Old 01-23-2010, 12:07 AM   #1
Prairie Beemer OP
Oddometer: 52
Airhead on gravel and dirt
I'd like to get a little more off the beaten path next spring on my R60/7. What can I expect from the bike on gravel, dirt, sand or maybe a little mud?
They seem to do fine in the old war movies.
Prairie Beemer is offline   Reply With Quote
Old 01-23-2010, 06:01 AM   #2
SprintSix
Oddometer: 151
For light offroad use as described, they do great. Tires are the main factor. If you really are talking war era BMW they go well on gravel but my experience is limited to 2 rides. Very careful rides, fully restored bikes. Tires again would help enormously.
For more heavy use the big problems are ground clearance and weight. My budget plan for my 81 r100rt. Top brace, 1" over shocks, shallow pan and pickup froma /5, frame mounted bash plate, flip the exhaust, spark arrestor type mufflers, knobbily DOTS. Strip weight.
SprintSix is offline   Reply With Quote
Old 01-23-2010, 07:28 AM   #3
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,487
Slow, cautious riding on gravel roads and relatively smooth dirt is fine and fun. As mentioned, anything else and you are limited by tires, ground clearance, weight and suspension. Even dual purpose airheads like the g/s aren't great in these situations unless much modified and prepped. But you should give it a try. Heck somewhere I saw a suzuki gsxr with knobbies that some character rode around the world.
JT
www.northwoodsairheads.com
www.jefftrappwindsors.com
"Between two explanations, choose the clearest; between two forms,
the most elementary; between two expressions, the shortest."
Between two motorcycles the simplest (DW)
Eugeni d' Ors (1881-1954); Spanish writer.
jtwind is offline   Reply With Quote
Old 01-23-2010, 08:51 AM   #4
tennessee thumper
now in Mt. View, AR
tennessee thumper's Avatar
Oddometer: 730
Ride to your ability.
If you have some motocross experience you'll find the rubber cow to be heavy but quite capable in most situations.
Paved roads are the exception here in my neck of the woods and with my /5 I've done a number of ill advised water crossings, traveled many a forest service road and dug out of some pretty deep gravel.
Only thing worse for the wear was the front fender and oil sump.
The most important thing is having dry ground to ride on. Mud is not your friend when off roading on an airhead. My #1 rule is this...
when in doubt, throttle hard.
tennessee thumper is offline   Reply With Quote
Old 01-23-2010, 10:02 AM   #5
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,014
Wider bars are better than narrow bars.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 01-23-2010, 11:03 AM   #6
Ray of Sunshine
Meat Donut 2 Some
Ray of Sunshine's Avatar
Oddometer: 16,858
UNlike the street, forget you have a front brake. Even the POS front brake on a BMW airhead will lock the front tire. Not good.
I have ridden lots of dirt/gravel roads on my airhead and it isn't too bad. Not like a dedicated dual sport, but remain calm, let he bike find its way, and you will be okay.
Just how seriuos are you going to ride? Casual use, yes, serious ADV take no prisoners mud plagging, there are much better choices.
For the love of Baldy, would someone please buy my bikes?
Life is better, but why not?
Ray of Sunshine is offline   Reply With Quote
Old 01-23-2010, 11:04 AM   #7
Country Doc
Wanderer
Oddometer: 2,721
I actually find my /6 and /5 easier to ride on gravel than my R100GS was. The CofG is low, they handle just fine on smooth gravel, and they were more predictable. I never knew what was happening beneath me on the GS.
I wouldn't try anything rough or loose, but I'd explore secondary unpaved roads to my hearts content on an old road-going airhead.
dc
Country Doc is offline   Reply With Quote
Old 01-23-2010, 04:42 PM   #8
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,501
They go great on gravel,I think my R65 goes better on gravel than all the adventure bikes I had before.Set up is important though....tyres and bars.
motu screwed with this post 01-23-2010 at 07:29 PM
motu is online now   Reply With Quote
Old 01-23-2010, 04:44 PM   #9
Country Doc
Wanderer
Oddometer: 2,721
cool bike!
dc
Old 01-23-2010, 05:57 PM   #10
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,392
Off road airhead
Just ask the dude that owns this bike!
DSC03992
Check out the Alabama chrome on the headlight and fender strut. Hey Redbud, where you at? His /5 bombed down some dirt tracks pretty snappy!!!
Old 01-23-2010, 06:10 PM   #11
BALSEY
Oddometer: 113
Thanks for the input. I'm thinking of a gravel traveler for my 83' R100.
BALSEY is online now   Reply With Quote
Old 01-23-2010, 06:54 PM   #12
kstoo
kstoo's Avatar
Oddometer: 73
+1 tires (I am going to try something else on the next change).
Suddenly I realize what that black knob at the center of the handlebar is for!
I need a better way of sealing water out of the ignition sensor area when that goes under water. damhik.
Other than that, I just love blasting gravel roads. It gets you to places that others don't normally find.
kstoo is offline   Reply With Quote
Old 01-23-2010, 06:58 PM   #13
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,502
Originally Posted by motu
They go great on gravel,I think my R65 goes better on gravel that all the adventure bikes I had before.Set up is important though....tyres and bars.
What bars are you running?
Old 01-23-2010, 07:29 PM   #14
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,501
Slideways from Omar.
Old 01-23-2010, 07:59 PM   #15
Dratharr
Dratharr's Avatar
Oddometer: 233
I ride my R100/7 off road all the time, it rides better than my R1150GS on gravel road's. Last year I was riding with a friend of mine in the Black Hills of South Dakota he was on his 77' R100S and I was on my GS, we where riding some dirt roads and a couple of guys were in front of us on KTM dirt bikes my buddy passed them, and then they passed him, then he gassed it and totally schooled them, I was laughing my ass off, he was ripping down that dirt road at probably around 80mph. He was pitching it sideways around the corners, those guys had to be like WTF. My friend is totaly old school Bell half face helmet, googles, Luftmiester fairing, it still cracks me up thinking about it.
Dratharr is offline   Reply With Quote
Times are GMT -7.   It's 12:29 AM.
