Old 04-19-2013, 01:10 PM   #17176
Blue Mule
Persistent Slacker
Blue Mule's Avatar
Oddometer: 2,435
Originally Posted by sunquest View Post
Just got back from Panama on my VFR 2-up and purchased a Tenere on my return and looking for advice on cases knowing the question opens the door for opinion. 45L looks, I think to big as in to wide 35L a good compromise kind of looking at the
TraX 37-liter
Factory cases Look to small and delicate, a deeper case would lower the center of gravity. the 37 can be switched for 45 if needed. On my travel I noticed a fellow rider on a Tenere and asked the question in the last 2 month have you found anything you needed and don't have with you he replied" no don't think so " my answer " then I think you brought to much " TKS for any links or OP's D.C.
I got these, I really like them and am planning on picking up a set of the soft bags as well for shorter , more local rides, where locking and size wont matter. Looks wasn't a concern for Me, though i don't think they are completely fugly!
http://www.happy-trail.com/Departmen...0Z-Tenere.aspx
[url=http://www.flickr.com/photos/18007625@N04/8663000975/]
[url=http://www.flickr.com/photos/18007625@N04/8663004485/]
"The universe is wider than our views of it." - Henry David Thoreau
Blue Mule is offline   Reply With Quote
Old 04-19-2013, 02:41 PM   #17177
fredz43
Location: Illinois- land of straight, flat, boring roads.
Oddometer: 645
TraX 37-liter
Factory cases Look to small and delicate, a deeper case would lower the center of gravity. the 37 can be switched for 45 if needed. On my travel I noticed a fellow rider on a Tenere and asked the question in the last 2 month have you found anything you needed and dont have with you he replied" no dont think so " my answer " then I think you brought to much " TKS for any links or OP's D.C.
I have the Trax 37 and 45 combo and like that for longer trips when I tend to pack too much. I normally use the 37 on both sides for everyday rides. Also with their quick release racks, I can take the racks off in a minute if I won't be using any bags. 100% satisfied with this setup for over 20,000 miles.
Here is a friend's S10 with 37 L Trax on both sides.
fredz43 is offline   Reply With Quote
Old 04-19-2013, 02:57 PM   #17178
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,444
TraX 37-liter
If you live in a place where lane-splitting is legal check into the Holans. They hold a lot but fit very tight to the bike with a narrow profile.
twinrider is offline   Reply With Quote
Old 04-19-2013, 03:14 PM   #17179
fredz43
Oddometer: 645
The Holans are very good looking, well made bags also. As far as lane splitting, the ends of the OEM bars are about 38 inches wide, so if they will fit, most bags will fit. Here is a front view of the 37/47 Trax combo from the front, as the angle of the rear shot that I posted makes them look wider than they are.
Old 04-19-2013, 03:53 PM   #17180
ballheadknuckle
ballheadknuckle's Avatar
Oddometer: 135
Originally Posted by Whorepedo View Post
Is there any "over the speedo" gps mounts other than the Touratech & Madstad?
I saw the SW Motech mount but they dont list my gps and I havent heard back from my inquiry to them.
I like the location but I dont really care about the movable windscreen so the $150-ish price tag is steep.
Off-the-road has a plain GPS mounting bar: http://www.off-the-road.de/en/XT-120...XT-1200-Z.html
ballheadknuckle is offline   Reply With Quote
Old 04-19-2013, 03:59 PM   #17181
Wreckchecker
Ungeneer to broked stuff.
Oddometer: 2,802
I made mine for nothing and it's not hard if you can cut plastic and make 2 bends in it.
Flat piece of plastic, bent into a Z-shape. The forward downflange fits between the instrument pod and the mount. The pod is mounted with (I think) 3 sheetmetal-type screws so the downflange needs to have holes for the mounts and the electrical connector.
Super Tenere & WR250R, AMA, IBA
Wreckchecker is online now   Reply With Quote
Old 04-19-2013, 04:06 PM   #17182
Wreckchecker
Oddometer: 2,802
TraX 37-liter
Muffintop Industries is a small shop in South Dakota with great prices and the boxes are brick outhouse tough. You can get as small or big as you want if you don't like his stock offerings.
http://muffintopindustries.com/
I mounted mine on SW-Motech detacheable racks with fender washers and fiber lock nuts.
Old 04-19-2013, 04:29 PM   #17183
Whorepedo
Whorepedo's Avatar
Oddometer: 501
Originally Posted by frontiercat View Post
A fellow rider on the Super Ten pic page built one out of flat steel or aluminum plates against the side of the windscreen uprights. Looked very nice and factory.
http://advrider.com/forums/showpost....postcount=4505
That would be perfect! He should make those and sell them!
2000 Suzuki TLR; 2012 Yamaha Super Tenere; 2005 XT660R; 1993 TDM850; 1977 Kawi KE175
Whorepedo is offline   Reply With Quote
Old 04-19-2013, 04:32 PM   #17184
Whorepedo
Whorepedo's Avatar
Oddometer: 501
I've got a Touratech cradle and a 478 so I really need that bar to mount it to.
Old 04-19-2013, 05:35 PM   #17185
California
Motorcyclist
California's Avatar
Location: Lantana, TX...after 56 years in Carmel Valley, Ca.
Oddometer: 3,050
here's a picture of the rear end of mine. These are different sized Micatech bags, and a Trax top box. The panniers are sized so that the bike is equal width out from each side. The left pannier is 8.5" wide, the right pannier is 10.5" wide, and all mounted up, the bike is just under 40" wide.
btw, The Micatechs are very well built, and clearly a heavier grade of aluminum than the Trax bags I have on my WeeStrom. That having been said, I love the Trax bags. I'm still getting used to the Micatechs, but so far, I'm favorably impressed....
California, aka Leslie V Leslie.
Two roads diverged in a wood, and I
took the one less traveled by,
and that has made all the difference
California is online now   Reply With Quote
Old 04-19-2013, 06:00 PM   #17186
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,097
I went the KLR approach. Two pieces of angle with the rod welded betweeen them.
pluric is offline   Reply With Quote
Old 04-19-2013, 09:06 PM   #17187
tremor38
tremor38's Avatar
Oddometer: 1,460
Originally Posted by California View Post
Soooo, I've had the Tenere for a couple of weeks now, and put about 1500 miles on it, and...
1st. I'd like to thank Jim (aka Japaco) for farkleing the bike so well, that I can scarcely think of anything to do to it.
2nd. I was planning on keeping the WeeStrom until I was sure the Tenere would satisfy me enough that I wouldn't want to keep the Wee. I haven't even started it since getting the S10 , I haven't ridden it, have no desire to, and will clean it and put it up for sale this weekend.
3rd. WOW what a fantastic bike! Power is fantastic. Japako had done the reflash, installed the clutch override switch, arrow headers, and a Leo Vince can, and other than a surge occasionaly, it runs like a striped ass ape! I do have a little concern about the spokes on the front wheel, although I haven't had time to check them all. I get a little wobble once in a while when cornering aggressively. Is that spokes? Or is there something else I should be looking at?
4th. Good lord, did they underspring the rear of this thing, or what! I weigh 200, and when my wife and I went to the Hill country, even full preload was nowhere near enough. This will have to go to the top of the "to do" list
5th. It sure doesn't feel like it weighs 500 lbs! It's got Micatech bags, and I added a Trax top box, Givi engine guards, and cool custom highway pegs. Madstad bracket with cross bar for GPS mount! Fully loaded and two up, I never once felt anything but total contril, even in the slow, parking lot, u-turn type stuff, and even the dirt roads don't seem threatening.
In conclusion, if you don't have a Super Tenere yet, you don't know what you're missing................
Good to hear from yet another satisfied rider... but 'under sprung' after adding 200lb self and wife. Haha! Tell me you're kidding. :p
Sent from my SC-03E using Tapatalk 2
2011 Yamaha XT1200Z
tremor38 is offline   Reply With Quote
Old 04-19-2013, 09:10 PM   #17188
Whorepedo
Whorepedo's Avatar
Oddometer: 501
I picked up an MSR mount on the cheap that basically sits in the same place. I really want to put it up over the gages, though. This'll do for the time being.
Old 04-19-2013, 09:14 PM   #17189
snakebitten
Small Town Hick
Oddometer: 977
Hey California,
You are right, you got a Japako farkled bike. It was meticulously thought out.
But I don't think the seller, my friend, was a 2-up guy. So the suspension wasn't nearly as inadequate for him.
I too do a healthy amount of 2-up. (loaded like a pack mule) She was "fair" at first, with brand new suspenders. But with 24K on the clock, she is squatting bad now, regardless of preload.
But, since you got a great $$$$ deal for your Tenere, you should feel much better about throwing a few bucks at the ONLY thing left to do to yours.
A nice new rear shock, and at least a set of single rate springs for the forks.
Glad to hear you realize what you got.
XT1200Z BIGGEST Dirt Bike in the world
500 EXC Dirtiest Street Bike in the world
snakebitten is offline   Reply With Quote
Old 04-20-2013, 03:26 AM   #17190
PWRCRZR
Grumpy Old Bastard
PWRCRZR's Avatar
Oddometer: 7,643
Looks like it is time to get to know my new bike
It's like christmas around here, parts are starting to show up.
New K60's, Altrider crash bars, side stand foot, heated grips, fender extender.
I still have a set of Jesse bags and a madstad bracket on order..
PWRCRZR is offline   Reply With Quote
Times are GMT -7.   It's 07:22 AM.
