Old 02-01-2010, 11:20 PM   #1
Steve G. OP
Steve G.'s Avatar
Oddometer: 6,872
R100GS---Avon Gripster vs Avon Distanzia
I've had good luck with the Gripsters, but found they wear out faster than I like. Wondering if I can get any feedback of user of the Distanzia tire. Thank a bunch!!
Steve
Steve G. is offline   Reply With Quote
Old 02-02-2010, 12:30 AM   #2
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,476
Gripsters last pretty well for a DS tire but not as long as Distanzias. Folks regularly get 10k+ out of a rear. I got 12k out of my last rear but I did a few thousand miles on dirt. There's always a downside-Distanzias regularly rank the lowest in wet asphalt performance.
http://www.advrider.com/forums/showt...light=shootout
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 02-02-2010, 05:56 AM   #3
Martian
Oddometer: 1,105
ALL tires wear faster than I'd like them to!
Tom
'93 R100R
'02 F650GS sold)
'93 R100GSPD(sold)
http://frommars.smugmug.com
Martian is offline   Reply With Quote
Old 02-02-2010, 07:05 AM   #4
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,468
It took me 15k+ miles to make my distanzia look like this, but in retrospect I may have taken it a bit too far. It was paper thin in the center when I took it off. They handle great on pavement, wet or dry, and good enough in the gravel. They actually work better in the sand than a knobby.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 02-02-2010, 05:52 PM   #5
duhgee
Oddometer: 232
I used Distanzia's for 12K km this past spring. I kept them underinflated (not intentionally), so if properly inflated I figure I could've kept them for up to 15K. I was mostly on road, a bit in rain, and that was okay. I didn't like them much at all for mud, but on sand they were okay. Overall, I think I'll get them again for mostly road (90% paved, 10% gravel) riding, and stick with TKC's for gravel/dirt/mud/sand.
'08 BMW R1200GSA
duhgee is offline   Reply With Quote
Old 02-02-2010, 07:55 PM   #6
Beemerboff
Oddometer: 2,306
I like Distanzas best out of the bunch of 90/10 or 75/25 tires.
They are easily the best on black top, and at road pressures on gravel tracks as good as the others are with half the air let out.
They are wearing evenly front to rear, not much scalloping on the front, and at 6000 km look like they have at least another 1000 km in them.
Which is around 25 % more than I get from the opositon.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff screwed with this post 02-04-2010 at 02:27 AM
Beemerboff is offline   Reply With Quote
Old 02-03-2010, 08:24 PM   #7
Kerley
Oddometer: 31
I may be off track by comparing a KLR, but I just got 12,500 miles out of my rear Gripster.
Kerley is offline   Reply With Quote
Old 02-03-2010, 09:02 PM   #8
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,298
Man, if you don't have the time or the cash to swap out tires on your big Alaska trip, or whatever, the Distanzias kick butt. 10k out of mine, maybe 70 % on slab. They really aren't bad in the rain on asphalt, and not too bad in the mud!!!
muddown
hardwaregrrl screwed with this post 02-04-2010 at 07:52 AM
Old 02-03-2010, 09:02 PM   #9
Steve G. OP
Steve G.'s Avatar
Oddometer: 6,872
That's pretty darn good!!
Steve
Old 02-04-2010, 02:39 AM   #10
Beemerboff
Oddometer: 2,306
The only tires I get the same distance out of as most other folks are the the Pilot Powers on my VFR - probably because I am not pushing them or the bike anywhere anywhere near their limit.
Most of my riding is on my Beemers is on bumpy, slippery spray seal back roads or loose gravel roads, and I have just got used to the wheels moving around.
The VFR gets the fast main road blasts and I am not good enough to get it anywhere near its limits.
Old 02-04-2010, 08:14 AM   #11
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,513
I can't see how people get more than 6K out of any tire. I've never been able to achieve that on any tire on any bike in my entire life. And yes, I religiously check my tire pressure and don't ride 2-up very often. Maybe I need an easier throttle hand or something.
T.
Infracaninophile is offline   Reply With Quote
Old 02-04-2010, 11:42 AM   #12
borg
Oddometer: 123
I find the comments about Distanzias being just "OK" in the rain interesting having commuted quite happily all winter using them on my GSPD. Admittedly I've been swapping between the PD and an F650 Dakar shod with TKC-80s so it might be the Distanzias are simply shining in comparison.
Oh yeah, I commute into Seattle on the ferry system so I get a lot time riding in the rain.
Steve
borg is offline   Reply With Quote
Old 02-04-2010, 05:08 PM   #13
Beemerboff
Oddometer: 2,306
I havent found the Distanza to be bad in the wet, no worse than their competitors and a mile ahead of any of the semi knobbies like Saharas and Enduros.
Old 02-04-2010, 09:57 PM   #14
SUVslayer
SUVslayer's Avatar
Oddometer: 781
muddown
Kinda funny you use this pic to promote their traction!
I have to say, I'm with Infra on this. Tires just wear out after 5k at most. Wish I got more, but there it is.
And my .02... go for TKCs. Any offroading and you'll be happy you got them, and they are very good on the street.
SUVslayer is offline   Reply With Quote
Old 02-04-2010, 10:34 PM   #15
Tripletreat
Oddometer: 566
Avon Gripsters/Distanzas
I've run both the above referenced tires on my 1988GS virtually since it was new (very first tires were Metzlers, if I recall). I'd say you'll be happy with either design on a GS. I believe the Distanza has a higher load rating. I found that tire to make more noise on the road; I believe the tread blocks are spaced more widely, hence on pavement is doesn't seem so smooth as the Gripster. At higher speeds its probably a wash. As I noted, I've run Avons for many, many years and found Avon customer service to be expemplary.
Tripletreat is offline   Reply With Quote
Times are GMT -7.   It's 05:59 AM.
