #9
walkingbear
walkingbear's Avatar
Oddometer: 2,853
take it off your hands
I will take it off your hands...
Have an 88 RS .. changed to longer pipes...
Installed a Laminar lip http://www.laminarlip.com/bmw.php .. gives it better air flow..
If you want to trade.. I would . I get 40-41mpg
BMWMOA 82741 75 R90S ,83 R100RT (Baron) , 88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS w/hack,05 K1200S (Gandalf)
walkingbear is offline   Reply With Quote
Old 01-22-2010, 05:40 PM   #10
Kentucky
Oddometer: 1,152
Yep. If it becomes unbearable just send me a PM and I'll come up and drag the old girl back to the man cave. Problem solved!
2012 Kymco GT300i
2006 Honda ST1300 (for sale soon)
2009 Kymco Agility 125
2006 Kymco B & W 250 SOLD SOLD
2007 Piaggio BV 250
Kentucky is offline   Reply With Quote
Old 01-22-2010, 06:59 PM   #11
Hawk Medicine
Coyote's Brother
Oddometer: 3,299
I can't believe that you said that...!
How about Airhead seat hinges?
Or maybe the cheapo charging systems, stupid hand controls, breaking bag mounts, battery that you need a mechanics degree to remove, luggage latches that fail, steering dampers that are a running joke, hokey honky R-100 center stands, collapsing side stands, The entire single disk brake system, bikes with full fairings at have the fuses in the headlamp shells and theres more.
Oh God...! I just hate Airheads!
Mymindsok
PS: Know anyone who has a R-100 basket case for sale?
PSS: If you're riding an RT and your clothes smell like gas, maybe you're not riding fast enough!
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 01-22-2010, 09:53 PM   #12
tordog
tordog
Oddometer: 29
Bad Gas
Is it old and stale fuel? Try some fresh unleaded.
tordog is offline   Reply With Quote
Old 01-23-2010, 06:28 PM   #13
bmwrench
Oddometer: 1,462
"This is clearly not something that's a "design flaw," as BMW doesn't do that."
Right. BMW doesn't make mistakes. They make improvements.
bmwrench is offline   Reply With Quote
Old 01-23-2010, 06:53 PM   #14
PFFOG
Richard Alps-aholic
PFFOG's Avatar
Location: Western NY, further from NYC than 6 entire states
Oddometer: 1,145
Ride faster!!!!
PFFOG is online now   Reply With Quote
Old 01-23-2010, 07:04 PM   #15
squish
Out of the office.
Oddometer: 4,948
Have you checked your compression?
Do you burn oil?
If your rings are a little loose and you're burning oil
it might make the exhaust more strong.
You could try hooking the bike up to a EGA but that cost money.
Does it smell like gasoline or just like dirty exhaust?
What's your oil smell/look like?
Try changing the oil does that change anything?
Sometime fresh oil helps to sell the rings a little and it won't smoke as bad at first.
How do the plugs look?
On vacation for a spell
squish is offline   Reply With Quote
Times are GMT -7.   It's 06:03 PM.
