05-11-2012, 10:44 AM
#12211 | |
Ungeneer to broked stuff.
Oddometer: 1,842
![]() Now Boss - About all this paper on my desk.....
Super Tenere in black AMA, IBA June 2012 Maryland to Alaska: http://advrider.com/forums/showthread.php?t=796138 |
05-11-2012, 10:51 AM
#12212 |
Oddometer: 91
Hi guys! The headlight h7 connector has burned. Anyone knows of it can be' replaced? (only the connector)
http://www.flickr.com/photos/nordkapp55/ http://www.flickriver.com/photos/nordkapp55/ from 2010, November: Yamaha Super Ténéré XT1200Z |
05-11-2012, 10:52 AM
#12213 | |
Oddometer: 1,842
From the engineering aspect, it very well may work for two reasons. First, as somebody else mentioned, a designer would typically want a slightly richer mixture for starting, which is just what we are doing by turning out the one screw for the throttle body sync. Second, the ECU is typically as unencumbered as possible when starting a motor. The cool part is that you don't need a dyno to see if it works. Time a few passes through the bottom 3 gears or between two fixed points with the jumper, and several more passes without the jumper. The difference in averages will either be there or it won't. I'm sure somebody will start posting numbers soon.
05-11-2012, 10:54 AM
#12214 |
Oddometer: 1,842
Look REAL close at the wires going into the black sleeve and the insulation is probably deformed/shot. Yamaha has been replacing them on warranty and there's a thread about it in the Tenere forum.
05-11-2012, 11:03 AM
#12215 |
Oddometer: 91
Thanx ! I tried but i didn't find anything! Could you please link something about? Thanx again
http://www.flickr.com/photos/nordkapp55/ http://www.flickriver.com/photos/nordkapp55/ from 2010, November: Yamaha Super Ténéré XT1200Z Nordkapp55 screwed with this post 05-11-2012 at 11:11 AM |
05-11-2012, 12:06 PM
#12216 | |
Oddometer: 1,842
so paste the following into a Google search to find the now 16 page thread:Yamaha Super Tenere forum Cooked Headlight Harness And PLEASE post your failure at www.SAFERCAR.GOV While this is a link, it is to the NHTSA Office of Defect Investigations. If we can get enough of these, we stand a chance of a recall, although I am certain that Yamaha is already looking into the problem.
05-11-2012, 12:13 PM
#12217 |
Oddometer: 91
Thanx i've found it! Do you think that i can post My failure? (I'm from Italy)
05-11-2012, 12:17 PM
#12218 |
Oddometer: 1,842
haha My bad!
![]() Should still be a warranty item though.
05-11-2012, 01:25 PM
#12219 | |
Mentally Retired
Oddometer: 1,112
West - "Oeste Sanchez" |
05-11-2012, 01:30 PM
#12220 |
Oddometer: 282
I'm going to pick up my Tenere in an hour! This bike has literally 0 miles on the odometer.
I've broken in new engines before, but I'm not above learning new things so talk to me about your new bike break-in techniques. What do you do?
Ride to Coffee Coffee to Ride |
05-11-2012, 02:36 PM
#12221 |
All squint eyed&confused
Oddometer: 771
Break in
Owners manual basically says don't keep the RPMS at an excessive number for an extended period of time. Example: don't go from show room to a 2 hour drive interstate drive at 80mph! I have always been told by experienced riders/mechanics to make sure you do lost of compression breaking, along with variations in speed/rpm's. Compression breaking apparently helps to "seat" the piston rings!
2012 Yamaha Super Tenere' and Lovin it!
05-11-2012, 03:00 PM
#12222 | |
My S10 was already running really well with the PC.V and Autotune ,Arrow Headers, Leo Vince Can and DNA filter so the improvement was Good but the bike was already much improved over stock. Cheers Rick |
05-11-2012, 03:43 PM
#12223 |
WesternExplorer
Oddometer: 112
Clutch switch jumper
I did it last night and rode to work today. Can it be this simple. All the off idle stumble is gone. It pulls like it should off the line now. I did notice my fuel MPGs are down from 46 to 40 so I assume this some how take the lean out of it. I just don't understand why this works but it does. I will put it back and ride home tonight to see if the stumble returns.
05-11-2012, 05:24 PM
#12224 |
Oddometer: 23
I just went for another good ride and tried T mode this time. Before I jumpered the connector there was a pretty dramatic difference between T and S modes and now there is virtually no difference. I kept checking to see if it had switched itself back to S.
Weird. |
05-11-2012, 06:03 PM
#12225 | |
D S N
Oddometer: 271
http://www.yamahasupertenere.com/ind...80394#msg80394
I don't know where I'm going but I won't be late! |
