Old 05-13-2010, 10:29 AM   #31
AntonLargiader
AntonLargiader's Avatar
Oddometer: 3,473
MAX shows a pic of the GS plate. Narrower in the back, no cutout for the drain plug (makes sense as the smooth sump has a rear-facing drain). Most likely the difference originated with the different centerstand on the GS. Don't know if it's shaped differently around the exhaust or anything.
I don't see why you wouldn't be able to retrofit the GS system to the G/S. System being plate, sump and pickup.
EDIT: actually I don't think it is narrower.
Old 05-13-2010, 11:08 AM   #32
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,506
I have both a 81 G/S and a 93 GSPD in the garage. I can measure both and see what the differences are this weekend. Visually they look exactly the same.
Tom
Infracaninophile is offline   Reply With Quote
Old 06-07-2010, 07:57 PM   #33
One Less Harley OP
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 3,923
I have been doing some jetting changes on the G/S, the bike was jetted with 135MJ/ 45 Idle jet needle position unknown, millage was OK, 42-44 on back roads under 75mph, but starting from cold was bad, as bike wanted to die when giving throttle until warmed up for about a minute.
here's a list of jets and MPG figures for the bike.
Note- I am not heavy on the throttle, and ride fairly sedate. Sometimes spirited but not extremely hard on it.
Stock Carb Settings
Main Jet 135 (150 stock, 130 stock for 1981)
Idle Jet 45 (45 stock for 1981,40 for 83-86)
needle Jet 266 (stock) , needle has about 15,000 miles
Needle clip 2nd from top (3rd stock)
Needle 46-241 (46-251 for 1981)
Main jet Idle Jet Speed/Conditions Needle Position from top MPG Date/notes
150 45 65-70 bottom 38
150 45 60-70 bottom 38
135 45 -75 3rd from top 42-44 choke not very effective
150 45 60-70 bottom 38.9
150 40 60-65 rain bottom 41
150 40 55-60 bottom 39.7
142 40 55-60 3rd from top 44.02
142 40 55-60 3rd from top 45
135 45
1st from top 38
2.68 needle jet, cold start BETTER
8/16/2012, plugs dark, runs great, slight hesitation at constant speed of 50plus
135/ 45/ 3rd from top / 38 mpg/ runs great but plus mostly black,2.68 needle jet/ electrode a little lighter (4/10/2013)
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 04-10-2013 at 06:25 PM
Old 06-07-2010, 09:35 PM   #34
Beemerguru
Beemerguru...G/S guy
Beemerguru's Avatar
Oddometer: 640
Try a 145 and needle on 3rd position and see what happens.
Greg Hutchinson
BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club
http://gregsgssite.shutterfly.com/
Beemerguru is offline   Reply With Quote
Old 06-08-2010, 05:35 AM   #35
One Less Harley OP
Oddometer: 3,923
I'll run some more gas though it to get some average mpg figures. Then try the 145's, I would expect the mileage to drop though.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 06-08-2010, 07:28 AM   #36
Rucksta
Chronic Noob
Rucksta's Avatar
Oddometer: 2,302
Pretty close
Main 145
Needle 2.64 position 4
Needle jet #46-241
Idle jet 45
Idle air jet dia 1
claimed 47.0 mpg @ 60mph (with a pointy headed anorexic midget rider)
This was the spec for a non US G/S with no polution control.
I think you must be getting pretty close.
I never could work out what they meant by position 4 as my needles only had 3 rings.
If the Earth is flat why are my tyres round?
Rucksta is offline   Reply With Quote
Old 06-08-2010, 09:04 AM   #37
Beemerguru
Beemerguru's Avatar
Oddometer: 640
I use the european specs for the 800 engines after the emission plumbing is gone. Breathes better, runs cooler, heads last longer and decent mpg if you keep it under 70mph
Greg Hutchinson
Old 06-08-2010, 10:06 AM   #38
One Less Harley OP
Oddometer: 3,923
does that mean your using the 145 MJ as specd buy rucksta??? Should have mentioned that the air injection has been removed. No other mods. Fresh top end and new rings.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 06-08-2010, 11:16 AM   #39
Caddy82rats
Caddy82rats's Avatar
Oddometer: 1,077
I've got 135 with asymatrical inlet (Euro BMW upgrade)
Better milerage, better low end response.
Caddy82rats is offline   Reply With Quote
Old 06-08-2010, 11:25 AM   #40
AntonLargiader
Oddometer: 3,473
There was a SIB to implement that here, also. AFAICT, every bike runs better with the asymmetric intakes and most of them have probably been converted. It can make a dramatic difference on the R80!
Old 06-08-2010, 04:16 PM   #41
One Less Harley OP
Oddometer: 3,923
Vision X Lights
I had recently purchased a set of hid lights from Trail Tech and was less than impressed w/ them, both quit working in a VERY short time.
So I looked into another option- ended up going for the Vision X LED(same as the Denali lights) lights w/ the Euro lens, which is between a spot and flood light (wish there was spot light version). The light output is very good, very white light and very brite. The light pattern fills in up close the empty spots in the stock high beam lighting, but don't reach out any further than the stock H4 (65w high). There is no beam pattern to the light and I assume glare in rain or fog would be extreme and probably excessive.
Construction of the lights are top notch, very nice and heavy cast aluminum. The light mount very solidly to the mounts and other lights can be mounted together by means of a very nice aluminum block. Stainless bolts and u shape bracket. The wiring harness has a very nice water proof pig tail.
I also used a Piaa wiring harness ( which I already had) Piaa mounting bracket to attach to the crash bars, this swivels for differing mount locations. The lights are switched (on/off) with the high beam only.
PIAA Mount
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 06-08-2010 at 04:24 PM
Old 06-09-2010, 08:46 AM   #42
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,238
there is a spot version though their page admittedly says flood and spot in various places on that page.
i'm waiting for some night shots with the lights on.
bmwblake is offline   Reply With Quote
Old 06-09-2010, 10:56 AM   #43
One Less Harley OP
Oddometer: 3,923
Blake , I called them and they had a spot lense available, $7 each. I ordered a set.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 06-09-2010, 03:18 PM   #44
One Less Harley OP
Oddometer: 3,923
here's a writeup link to the vision x lights. I'll post my impressions of the spot lense over the euro pattern.
http://www.advrider.com/forums/showt...=vision+lights
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 06-22-2010, 04:18 PM   #45
One Less Harley OP
Oddometer: 3,923
R80 G/S ring gear bearing replacement
Replacing final drive bearings on a R80 G/S.
BMW Part #’s
5) p/n 33121241938 shaft seal (85X110X10)
4) p/n 33121242210 out put ball bearing (85X120X18)
2) p/n 33121241682 needle bearing dive bearing (35X50X20)
13) p/n 33112311097 gasket
p/n 07119906328 (two) brake pivot o-rings
Fig 1
Fig 2
Fig 3
First clean mud (this is a G/S) from final drive, rear wheel and mono lever. Loosen three nuts holding rear wheel and back off adjusting rod to the brakes, then remove wheel. Remove brake shoes and just to make things easier keep springs on shoes, also remove circlip (#18). Put these in a safe spot along with other parts, which will be removed later. It’s helpful to put parts in relative location for ease or reassembly.
Fig 4
Remove drain plug (#9) for drain final drive. At this time clean off the drain plug magnet. Now clean the inner part of the final drive with brake cleaner and a small brush. Remove the brake rod adjuster (wing nut). For the brake arm, make a scribe mark on the brake arm pivot pin where the arm is split. This will aide in relocating the arm and pivot pin on reassembly. Remove pinch bolt and pointer. Then tap the brake cam out towards the left side of the bike (while sitting on the bike) again make sure to keep parts grouped together so no to mix them up later.
Fig 5
Fig 6
Final drive cover removal-The remove the 8 final drive cover bolts and wave washers in Fig 5, and then insert two 5x30mm bolts as pictured in Fig 6. Then heat up the housing cover around the perimeter of the oil seal with a heat gun, this is to make removing the cover easier as the out put bearing is press fit into the cover.
Tighten each of the 5x30 mm bolts, equal amounts, don’t over tighten one side over the other, as you want to pull the housing cover off square and not angled. The bolts will be tightened down almost to their full length before the cover is released from brake pivot tube (fig1, #25). Make sure to keep one hand on the cover at all times to catch it when the bearing is released.
In order to remove the large roller bearing (fig 1, #4) from the outer cover screw in the tap lightly with a copper hammer around the perimeter of the flat ring gear surface (Fig 6) until the cover is free of the ring gear and bearing. Once free remove the cover and ring gear from final drive. Again make sure to hold onto the cover and be careful not to damage the spacers inside the outer cover.
Fig 7
Be careful as the driven bearing has a shim (Fig 7) for the ring gear. It is a brass like ring, DO NOT BEND OR LOOSE THIS. Best and safest place for it is in it’s current location.
Fig 8
Seal removal-Look inside the cover plate and be careful not to loose or bend the shims (fig 8) for the out put bearing. Remove shims and store in a safe place. Clean the cover in mineral spirits and scrape gasket, leaving the flange clean. Note that seal (Fig 1 #5) protrudes slightly from the face of the cover; make a mental note of the amount. Then remove the large seal with a hammer and punch. Once removed clean and oil the sealing surface.
Put cover gasket side down on a flat clean surface and lightly oil outside edge of seal,
put it in place on outer cover and around the circumference GENLTY tap new seal in place. DO NOT force, the key is to work it slowly, as not to bend the seal. Keep tapping seal until the amount of protrusion is the same as noted earlier and equal all the way around.
Fig 9
Fig 10
Out put bearing removal- Note I don’t have the appropriate three jaw bearing puller for this so be patient on this. Heat the inner race with a heat gun, then with a set of chisels work on hammering the race off. Work the chisels at 180 degrees of each other, then at 90 degrees. Keep tapping the chisels in place working them opposite of each other, you may have to get larger chisels or add metal shims next to the ring gear (Fig 10) as the spacing between the race and ring gear gets larger. Be very careful not to mar the ring gear surface. Don’t do this on concrete, or where you may drop the gear as it might be damaged. Removal will take time but it will come loose.
Fig 11
To remove the inner driven bearing race (Fig 1#2) on the ring gear a dremel tool and small cutoff wheel works very easily. See small cut in Fig11. Just make sure not to cut completely though bearing race, as you don’t want to damage the ring gear surface. Proceed slowly in cutting but stop when almost through the shell. Then tap the cut with a chisel and the race will spring open for easy removal. Save the inner race for reinstallation of the new race. Clean ring gear thoroughly.
Remove the brass shim and protector plate from the drive housing (Fig 7).
Fig 12 Note small hole in bearing shell
Fig 13
I found it easier to remove the needle bearings and cage first, and make note of the small hole in the outer race. Use an inner bearing removal tool to remove outer race of the driven bearing (Fig 13), which is inside the housing. Remove any remaining gasket and sealant with a scraper (be careful not to mare the sealing surface) and solvent. Wipe down and clean inner housing of all oil, also inspect gears for wear.
Fig 14
Fig 15
Chill ring gear in freezer and with a heat gun heat the inner race of the driven bearing. Lightly oil the surface of the ring gear. Tap race into position, and use the old cut race (fig 11) to tap it completely home as in Fig 15. Make sure the race is seated completely on the ring gear flange.
Take note of the hole in the bearing race and line up as in Fig 12. Use bearing driver tool pictured in Fig 14 to install outer race and needle bearings in the final drive housing. Use appropriate size tool that rest on the outer race, as you don’t want to damage the needle bearings or cage. Install protector plate (Fig 7), Lightly oil brass shim and place in position.
It is best to use a hydraulic press here, because if the bearing isn’t seated fully the endplay will not be adjusted correctly. Place ring gear in freezer and heat the output bearing (Fig 1 #4) with a heat gun, lightly oil ring gear surface, then press bearing into place. Make sure it is fully seated.
Now all the hard things are done, the rest is easy!!!!!
Lightly oil ring gear where it contacts the outer cover seal. Place ring gear in housing make sure that the driven gear bushing (fig 7) is in the correct location. You don’t want to damage it. Put a light coat of Yamabond (Harley Davidson High-performance grey or Permatex #2 works well too) to both sides of outer cover gasket (fig 2 #13). Place gasket in housing, put cover in place and tighten cover bolts slowly and evenly tightening alternating bolts (make sure to rotate the ring gear as the gear teeth need to mesh tot he pinion gear and not get press on two gears, teeth need to slide past each other) until cover bottoms out, torque bolts to 13 ft.-lbs.
Oil and replace two rear brake cam pivot o-rings, install brake lever arm making sure that the split section of the arm lines up with the scribe mark made earlier. Don’t forget the pointer, which goes between the socket head bolt and arm.
Install circlip (fig 2 #7) onto the left brake pin. With an clean cloth wipe brake shoes and sand with sand paper (100 grit works fine), just enough to scratch off the surface. Then install springs to the shoes then shoes to the final drive. Install rear brake arm. Replace wheel and torque three lug nuts to 62 ft.-lbs. Then adjust rear brake rod so rear pedal travel is 25mm.
Fill final drive with 350cc GL5 SAE 80w/90. Now take your G/S for a test ride and double check your work, checking brakes for adjustment, listening for any noises and or vibrations. You might want to check after 20-30 miles the final drive for leaks, just in case.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 06-22-2010 at 04:24 PM
Times are GMT -7.   It's 09:27 PM.
