Old 02-22-2013, 06:07 PM   #16201
Dirty bike
Eval Innovations Inc
Dirty bike's Avatar
Oddometer: 853
Originally Posted by Geology Rocks View Post
Has anyone switched all of them to stainless? The is a side of me that wants to take them off and paint them all black.
OGR...i will hopefully be riding by that point so I can show you around for a bit.
Woody's Wheel Works sells a kit for this. Someone actually had all their spokes powder coated too, purple, if I remember correctly.
http://www.woodyswheelworks.com/home.htm
Dirty bike is offline   Reply With Quote
Old 02-22-2013, 06:11 PM   #16202
Dirty bike
Dirty bike's Avatar
Oddometer: 853
Originally Posted by ballheadknuckle View Post
Thanks a lot, the connector was exactly where you told.
Glad to help. Very nice job on the license plate bracket. Very clean look.
Old 02-22-2013, 06:33 PM   #16203
GrahamD
GrahamD's Avatar
Oddometer: 5,319
Hate to piiss anyone off but
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 02-22-2013, 08:13 PM   #16204
dcstrom
Oddometer: 1,557
Originally Posted by Old Git Ray View Post
Anyone got any suggestions as to long trip spares.
So far I have listed:
Wheel bearings and seals, back and front.
Both filters
Both ends brake pads.
Throttle cables (possibly)
I considered fork seals but I have them covered with neoprene socks.
OGR
Hi Ray, I'm in Guatemala now, 20,000 miles into my trip. I went through the same process, racking my brain cell to try to think of likely spares. I bought brake pads, the big final drive seal, fork seals (I had dust covers but not convinced they work) spark plugs, some spokes f/r, and levers.
Of those, the plugs were installed as part of the 24000 mile service, 10000 miles into the trip, so I don't have any now. Manual says change at 12000, my first set went twice that and were still good.
Needed the rear drive seal, leak repaired under warranty but the had no stock so used the one I was carrying, and replaced in the kit later.
Same with one fork seal, fixed under warranty in Tucson. The other seal leaked when I got to Guatemala, but fixed easily with a "Sealmate". I'm a believer now! Saved me a lot of grief not having to change the seal.
Spare levers are overkill for me I think, since I have Barkbusters. Would need to be a pretty good hit to break levers through them, and if you did you'd probably have bigger problems than just levers... so, anyone want some levers? Come get 'em!
Don't anticipate needing the spokes either, my rears are cable-tied together so they are not going to get bent if they come loose. Worst case I'll just need nipples, but haven't had any loose spokes so far. I tweaked a few, but I wouldn't say they were "loose".
Filters seem easy to get, oil not so much, I've been buying Honda and Suzuki branded oil from dealerships.
I have a K&N air filter so no worries about finding replacements. Checking and maybe cleaning in the next couple of weeks. The work better when they are a bit dirty, so may not give it a clean.
Also bought an air compressor and the usual tire repair stuff, plus an 18" tube that can go in either tire in case of a rim dinged badly enough that the tire no longer holds air.
Then there's a selection of nuts and bolts, electrical odds and ends, duct tape and baling wire - most of which is overkill. I've been on some seriously bad roads and NOTHING has rattled loose.
Here's the trip report if you want more...
http://www.yamahasupertenere.com/index.php?topic=5583.0
Trevor
Super Tenere news and reviews
http://supertenere1200.com
dcstrom is offline   Reply With Quote
Old 02-23-2013, 01:28 AM   #16205
GrahamD
GrahamD's Avatar
Oddometer: 5,319
Thanks XR Animal
Old 02-23-2013, 03:46 AM   #16206
ballheadknuckle
ballheadknuckle's Avatar
Oddometer: 135
Originally Posted by GrahamD View Post
Thanks XR Animal
Nice vid.
Do motorcycle riders in the US also have a habit of warning upcoming riders that they might run into police? In germany the oncoming riders often show you gesture to warn you that police is upcoming :)
ballheadknuckle is offline   Reply With Quote
Old 02-23-2013, 04:04 AM   #16207
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,395
Nice vid but jesus the stock exhaust sounds like shit.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is offline   Reply With Quote
Old 02-23-2013, 04:27 AM   #16208
creggur
There are no curves here.
creggur's Avatar
Location: Jacksonville, Fl. aka Flatandstraightsandistan...
Oddometer: 277
Nice vid.
Tapping the top of your helmet with your left hand. Though, don't expect to see it much, guys on sportbikes will warn you sometimes, but I've never seen a cruiser rider do it. And you simply won't see many adventure bikes running around (at least not in my neck of the woods)...
_________________________
Blue '12 Tenere
Originally Posted by scottie boy View Post
If you calculated the money spent versus time actually used, vaginas cost more per hour than the space shuttle.
creggur is offline   Reply With Quote
Old 02-23-2013, 08:09 AM   #16209
Tim
Tim's Avatar
Oddometer: 2,361
The next thing needs some work is the heat shield on the exhaust which does not really fit with the akra can.
Yamaha replacement cover in carbon
A good friend will come and bail you out of jail...but a true friend will be sitting next to you saying........."Damn..We F*cked Up" - Anon.
Tim is offline   Reply With Quote
Old 02-23-2013, 08:25 AM   #16210
Thagua
Let's go adventuring...
Thagua's Avatar
Oddometer: 354
Exhaust cover
Or try this one in fiber-carbon ... looks great and covers complete my Akra
Cheers,
Roberto
'Let's go adventuring'
Thagua is offline   Reply With Quote
Old 02-23-2013, 08:37 AM   #16211
ballheadknuckle
Oddometer: 135
Cruiser rides here do it also very rarely. Most of em have issues to reach the speed limit
That looks nice, is it real carbon like the worldcrosser pieces or only carbon look? The price suggest that it is real carbon.
Had anyone issues with the oem panniers with this part or a modified stock heatshield?
Old 02-23-2013, 07:13 PM   #16212
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,395
Pennytech 5 function digital volt meter install
I wanted to add a volt meter as well as an accurate ambient temp gauge so I picked up a Show Chrome 5 function gauge at Amazon for $32 and a stainless steel bracket at the local home center. Used double-sided tape and a zip tie to attach the bracket to the column below the instruments, and velcro to attach the gauge to the bracket. Still have to trim the excess off the bracket but very pleased with the results.
The gauge isn't waterproof, but is pretty well protected from rain in this location. Have used them on several bikes with no long-term issues. http://www.amazon.com/Show-Chrome-Di...w+chrome+gauge
Old 02-23-2013, 11:38 PM   #16213
goodcat8
I can pass this guy.....
goodcat8's Avatar
Oddometer: 3,006
+1 here in LA too. Every genre is really good about it minus the cruiser folks and the scooter people. The scoots may not even know what it means though....
2014 Triumph Scrambler
Prior: 3rd Battalion - 6th Marines - 2nd Marine Division - Lima Company - 2nd Platoon - 0311
goodcat8 is offline   Reply With Quote
Old 02-24-2013, 12:45 AM   #16214
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,395
So you take your hand off the handlebar to tap your helmet? We're old fashioned here, we just flash our headlights. Works day or night...
Old 02-24-2013, 12:55 AM   #16215
Flydream
King of the Atlantic
Flydream's Avatar
Oddometer: 380
+1 flash headlights.
Flydream is offline   Reply With Quote
Times are GMT -7.   It's 01:06 PM.
