Old 02-02-2010, 01:11 AM   #1
tropsove OP
SPIRITUAL ADVISOR
Oddometer: 20
950se Wiring Diagram
Has anyone got a wiring diagram for a 950se uk spec. I'm trying to fit an on/off switch for the lights as at present they come on when the ignition is turned on. If the weather's cold the battery can struggle turning over the engine and powering the lights at the same time. Also I've got an alarm fitted which doesn't help.
Cheers
tropsove is offline   Reply With Quote
Old 02-02-2010, 01:50 AM   #2
galbo950
galbo950's Avatar
Oddometer: 588
What switch block does it have?? If its the same as the Aust switch block its easy enough to modify the switch so that it has an off position. The Oz version has the EXC switch block, all you need to do is push the switch hard enough to the off position whilst you gently lever the switch mech's opening. Once you have done this it will expose a little plastic tag om the switch that you need to cut off, this will enable the switch to move between the off - low beam - high beam positions. I know this as I did it to my SE. Hope that helps.
galbo950 is offline   Reply With Quote
Old 02-02-2010, 02:38 AM   #3
Bronx
Bronx
Bronx's Avatar
Oddometer: 1,448
SE Wiring Diagrams
Cheers
I just sent you some information via PM that may help
Bruce
KTM 950 SE
KTM 625 SXC
http://www.advrider.com/forums/showthread.php?t=596286
http://www.advrider.com/forums/showthread.php?t=561584
If you don't get lost it is not an adventure .
Bronx is offline   Reply With Quote
Old 02-02-2010, 08:49 AM   #4
Peanuts
Peanuts's Avatar
Location: Beautiful but often rainy North Yorkshire, UK
Oddometer: 1,733
I have a pdf wiring diagram. PM me an email address and I will get it to you :)
Peanuts is online now   Reply With Quote
Old 02-03-2010, 12:09 AM   #5
TrentW
MMmmmm....
TrentW's Avatar
Oddometer: 88
Originally Posted by galbo950
All you need to do is push the switch hard enough to the off position whilst you gently lever the switch mech's opening. Once you have done this it will expose a little plastic tag om the switch that you need to cut off, this will enable the switch to move between the off - low beam - high beam positions. I know this as I did it to my SE. Hope that helps.
+1
Works like a charm...
TrentW is offline   Reply With Quote
Old 02-03-2010, 06:39 AM   #6
tropsove OP
SPIRITUAL ADVISOR
Oddometer: 20
Thanks guys for the help, it was literally a 10 sec job.
Cheers
Graeme
Old 05-13-2012, 05:37 PM   #7
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,976
Question
Anyone still have this handy???
I only have the ADV version handy here.
Please email me if you do.
Thanks,
craig
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 05-14-2012, 08:44 AM   #8
Crowley
Crowley's Avatar
Oddometer: 56
Thanks,
craig
Mail sent -
Crowley is offline   Reply With Quote
Old 05-14-2012, 09:53 AM   #9
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,976
thanks!
all set, now to try and fix the problem.
Old 05-24-2012, 12:31 PM   #10
ABYSS
KTM
Oddometer: 1,198
Is there sitll a need
I still have paper and electronic which do you prefer???
Every question in life has an answer of YES OR NO
Maybe = NO
Keep life simple and enjoy it!
ABYSS is offline   Reply With Quote
Old 05-24-2012, 04:18 PM   #11
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,976
Thanks,
I guess with all the off road. A relay broke off the wiring. Found it, stole one from a spare harness and good to go!
Fixed in time to hit the trails. This bike is so much fun. Light like my old LC4 640, but powerful and smooth. For seek and destroy missions, this is the machine.
Old 04-13-2013, 05:10 PM   #12
Dean74
Oddometer: 11
950se wiring diagram needed
hi all,
looking around for a wiring diagram for my se, and found this thread. Does anyone still have this diagram? (specifically lighting if you have it in different parts).
cheers,
dean
www.motodino.net
www.donkeyandthemule.com.au
Dean74 is offline   Reply With Quote
Old 04-14-2013, 12:58 AM   #13
TrentW
MMmmmm....
TrentW's Avatar
Oddometer: 88
PM Sent
Old 05-20-2013, 01:03 PM   #14
ToddLite
ToddLite's Avatar
Oddometer: 107
little help?
Sorry to be a bother to the community but can anyone here hook me up with a copy of the wiring diagram too? I promise to pay it forward.
I have a US spec bike but it looks like the PO put the EU spec light switch on my '07... although it currently does nothing... trying to figure out if I can tie my Rigid LED's into that switch mechanism somehow.
Can anyone out there lend a hand?
ToddLite is offline   Reply With Quote
Old 05-20-2013, 01:30 PM   #15
Peanuts
Peanuts's Avatar
Oddometer: 1,733
https://www.dropbox.com/s/af000j2ti5...%20diagram.pdf
Times are GMT -7.   It's 12:03 PM.
