Old 01-27-2010, 04:36 AM   #1
Dieselboy OP
Journey not Destination
Dieselboy's Avatar
Oddometer: 1,152
F800GS Tubeless
For on-road ease of flat repair, I've sealed my rim to use tubeless rubber on my F8GS.
EDIT: Thanks!!! to Cyborg (his link) (Finally found the link...)
Supplies
Prep
Conversion
"Seals All" went into the syringe. Goop went directly from tube. Apply two layers of Seals All. Wait 30min then apply one layer of Goop. Let stand over night. Remount.
Dieselboy
The Adventure Continues
Dieselboy screwed with this post 08-23-2013 at 07:50 PM
Dieselboy is offline   Reply With Quote
Old 01-27-2010, 04:54 AM   #2
llamapacker
Mr. Conservative
llamapacker's Avatar
Oddometer: 1,312
Intersting, now go ride and check back in 10 or 15 thousand miles. I like it.
14 KTM 1190 Adventure
14 500xc-w plated
llamapacker is offline   Reply With Quote
Old 01-27-2010, 04:57 AM   #3
jaycommando
jaycommando's Avatar
Oddometer: 103
good idea
much easier than trying to move spokes to the outside of the rim.
Jay.
Just because I stink of petrol, look like shit and still smile doesn't mean I've not been having fun!
Soldiers Do It With Their Helmets ON!!
jaycommando is offline   Reply With Quote
Old 01-27-2010, 05:23 AM   #4
cristi-mic
cristi-mic's Avatar
Oddometer: 95
http://www.tenereclub.ro/index.php?p...3&t_id=346&s=1
Me too
http://cristi-mic.blogspot.com/
cristi-mic is offline   Reply With Quote
Old 01-27-2010, 06:46 AM   #5
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
I'm so subscribing to this one. Thanks for being a guinea pig, Diesel.
David
David
I'm tryin' ta think, but nuttin' happens!
--Curly
WoodWorks is offline   Reply With Quote
Old 01-27-2010, 06:52 AM   #6
PackMule
love what you do
PackMule's Avatar
Oddometer: 19,460
Nate in N.E.
Yes, I have a Dakar problem -- that there are 50 weeks of the year without Dakar!
They don't expect you to finish. That's why it's the Dakar. -- PPiA
PackMule is offline   Reply With Quote
Old 01-27-2010, 07:53 AM   #7
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,152
David
Originally Posted by PackMule
Why does it feel like the boat is sinking and sharks are circling?
Dieselboy
Old 01-27-2010, 08:14 AM   #8
nevermind
sLOW Rider
nevermind's Avatar
Oddometer: 3,019
How did it balance out after adding all the slime, goop and goo? Did it take a lot of weight?
nevermind is offline   Reply With Quote
Old 01-27-2010, 08:15 AM   #9
Maddaddy
Greg
Maddaddy's Avatar
Oddometer: 1,725
I hear the train a coming
this is gonna be better than Jersey Shore.
PSSOR - Dualsport Training & Adventure Camps.
Off-Road Destructor Extraordinaire
Maddaddy is offline   Reply With Quote
Old 01-27-2010, 09:05 AM   #10
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,152
I put her on a Marc Parnes balance tool and spun her both without the tire and with the tire. Neither one showed a significant heavy spot, i.e. after ten spins the wheel never once stopped in the same spot.
Lucky or incompetent. Either way there is not a significant imbalance.
Dieselboy
Old 01-27-2010, 09:33 AM   #11
WoodWorks
House Ape
WoodWorks's Avatar
Oddometer: 2,204
I'd be real curious to know what your rate of leakage is (if you plan on tracking that), and how far you feel safe lowering the pressure when off-roading.
David
David
--Curly
Old 01-27-2010, 10:38 AM   #12
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,152
David
I will definitely track it but I don't off-road so I won't be playing that end.
I'm curious about the other end of the spectrum-- fast. Will the centripetal force cause leakage as the sealant is pulled to the perimeter or will the tire pressure keep it all in check?
Dieselboy
Dieselboy screwed with this post 01-27-2010 at 10:44 AM
Old 01-27-2010, 11:05 AM   #13
nevermind
sLOW Rider
nevermind's Avatar
Oddometer: 3,019
The cool thing about the Parnes balancer is you don't spin it and watch where it stops each time. Put the wheel up on the rig, let it settle. That is the heavy spot. Mark it. Weight the opposite side of the wheel until you can put the heavy spot at 9 o'clock and 3 o'clock and have no movement.
Old 01-27-2010, 11:24 AM   #14
Dieselboy OP
Dieselboy's Avatar
Oddometer: 1,152
Good to know. I don't use the balancer much.
I still think she is basically balanced.
Dieselboy
Old 01-27-2010, 11:37 AM   #15
SCflyer
SCflyer's Avatar
Oddometer: 1,634
Saw a RR for..."Gregor" I think where he did a 17/19 combo on his KTM 950, made the rear tubeless in this manner and went on a trip, 2 up with gear on the Translab. I think he only had problems with the road conditions eating up the tire. It still did decent (able to limp in to town) even with multiple string plugs.
SCflyer is offline   Reply With Quote
Times are GMT -7.   It's 09:26 AM.
