Old 05-02-2010, 06:24 PM   #16
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,234
Originally Posted by One Less Harley
BTW, Anton do you have a used one for sale, or you wanna trade for an input shaft. You might need one sometime.
If you want the 2nd gen one I have, sure. Dunno what the difference is between that and 3rd gen, but I think it's minor. The big change was 1st to 2nd.
Sort of like the input shafts I guess. Yours is the late clutch spline but with the early fluting that needs the 519 gear.
Old 05-02-2010, 06:56 PM   #17
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,418
Richard...
you're a bad ass.!!! Hope you enjoyed the rally!!!!
Old 05-02-2010, 08:11 PM   #18
One Less Harley OP
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,695
It was either bust ass Thursday night or go to work on Friday......hum.....work or ride????
Found some nice roads, that is until we caught up to the road grater, which put a nice "fluff" on the gravel, made it nice and soft. Now I don't mind the rear wheel spinning up hill, but the curves and downhills were giving me fits.
Installed the Race Tech stiffer springs, which helped the front end some.
I've signed up for the BMW performance class in July, R1200, oh baby, or should I say Barbie (couldn't resist).
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 05-03-2010, 08:59 AM   #19
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,033
....snip.... oh baby, or should I say Barbie (couldn't resist).
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 05-10-2010, 08:21 PM   #20
One Less Harley OP
Oddometer: 4,695
Larger KTM footpegs made to fit.
A while back I was out ridding w/ the stock foot pegs and rubber inserts which become slippery when wet. So I removed the rubber and at least the pegs were grippy. The stock ones are quite narrow so I wanted to see what larger ones would be like, plus not wanting to spend a lot of money on pricey aftermarket ones. So to the garage w/ a cutoff tool, welder and some scrap metal.........
The top foot peg is the stock one, the lower is from a 1996 KTM 300MXC (aka POS) I once had. The swivel mount was too wide so it was cut off.
A new mount was made out of scrap flat stock
The metal was relieved to make 90 degree bends then welded up.
Holes were drilled into the new mount, sorry no pictures, then the KTM platform was situated to be close to the original footpeg location. Then tack welded in place, adjusted then welded completely.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 05-10-2010 at 08:30 PM
Old 05-10-2010, 09:31 PM   #21
hardwaregrrl
ignore list
Oddometer: 7,418
Nice....
I got me some moose racing open package pegs at cycle gear for 40 bucks!!! Welded new stops on and good to go!!!
Old 05-12-2010, 08:23 PM   #22
One Less Harley OP
Oddometer: 4,695
OEM Sump Gaurd, and Twin Headlight Earnie's Center Stand Guard
Newest addition to the G/S- Sump and center stand guards. I tried to get the OEM BMW center stand guard, but they were NLA, so The other option was the Twin Headlight Earnie one, which looks better and mounts better than the OEM, but the Earnies' sump guard was not a design I liked, the rigid attachment to the sump was unacceptable. I decided against it after seeing Hardware Girl's on the ST.
I purchased the sump guard, bolts, rubber spacers and washers from Chicago BMW and as luck would have it there were none in the USA, but there was ONE left in Germany. YEAH THAT'S RIGHT ONE.....ONE ...ONE, WHICH MEANS THAT THERE WILL BE NO MORE OEM ONES EVER!!!! I don't think they will be making any more ever again.
A shot of the 22mm headed bolts (note the shank on the bolt), rubber spacers, and flat washers which mount between the rubber and sump.
Another shot of how the mounts are assembled.
Another view of the guard.
A comparison shot between the little bitty stock guard, note the cooling vents, sure wish the big on had these!!
and it mounted, yes the guard is really close to the exhaust pipe, so close I had to loosen the exhaust clamp and fined nut and move the pipe a little to clear the guard.
A nice neat fit to the Twin headlight Earnie center stand guard.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 05-12-2010 at 08:48 PM
Old 05-12-2010, 08:52 PM   #23
hardwaregrrl
ignore list
Oddometer: 7,418
Hey Richard...
looks really nice. and sharp!
Old 05-12-2010, 09:06 PM   #24
One Less Harley OP
Oddometer: 4,695
BTW, no pictures here as I was in a hurry, but my front brake was a little soft so, since I had the caliper and master cylinder kits on hand, I rebuilt them a cople of days ago. Lots better pressure at the lever.
Pretty easy to do, just needed snap ring pliers to get the piston out of the MC, then for the calipers, compressed air to push out the pistons, (keep your fingers clear), a small pick to snag the piston seals. then just clean the parts well. The mastercylinde and calipers bores were in good shape so the master cylinder bore was lightly sanded and cleaned again, then seals and bores lubed with brake fluid upon assembly.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 05-12-2010 at 09:20 PM
Old 05-13-2010, 04:57 AM   #25
AntonLargiader
Oddometer: 4,234
... yes the guard is really close to the exhaust pipe
It's the wrong sump. That skid plate matches the smooth-bottom sump, not the early GS and /5 sump.
The smooth sump is slightly deeper: http://www.largiader.com/tech/oilpan/
Old 05-13-2010, 06:56 AM   #26
One Less Harley OP
Oddometer: 4,695
The Guard is #71-60-2-315-345, pictured on the R80G/S fiche. It also looks to fit the same as what Tom has on his G/S
http://www.advrider.com/forums/showt...453959&page=92
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 05-13-2010 at 07:03 AM
Old 05-13-2010, 08:18 AM   #27
AntonLargiader
Oddometer: 4,234
My mistake - I thought it was the GS plate, not the G/S plate. But if you run across a smooth-bottom sump (and matching pickup assembly) it might give you a bit more clearance. I'll measure the critical dimensions at some point.
Take care of it, you might have a collector's item!
Old 05-13-2010, 09:34 AM   #28
Gimmeslack
furthur
Gimmeslack's Avatar
Oddometer: 2,473
Are you saying G/S and GS skid plates are different? I always thought it was the same plate. I picked up a used one and it seems to fit fine. I was told it came off a GS by salvage dealer.
"If you hold a cat by the tail, you learn things you cannot learn any other way."
Twain
Gimmeslack is offline   Reply With Quote
Old 05-13-2010, 09:41 AM   #29
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,514
I thought they were the same as well. Looking at the fiche shows different part numbers. The G/S is now showing NLA. The GS is still purchasable. I thought the engine blocks were exactly the same? Is it that the GS has the crossover tube and therefore the PD skid plate is different?
Tom
Infracaninophile is offline   Reply With Quote
Old 05-13-2010, 10:49 AM   #30
One Less Harley OP
Oddometer: 4,695
If I see a GS and/or GSPD at the European Rally this weekend I'll take some picts....as I'm curious now.
According to the BMW fiche-sump guard #'s
88-90 R100GSPD p/n 51-47-2-315-392
88-90 R100GS p/n 71-60-2-315-345
88-92 R80GS p/n 71-60-2-315-345
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 05-13-2010 at 10:59 AM
Times are GMT -7.   It's 05:39 PM.
