Old 02-01-2010, 07:36 PM   #1
One Less Harley OP
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,834
Wrenching on my R80 G/S, an ongoing therapy
1984 R80 G/S WB1034803E6362926
1) 05/6/86 Purchased New from Psycle Therapy, Columbus Ohio by B Grimes (Urbana Ohio).
2) 4/16/98 Purchase from Competition Accessories (Springfield Ohio) with 57,4557 miles, C. Roelling (Miamsburd, OH), for $1,500
3) Gunner65 purchased and only had it for 3hours
4) Lexington owner purchased it from inmate Gunner65
5) 09/11/2008 One Less Harley (KY) with 95,000 miles from a guy from Lexington KY, who didn't own it very long.
According to Gunner65 the bike has been to Alaska at least twice. Cosmetically challenged when I purchased it, mechanically very good and well maintained. Very clean oil oil pan w/ no sludge. Nice original example. Bike now has a R100GS front end w/ HH Race Tech Inserts, 4 pot Brembo, Taller 5th gear, top end rebuilt, Enduralast, repainted blue.
Links to miscellaneous post-
1) Death Wobble
2) Connecting Volt guage to G/S
3) Bosch Starter Repair, Bendix Replacement
4) Motor won't turn over, this is unusual-Starter related
5) Clutch Balance marks
6) Head job, rings, rod bearings-good post
7) Painting HPN tank (polyethlene)??, why not?
8) 320mm brake upgrade
9) Tanks to fit an R80 G/S
10) R80 G/S upside down brake arm conversion
11)
Fix for Acerbis (OMG) petcock, left and right ones now point the right way
12) Transmission rebuild mislabeled 17.5 degree primary gear
13)
BMW Performance School
14)
Trail Tech MR16 HID lights are crap, 2 lights 2 failures!!!
15) 4 Pot Brembo Caliper conversion for GS
16) Damned neutral switch again!!!
17) Airbox Engine Breather Modification
18) Happy Trails Top Mounting Bracket Fix
19) Page 3, Post #45 ring gear bearing replacement
20) Page 5, post #65 R100GS front end
21) Page 1, post #10 Flywheel Issues, no rivets
22) Float bowl leashed Sololobo's article
23) HH Race Tech R100GS fork inserts.
24) Final Drive Breather Hose
26) Carb jetting Changes and notes
27) Hanging Idle discussion
28)
Larger Foot Pegs from KTM
29) R80G/S to 2012 MOA Rally via the TAT
30) Float Bowl Leashes
So here's the old gal as purchased, notice the big honking headlights and angle irons for brackets.
...and here it is now.
One of this first things I did was drop the oil pan to check for gunk in the engine and check the oil pickup. I've heard these can loosen up. All was well inside along with changing all the fluids, that included the brake fluid.
Next on the project was to pull the tranny and lube the splines, plus since the rear frame was off why not powder coat it???
Then a custom muffler guard for the Sito Muffler out of plain metal rods.
Look here for link
http://www.advrider.com/forums/showthread.php?t=387232
Then some eyebrows for the large PIIA's as I was getting a glare from the top edge.
Then reinforcing stock racks for the Happy trails panniers. Gussets added.
And a rear bar, stood up to a good crash, but probably should be bigger.
Happy Trails bags mounted plus new paint on tank and side covers. I had the original blue tank scaned for a color match. This tank is from a R100GS with the seat tab cut off.
Cut down side cover for muffler and accessory plug added.
1st installment hope I haven't bored anyone w/ the repost!!
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 04-02-2015 at 09:00 AM
Old 02-01-2010, 08:14 PM   #2
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,515
Subscribed
In.
I wonder if there's any way for the Mod to "Join" your old posts to your new thread. I know Mods can do it. Perhaps if you get the info, Putts could do the heavy lifting. Just a thought.
T.
Infracaninophile is offline   Reply With Quote
Old 02-02-2010, 01:53 PM   #3
R12Battletub
nooblet
Oddometer: 325
I noticed you have the larger brake rotor in the later pictures. How do you like it? Did it make much of a difference?
Cheers, Gunther
R12Battletub is online now   Reply With Quote
Old 02-02-2010, 03:19 PM   #4
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,701
Cheers, Gunther
One Less
I went back to have a look and the "original" rotor on the standard looking carrier. It is quite interesting. It seems to be a floater or semi floater judging by the big buttons. Any idea what is was and where its from? Is it still around? Can I have it please?
Rucksta is offline   Reply With Quote
Old 02-02-2010, 03:22 PM   #5
One Less Harley OP
Oddometer: 4,834
320 MM brake upgrade
Instead of reposting what has already been discussed I will supply one picture from the post and a link to the discussion. I think this will work out best, not to mention easier!
For my post and pictures on the 320 mm brake upgrade look here...
http://www.advrider.com/forums/showthread.php?t=431606
or thoughts of adding a second disc brake to the G/S, check out link below-
http://www.advrider.com/forums/showthread.php?t=429709
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 02-02-2010 at 04:35 PM
Old 02-03-2010, 01:22 PM   #6
Beater
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,532
Nice. Keep it coming ...
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is offline   Reply With Quote
Old 02-03-2010, 04:35 PM   #7
One Less Harley OP
Oddometer: 4,834
If I get off my but and don't feel to guilty about not working, I'll post on the upside down brake lever and some post on replacing the drive and driven bearing on the final drive.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-03-2010, 04:36 PM   #8
One Less Harley OP
Oddometer: 4,834
Originally Posted by Rucksta
One Less
What is it that your are asking??? The original rotor is a "floater" the 320 has some laser cuts to allow for heat expansion. I'm keeping my original rotor.
Personally I like the 320mm conversion, I can now lock up the front wheel, does anyony really need a 48 piston front brake, just kidding about a 48 piston brake, but six piston seems a little overkill, maybe I'm not ridding hard enough or carrying that much weight.
Sololobo wasn't that impressed with the 320mm and stock caliper I think he has higher expectations.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 05-02-2010, 01:15 PM   #9
One Less Harley OP
Oddometer: 4,834
Silly me forgot I was trying to post my wrenching in one place, so to move this topic to where it needs to be----
R80 G/S, loose change sound
I've noticed an unusual noise from my R80G/S. It is noticed when shutting off the engine and at idle. Noise does not go away when pulling in clutch at idle.
Sounds like a metallic rattle, briefly when shut down, basically like loose change, clanging together. Not overly noisy and most people probably wouldn't notice.
I'm thinking it may be the starter, which had new bendix installed last year.
I've put a screwdriver up to the heads and the front cover and listened, no unusually noises there.
Recent work done, tranny installed, valve and ring job.
Any thoughts???
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 07-29-2010 at 07:04 PM
Old 05-02-2010, 01:48 PM   #10
One Less Harley OP
Oddometer: 4,834
I had suggestions to check the, exhaust collector, center stand, timing chain, and exhaust nuts.
So to investigate further on Thursday before leaving to the GA mountain rally, the starter was removed, because it seemed that the noise was coming from that area.
With the starter out the kick starter was used to rotate the engine, well the noise was definitely coming from the clutch area!!! Clang clang when turning the engine over with it and also when rocking the wheel back and forth in gear. Then I looked where the starter engages the ring gear....well then I saw and heard where the noise was coming from.
The ring gear is held on by 6 6mm allen head bolts, and these were backing out, not just one or two but all six, and two were missing the nuts on the back side.
The threads were ruined so replacements were sought out, mind you this is at 8 PM, and my only option for a 6mm-10mm socket head is Lowe's. Remember I'm really wanting to leave for the Ga Rally tomorrow at 7am.
A quick trip to Lowe's to source out 6 allen heads, I'm not optimistic. The airhead gods must have been watching, since THEY HAD WHAT i NEEDED!!!!
Now to get the allen head out and replace one at a time, while not dropping the nut inside. I got all 6 replaced and lightly threaded. Wow this is going well...don't you think!!!!
Of course you know the airhead gods have a twisted since of humor, don't you??? Now I proceed to tighten the 6 bolts down (Yes I used locktight). Some of you bright people know that this is going too well, right?
Ok. last two nuts to tighten down, yep then it happens, the 10 mm wrench slips on the final tightening and.....drops. Where you might ask? In a most unlikely spot., through the hole where the starter engages the ring gear, WELL FUCK!!!!!!!!! and a few more explicative s in disbelief. IT has dropped behind the ring gear and crank case housing, but I can still see the wrench.
So off to the toolbox to get a magnet to fish the wrench out. Got it.....but as the airhead gods would have it, the wrench snags something and drops, completely out of sight. It's now about 8:30 and there is only one thing to be done.....if i really want to go to the rally...pull the tranny to retrieve the wrench.
Ok- to make a long story short, the wrench was retrieved and the R80 was taken for a short road test at 12:00 that night!!
Ride to the rally was great, perfect temps and about 30 miles of mountain gravel roads.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 05-02-2010 at 06:54 PM
Old 05-02-2010, 03:13 PM   #11
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,082
Dude! Glad you found that noise.
Loose bolts on any rotating machinery bits bode no good. BTDT more than once in my life.
As for the wrench falling back in, I keep not one, but two of the telescoping magnets that fit into your shirt pocket protector when collapsed. Just in case I forget to put one back where they live on the side of the rollaround tool chest.
In addition I keep two pairs of forceps and two antique mechanical fingers in the bucket organizer of "ready tools" for most garage chores.
I also like your organizing your mods and stuff under one umbrella. I hadn't seen your pannier rack mods before, and like those. Keep it coming.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 05-02-2010, 03:15 PM   #12
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,287
I have never seen ring gears bolted to the clutch carrier. Every one I have here is riveted. Immediately at hand I have a 1st revision '82 or so Airhead and an Oilhead. I'd be looking for a new carrier.
Old 05-02-2010, 03:22 PM   #13
One Less Harley OP
Oddometer: 4,834
Hum NEVER??? The socket head were 10mm or maybe 11mm long. There was locktight on them. Your comments on riviting puzzle me as to why the ring gear was bolted in place. Is it bad that it's bolted in place??? IF so why???
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 05-02-2010, 03:38 PM   #14
AntonLargiader
Oddometer: 4,287
There were three '81-on carriers. The first was know for breaking and I don't know if that one was bolted or not. The second and third are riveted. Details are on Snowbum's site somewhere.
It could simply be that rivets are the correct fastener for this application.
Well, hypothetically I suppose bolts might come loose.
Old 05-02-2010, 04:22 PM   #15
One Less Harley OP
Oddometer: 4,834
hypothetically come loose, yep, that's for sure
BTW, Anton do you have a used one for sale, or you wanna trade for an input shaft. You might need one sometime.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Times are GMT -7.   It's 08:07 PM.
