Old 03-12-2010, 04:08 AM   #91
unlawfulsm
Bearded Hooligan
unlawfulsm's Avatar
Oddometer: 577
Originally Posted by Maurizio
The Rally-Raid Products sprocket cover/clutch guard has arrived.
A truly nice piece of machined aluminium, indeed.
Easy to mount, it looks really sturdy and I think that it will make its job in the bad case of a chain failure to protect the clutch actuator and the ignition cover. Highly reccomended!
Pics when all the other parts will arrive and be installed...
I have one too and it is a very nicely built product. I hope that I never need to protect the case, but its there for insurance. I also picked up their gas filler and it is of the same quality. The only thing I am waiting on for my bike is the Rally Raid tanks that should be available after the Touareg Rally. Then she will be complete
Get a discount at Smugmug
Use Code- iFRLhicsrl4no
Great Deals on Gear
unlawfulsm is offline   Reply With Quote
Old 03-12-2010, 04:14 AM   #92
Maurizio OP
2 smoker
Maurizio's Avatar
Oddometer: 163
Luckily here in Italy we live in a "small" country filled with gas stations...
Anyway those tanks are, IMHO, the best option available today, considering size, cost (?), look and functionality.
maurizio
'14 250 EXC E "Sparkling Orange"
'08 FLHCTUSE3 - '76 CB 750 F ss
sold: '03 950 adv s, '05 450 exc, '08 690 e
Maurizio is offline   Reply With Quote
Old 03-12-2010, 05:36 AM   #93
gkgeiger
Every ride is an ADV
gkgeiger's Avatar
Oddometer: 665
Maurizio,
Enjoying this thread. Would you tell me the make and model of your folding mirrors. I like the folding ability but also need to see out of them. How would you rate them for vision and vibration? Thanks in advance!
Getting old is not for Sissy's!
Gene
'14 R1200GSW
'12 NC700X/D
gkgeiger is offline   Reply With Quote
Old 03-12-2010, 05:48 AM   #94
Maurizio OP
2 smoker
Maurizio's Avatar
Oddometer: 163
Originally Posted by gkgeiger
Maurizio,
I received a private message from a fellow ADVrider a few weeks ago with the same question: this was my answer:
"Those mirrors are pretty common here in Italy, and I bought it in a bike shop near home.
They are also pretty cheap.
You can easily find them on ebay: just an example:
http://cgi.ebay.it/SPECCHIETTO-SINISTRO-UNIVERSALE-MOTO-CROSS-ENDURO-QUAD_W0QQitemZ380205725558QQcmdZViewItemQQptZRicam bi_e_Accessori_Moto?hash=item588606f776"
I don't really know who manufactures them, maybe http://www.far.it/.
The rating about vision and vibration is as low as the stock ones... Maybe a little better as far as it concernes vibration, but the lenght of the stem is a little bit shorter than that of the standard KTM mirrors.
I use the bike very little on road (actually I use the bike much less than it deserves, but this is another story...) and the mirror is there mostly for Italian DOT rules...
maurizio
Maurizio screwed with this post 03-16-2010 at 08:26 AM
Old 03-12-2010, 05:48 AM   #95
umitc
umitc's Avatar
Oddometer: 353
Laugh
Hey Maurizio, great thread thanks.
Finally today, I have received my 690R and hit the roads and soon hope to start hitting the mud.
Concerning the above headlights. I have the same; I was thinking the large one will be the default and the top one is the high beam. Are you happy with this way??
umitc screwed with this post 03-12-2010 at 05:50 AM Reason: not finished
umitc is offline   Reply With Quote
Old 03-12-2010, 06:13 AM   #96
Maurizio OP
2 smoker
Maurizio's Avatar
Oddometer: 163
The top light is the low beam, and the larger is the high beam.
Exactely the opposite of my old 950 Adv setup...
The X2 is a good choice, IMHO, to get rid of the crappy EXC style stock headlight of the E/R, and also of the bulky E one.
It has a good light beam, almost equal to that of the stock Enduro (one of the best dual sport headlights I've ever seen).
maurizio
Old 03-12-2010, 06:36 AM   #97
umitc
umitc's Avatar
Oddometer: 353
Maurizio, thank you very much for your quick reply.
In a few minutes, I will be able to understand, how good they are.
Old 03-16-2010, 06:22 AM   #98
Maurizio OP
2 smoker
Maurizio's Avatar
Oddometer: 163
Originally Posted by bobzilla
Tell me more about the seat
Availability here in Europe on March, 25th.
Estimated price 199.
maurizio
Old 03-17-2010, 01:09 PM   #99
teti
especie en extincion
teti's Avatar
Oddometer: 143
maurizio buen dia, esta suspension es la original y la reformaste o pusiste una de 300mm de la 530 exc, y la trasera ?
me interesa cambiarle a la mia tambien.
saludos atte
desde argentina
teti
teti is offline   Reply With Quote
Old 03-17-2010, 01:30 PM   #100
Maurizio OP
2 smoker
Maurizio's Avatar
Oddometer: 163
saludos atte
desde argentina
teti
Front is a second hand fork from an '07 EXC, 300 mm, completely rebuilt, resprung with 4,6 nm coils and different hydraulic valving, slighty hardened in compression and extension; the rear is a new unit for a 690 Enduro R, modified in the internals to gain 5 mm more travel (280 mm) and with a little softer hydraulic setup.
Hope this helps, ciao!
maurizio
Old 03-23-2010, 12:52 PM   #101
tetram
Oddometer: 0
I bought and received part 4 and 5 but when i tried to put part 5 it seems that the 2 little plate that goes on plastic box are too long.
Did you have same problem so did you reduced the lenght of these plates
Thanks in advance for your help
tetram is offline   Reply With Quote
Old 03-24-2010, 02:35 AM   #102
Maurizio OP
2 smoker
Maurizio's Avatar
Oddometer: 163
Yes, I did it.
I've shortened those two tabs of about 3 mm.
A little more detailed write up of the install is here.
I want to add a note: you have better soldering an internal threaded bolt or small tube to the base plate, and insert the long screw from the top of the filter.
maurizio
Old 03-24-2010, 02:48 AM   #103
Maurizio OP
2 smoker
Maurizio's Avatar
Oddometer: 163
Last bits
The "project" bike is almost ready.
Some parts have arrived and already been installed:
Rally Raid Products sprocket cover, covering a Z14 front sprocket:
Carbon Performance heat shields:
ProFill Australia fuel neck filter (PROFILL-ULTRA-MK2-EUR-0001):
Edit: ProFill now lists a "coming soon" filter made for "ACERBIS "small cap" KTM690 adaptor for the rear under seat tank", part code PROFILL-ULTRA-MK2-ACE-0002.
KTM Power Parts Z 46 "Stealth" rear sprocket, to be installed Saturday Night (no more Disco Dance since mid Eighties, here... ):
The Power Parts Ergo Seat will be in the KTM Italia headquarters facility tomorrow and immediately sent out for delivery, so I hope my dealer will receive it on next Monday or Tuesday...
maurizio
Maurizio screwed with this post 03-24-2010 at 03:40 AM
Old 03-25-2010, 04:36 AM   #104
Swede
Swede's Avatar
Oddometer: 0
Does anyone know if the dustcover for that filter is avalible from KTM and if so the KTM number?
1000cc BMW, 2090cc KTM
Swede is offline   Reply With Quote
Old 03-25-2010, 06:24 AM   #105
Maurizio OP
2 smoker
Maurizio's Avatar
Oddometer: 163
I haven't seen any trace of it among KTM parts.
However there is a dustcover listed in the Twin Air catalog, but I am not sure that the part is the same (450/660 Rally Factory Replica '98->'10? )
maurizio
Maurizio screwed with this post 03-25-2010 at 06:49 AM
Times are GMT -7.   It's 05:33 PM.
