Old 01-15-2012, 11:42 AM   #106
One Less Harley OP
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,744
Pushrod seals leaking
Not in a rush here took about 1 1/2 hours to do one side, but just taking my time.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 01-15-2012, 06:46 PM   #107
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,862
dont forget the circlip. Just saying.
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 01-15-2012, 07:12 PM   #108
One Less Harley OP
Oddometer: 4,744
circlip...what circlip
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 01-15-2012, 07:45 PM   #109
_cy_
Oddometer: 6,330
just found this thread... thanks for sharing
Old 01-15-2012, 07:52 PM   #110
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,862
Old 01-17-2012, 12:36 AM   #111
sonnyboy
sonnyboy's Avatar
Oddometer: 312
Nice read and advice
sonnyboy is offline   Reply With Quote
Old 04-13-2012, 10:45 AM   #112
SPO
Oddometer: 150
$5000? That poor lamb!
SPO is offline   Reply With Quote
Old 05-28-2012, 09:43 AM   #113
One Less Harley OP
Oddometer: 4,744
Realized I didn't have any after pictures of the old girl, so here it is w/o the big HPN tank all purtied up with the stock little tank and coffin windscreen.
Skinny w/ big jugs...what's not to like.........
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 05-28-2012 at 06:27 PM
Old 05-28-2012, 07:54 PM   #114
Freeagain
Oddometer: 32
Twins
Hi One Less,
Bike looks great. As I said, pretty much a twin of mine - down the the K60 scouts!
I would love your thoughts on my engine noise thread if you have a minute.
Thanks,
Toby
Freeagain is offline   Reply With Quote
Old 05-31-2012, 08:44 AM   #115
One Less Harley OP
Oddometer: 4,744
Side Stand lengthening
With the GS front end which is something like 2 inches longer than the G/S, the bike has been leaned over too much. A ST side stand was obtained from Hardwaregirl. Surprisingly it's the same length as the G/S.
So 2 inches were added to the end along with another larger and gusseted fork. There is an extra hole added to the gusset. This is just in case the springs break or get knocked off and allow a nice point to tie the thing up.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 06-01-2012 at 08:50 AM
Old 07-25-2012, 04:27 PM   #116
One Less Harley OP
Oddometer: 4,744
Been installing the HH Race tech forks (info on forks), and need to relocate the turn signals as the fork caps won't hold the turn signal mounts, so I purchased brackets from Memphis Shades (ebay had best price) and turn signals from China which are supposed to fit the F650 again from ebay.
The bracket worked perfect, but I had to make a small backer plate. One bad thing about the bracket is the mounting screws are SAE.
Volt meter mounted w/ angle bracket.
Front view.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 07-26-2012 at 07:15 AM
Old 07-27-2012, 01:17 PM   #117
One Less Harley OP
Oddometer: 4,744
Kind of lost a float bowl on the TAT.
so made the carb leashes...
More info on leashes here.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 07-27-2012 at 01:42 PM
Old 09-03-2012, 06:13 PM   #118
One Less Harley OP
Oddometer: 4,744
Final Drive breather Hose
Info on the Final Drive Breather hose (here).
Hose Routing-
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 09-04-2012, 07:32 AM   #119
Prutser
Prutser's Avatar
Oddometer: 1,017
I use a ty-rap to zip the leashes to the shackle. Have seen some guys losing the shackle it self with the float bowl hanging on the leash.
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is offline   Reply With Quote
Old 09-06-2012, 04:15 PM   #120
One Less Harley OP
Oddometer: 4,744
Currently working on getting a spare set of wheels. I've located and purchased a rear wheel from Germany. There were three available, but only two were worth consideration. One had a very nice looking brake surface but appeared to have a slight grove, another was a little rusty and looked questionable. Then there was this one.
The brake surface had been sanded some, but no apparent groves in photo. The drum currently on the bike is worn, and most likely excessively.
Plus I needed a front hub from a R100GS. I figured finding a hub only would prove difficult. Placed a few want adds and called around, found three, an individual ($150), Recycle ($206) and Woody's Wheel Works ($350 refurbished). I purchased the one from the individual, but it will need to be bead blasted then laced to a tube type Excel rim. Just like what was done before by Woody's Wheel Works. One BAD ASS WHEEL. This is what it will look like.
Since I have the GS front, and wanted to run a tube type rim, more mentioned on that in earlier post on this thread. It will be nice to have a two sets of wheels with road tires and off road tires!! No problems pulling the rotor off the front wheel with the wheel change. Reason not to run different rotors is so the brakes won't need to bead in. Not an option w/ the rear wheel set up though.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 09-06-2012 at 04:28 PM
Times are GMT -7.   It's 05:06 PM.
