Old 03-15-2014, 09:44 PM   #46
Flyred
Who is John Galt?
Flyred's Avatar
Oddometer: 690
Ive used these tubes for several years
http://www.advrider.com/forums/showthread.php?t=465084
But adding the bags really improves the usefulness.
Flyred is offline   Reply With Quote
Old 05-19-2014, 11:46 AM   #47
gianni1951
gianni1951's Avatar
Oddometer: 66
Tool tube
Done.
gianni1951 is offline   Reply With Quote
Old 05-19-2014, 02:48 PM   #48
Strawdog
Strawdog
Strawdog's Avatar
Oddometer: 113
Name:  April 26 2014 (3).JPG
Strawdog is offline   Reply With Quote
Old 05-22-2014, 11:20 AM   #49
RexBuck
Oddometer: 1,033
Here's the one I made for my bike. Fitted on Hepco Becker racks. Locking, waterproof and pressure relief valve. Opens easily when going from 16,000 feet to sea level.
www.rexbuck.com - RexBuck's Latin America
Information on travelling in Latin America.
Includes links to ride reports to Mexico and to South America
RexBuck is offline   Reply With Quote
Old 06-03-2014, 02:29 PM   #50
alison's wanderland
alison's wanderland's Avatar
Oddometer: 253
Nice! Rex - you would happen to have a pic of the tool tube take apart do you? I'd like to see the individual pieces you used in hopes I can replicate it where I am
2010 F800GS – getting ready for the next adventure
2003 KLR685 – gone with the summer winds of Patagonia : 2012-13 -> L.A. to Ushuaia
adventures in : alison's wanderland
alison's wanderland is offline   Reply With Quote
Old 06-03-2014, 06:53 PM   #51
RexBuck
Oddometer: 1,033
Sorry, I didn't take pics of it when I was putting together.
Basicly it consists of a 4" piece of pipe with cap glued on one end and the screw cap glued on the other.
Getting lid ready for cable - The square piece on the screw cap is hollow on the back side which would let moisture in when a hole is drilled through it to accommodate the cable. So, I drilled the hole through the cap for the cable. I got a piece of plastic tube with an inside diameter of the cable and stuck the tube inside the hollow connecting the two holes through the sides of the square part. Then pressed some plumbers putty in that whole hollow area, filling the square part up. Dries hard as a rock. The plastic tube makes sure there is a clear run for the cable and the cable won't chafe the dried putty. The result is waterproof.
Cable for lock - then took my lid down to one of the wire rope outfits here, picked out a good quality stainless steel cable and they pressed on a stopper on one end and a loop on the other end. The whole idea of this cable is to make it just long enough that when the lid is turned tight, the end of the cable will reach near to one of the cross members of my rack and I can lock it on there. Once locked on, it is impossible (save destruction) to turn the lid off.
Since the tube was now completely water and air tight, I was concerned about being able to unscrew it if I had a significant change in altitude and air pressure. I have Cariboo bags that are based on Pelican Cases which have a waterproof pressure relief valve that looked like it would be perfect. So, I called Pelican and asked them if they would sell me one of their waterproof pressure relief valves they use on their Pelican cases. The guy said sure, they would classify it as a warranty claim and send it right out no charge. I then told him I was leaving in a couple of days and he also ate the cost of super fast 2 day mail. Hey Pelican . . .
You will have to figure out how to attach it to your racks . . . I assume they are something different than my Hepco Beckers. I basically secured a piece of 1 1/4" steel strap to my racks (running parallel to the tube) and then strapped the tube on with 5 large stainless steel hose clamps. My theory is that that I had the screw heads pointing different directions (mostly towards the bag) making a very long, difficult and tedious job for some ladrσn to be able to steal the whole thing.
So, with that tube I did a trip to South America and a small trip to Mexico. I went through altitude changes from sea level to 16,000 feet. Never a problem opening it when I needed it. My bike was usually parked in secured parking overnight but not always. I did notice once that it looked like someone tried to loosen one of the bands but obviously gave up. Very happy with it.
One thing you want to be really carefull about is making sure you have enough room between the bottom of the tool tube and the chain when you shock is fully compressed. I cut it really close as I notice a bit of scuff on the chain guard where it was rubbed a couple of times by the tube. Not wearing through and not enough for me to worry about.
Well, that's a lot of bla bla bla. If you need clarification or more pics of what is there let me know.
Old 06-04-2014, 06:48 AM   #52
alison's wanderland
Oddometer: 253
Tons of great info Rex!... thanks for detailing the process. I had seen (and made) similar with PVC, but I like the added cable lock is a good idea (much safer than a hose clamp) and pressure valve is a nice touch. Your set-up works a lot better than a few drilled holes and is much more waterproof! I have been trying to figure out a way to keep tools on my bike at all times, but living in central america, safety is an issue, so I have been looking for a discreet way to store it. I am going to give this a try. Hopefully I can find all the needed parts. Cheers.
alison's wanderland screwed with this post 06-04-2014 at 06:55 AM
Old 08-30-2014, 11:59 PM   #53
Heavydutydan
Oddometer: 7
Home made tool tube (ABS pipe and Aluminum)
Just thought I'd share what I made for a tool tube for my 2013 F800 GS. I currently have Touratech Zega Pro cases and wanted to fill the "void" on the ride side of the bike without interfering with the installation/removal of the side case or anything else for that matter. I'm not a professional fabricator, and did not have access to fancy tools for bending/shaping, but I had some spare aluminum in my shop and decided to make some templates out of cardboard. I bent the aluminum by hand and with a rubber mallet and drilled holes with a small drill press. I ended up making the whole bracket out of three separate pieces, fastened together with bolts and I had my friend who's a welder put a few tacks in it for me. I made the tube out of 4" ABS pipe. The bracket attaches between the Touratech bracket at the back and the two threaded holes in the bike's sub frame that were left vacant after I removed BMW's "Vario Case" brackets. No drilling or cutting into the bike was necessary. Overall it came out very nice, I painted it and the bracket all flat black, it's water tight and very sturdy. It has plenty of room for tools, spare parts, chain lube, rags, etc.. Here's a link to the slide show! Enjoy and feel free to ask me anything regarding what you see, as I was not able to put captions on each photo explaining what I did.
-Dan
http://s1369.photobucket.com/user/he...Tube%20Project
Heavydutydan is offline   Reply With Quote
Old 12-27-2014, 01:13 AM   #54
moto74
displaced
moto74's Avatar
Oddometer: 181
End caps for straight PVC tool tubes. Also come in OC colour.
Not cheap, but look nice and functional. 100mm and 150mm sizes. Lockable.
http://www.krsaustralia.com.au/produ...zooka-end-caps
moto74 is offline   Reply With Quote
Old 12-27-2014, 11:05 AM   #55
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,690
It's nice to see some of these old threads come back to the surface. Good job guys.
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Old 12-27-2014, 11:57 AM   #56
Nickhob
Armchair adventurer
Oddometer: 88
Mega and nano tube on sw-motech evo racks
Mega for most of my tools and nano for wd40 and chain lube
All the gear and no idea......
Nickhob is online now   Reply With Quote
Old 12-30-2014, 12:02 AM   #57
70East
70East's Avatar
Oddometer: 317
Everyone that mounted a tube on the right rear. Where are you going to mount your Camel Tank?
Brilliance is simply the art of planning ahead.
She's meanness set to music and the bitch is born to run!
I'm a fuel injected suicide machine.
70East is offline   Reply With Quote
Old 12-30-2014, 02:51 AM   #58
GeeK_InsiDe
Moore Gas!!!
GeeK_InsiDe's Avatar
Oddometer: 339
No need here
GeeK_InsiDe is offline   Reply With Quote
Old 12-30-2014, 07:37 AM   #59
Nickhob
Armchair adventurer
Oddometer: 88
+1
No need for a Camel tank in Europe. I get 280km before hitting reserve and if I really need, one of these for $50 works a treat.
http://www.bikegear.co.za/89bbf405-b...dc638b3-9.html
Old 12-30-2014, 09:48 AM   #60
RexBuck
Oddometer: 1,033
One or the other. I put my tube in because the Camel Tanks weren't developed yet and I wanted a little more space for the "necessary" shit we all think we need to carry with us.
Were I to do it again, I'd seriously think about the Camel Tank and put the tools somewhere else.
Times are GMT -7.   It's 10:11 AM.
