Old 03-06-2013, 09:40 AM   #16411
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,258
Originally Posted by jaumev View Post
Yeah... they are just some rookies...
In three weeks I'm going to practice your lessons to ride in deep sand... I will keep you informed
It's not too late. Take the DR and have some real fun.
pluric is online now   Reply With Quote
Old 03-06-2013, 09:43 AM   #16412
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,258
I would like to put a new aluminium handlebar as I have a little bent the OEM.
Do you know if there is a model that has a similar geometry to the standard? I like it.
My priority is that it must be as strong as possible, better if it has a central bar reinforcement.
This should be good. Your camera question got three pages of responses deleted by
the higher power.
Old 03-06-2013, 11:10 AM   #16413
William42
William42's Avatar
Oddometer: 3,041
the higher power.
Mud is evil
William42 is online now   Reply With Quote
Old 03-06-2013, 12:32 PM   #16414
jaumev
jaumev's Avatar
Oddometer: 1,511
You're kidding?
I have a white Tenere
jaumev is offline   Reply With Quote
Old 03-06-2013, 12:36 PM   #16415
jaumev
jaumev's Avatar
Oddometer: 1,511
the higher power.
The higher power don't realize that Tenere owners without problems in our bikes need to talk about cameras to not get bored
Old 03-06-2013, 12:39 PM   #16416
Anticyclone
Ride more worry less
Anticyclone's Avatar
Oddometer: 5,837
the higher power.
I'm scared to suggest anything for fear of having it deleted...
For what it's worth Jaumev, I've got a stock handlebar in my garage. It's your's for the cost of shipping (which would not be insignificant). If you like the stock bend, I'd stick with a stock bar. It's steel, so it should bend, not break when the sand gets the better of you.
Anticyclone is online now   Reply With Quote
Old 03-06-2013, 12:39 PM   #16417
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,258
You're kidding?
I have a white sand anchor
Fixt.
Old 03-06-2013, 01:38 PM   #16418
jaumev
jaumev's Avatar
Oddometer: 1,511
Thanks Anticyclone but I would like to have some aluminium handlebar, stronger than stock.
The problem is that I need a long space (control plane?) to fit all the switches (ABS, clutch…) and the Renthall, Pro Taper, etc. I’ve found from now are shorter.
I hope Dallara don’t mind I fix this post he rote in the Super T Forum. As always a really good (and long ) post.
[quote author=Dallara]
The more I look at it, and read about, the more I am convinced there is not only a common problem here, but also a common solution.
A few years I had a 2002 BMW R1150R, and oddly enough it had a very similar stock handlebar bend. It was a bit narrower, but the sweep, rise, etc. were much the same. And I had the same thumb-numbing, hand-tingling, and middle-of-the-back pain reported here and in other thread. About the time I got really tired of it (2004) on lots of BMW forums, as well as ADVrider, there was a guy named Ricardo Kuhn, and he had a web presence at his site - Moto Macondo. He was sort of a self-taught ergonomic guru, but also a hell of a machinist, and though he was a bit eccentric he did have a lot of followers for a product he called "Ricky Bars". He made these for only R1150R's and R1150G/S's. Essentially it was a set of beautifully machined riser/bar-backs and cut-down set of Renthal MX bars. It was best to talk with him on the phone, but he also exchanged e-mails, and after I talked with a few times I decided to spring for a set of "Ricky Bars"...
In a nutshell it was the best single accessory/farkle I have ever put on a motorcycle, and one of the most amazing experiences seeing how what he had been preaching to me on the phone was *EXACTLY* right. Why? Because it completely transformed that motorcycle. It went from a bike that would drive me nuts any day I spent more than 200 miles in the saddle, to one that literally I could ride endlessly without discomfort or fatigue. I swear it even handled better (as he said it would). I know a lot reading this may think I'm exaggerating, but I assure you it was true - at least for me.
Unfortunately, by his own admission and proclamation , Ricardo was not the best businessman, and sadly he finally ceased producing the "Ricky Bar" kits. If any of you folks were fooling with R and G/S Beemers at the time you probably saw many a rider lamenting the demise of "Ricky Bars" - because they worked. I wish he was still around making bar kits, as he not only made the gorgeous riser/bar-back clamps and cut the Renthal MX bars to fit you, but also made the proper inserts for inside the bars to use the bar-end weights, a Throttlemeister, etc. And he could ask you a number of questions and know which bend bar you needed and how wide it needed to be.
How does all this relate to the problems some of us are having with our S-10's? Well, some of the basic information Ricardo relayed to me seems to be very applicable here. He was adamant that most all street bike bars had too much sweep back, and while this seems to feel great on the showroom floor it is not a natural position for one's wrists or back muscles between one's shoulder blades. That's why all the bars he used to cut-down were MX bars, all having very little sweep. He also believed the bars should neither angle up or down much, if any, from level. A bit of droop was OK, and for some people even a bit of up-tilt. For most, though a near level bar at the grips was best. A lot of street bike bars he also thought were too narrow. The MX bars he used were very wide, so he had to cut them down, but most often they still ended up wider than the bike's original bars.
Now the Super Tenere's bars are plenty wide enough. In fact, I think Ricardo would have had most cut them down about a half-inch to an inch shorter. But I know Ricardo would have said the S-10's bars had way, way too much sweep. *WAY* too much, and with too much down-droop at the ends, too, along with being a bit too low overall, also.
Fortunately a good friend has my old BMW R1150R, complete with those precious "Ricky Bars" (and he loves 'em, too), and I've been able to get another good look at 'em, so I know where I'm going... I'm shooting for a bar with about a 60-65mm sweep (stock is approx. a 142mm sweep), about 95-100mm high (stock is approx. 82mm), and about 780-800mm wide (stock is approx. 820mm). I think a handlebar with those dimensions, used with the fixed Rox Riser bar-backs I have, will just about match what Ricardo would have recommended and should work good for me. Hopefully some of this data and those dimensions will help some of you, too.
Now all I have to do is solve the problem of using the stock handguards, bar-ends, and Kaoko or (name of prototype redacted for now... ;) ) cruise control, etc. Either that or I am going to have to change to some other handguards, bar-ends, etc.
Hope some of this rambling helps others... ::26::
Dallara
[/quote]
jaumev screwed with this post 03-06-2013 at 01:48 PM
Old 03-06-2013, 01:45 PM   #16419
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,258
The problem is that I need a long space to fit all the switches (ABS, clutch…) and the Renthall, Pro Taper, etc. I’ve found from now are shorter.
With all your fabricating connections you can't have them weld an inch or so of tubing on the bar ends?
Old 03-06-2013, 02:12 PM   #16420
jaumev
jaumev's Avatar
Oddometer: 1,511
Yeah, I was thinking something like this, but only if I can't find a ready made one.
Old 03-06-2013, 07:22 PM   #16421
DaFoole
Lewddite at large...
DaFoole's Avatar
Oddometer: 4,260
I'm interested....
"...when I handed the 40 ouncer to him, he got that far off stare that a cat gets when it just gets done licking its ass for the last 15". Yeah, THAT stare." -WTF-Over
"Don't come in here with your thoughtfulness, empathy, and reason... this is shit, up with which, I shall not put." -Boondoggle
DaFoole is offline   Reply With Quote
Old 03-06-2013, 07:32 PM   #16422
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,258
Originally Posted by DaFoole View Post
I'm interested....
I don't think it's the kind of bar you would be interested in.
Old 03-06-2013, 09:12 PM   #16423
FacePalm
D'oh!!!
FacePalm's Avatar
Oddometer: 25
Just figured I'd check in, let you all know what I've been up to...
Bike as it currently sits looks like this-
Since I picked her up in December have added
-Jesse Odyssey II's
-Fasst Flexx 15* Bars
-Vstream Sport/Tour screen
Started a thread on the SuperT forum detailing my farkles...
http://www.yamahasupertenere.com/index.php?topic=6751.0
Have ROX 2" anti-vibe risers waiting on the bench, currently adding Ride-on ADV long brake/clutch lines.
Skene P3+TS & IQ-175 on order. Plan to throw a Rigid light bar up front. Once done I can then start poppin' wheelies, or "riding the shaft" ala Pluric.
-More to come
FacePalm is offline   Reply With Quote
Old 03-06-2013, 09:24 PM   #16424
roarin calhoun
Oddometer: 385
Hee Hee gud'n. So true too.
I'm kinda slow & missed the zillion of pages on bash plates. What's a good one for the S10 that bolts to the frame,not the engine??? Thanks.
roarin calhoun is offline   Reply With Quote
Old 03-06-2013, 09:37 PM   #16425
snakebitten
Small Town Hick
Oddometer: 980
Frame mount is one of three:
Jaxons (Tabasco) (think Sherman Tank Armor)
Rumbux (Think Ranch Hand Truck bumpers)
JaumeV (Think Art)
XT1200Z BIGGEST Dirt Bike in the world
500 EXC Dirtiest Street Bike in the world
snakebitten is offline   Reply With Quote
Times are GMT -7.   It's 07:37 PM.
