Old 02-13-2010, 04:26 AM   #91
hattah79
hattah79's Avatar
Oddometer: 934
confused
When was the last year the 625 SXC was sold in Australia
Looked at one today 2007
I thought the SXC did not have oil in front frame tube like older 640
Has a filler and and oil lines at top of tube Also has the "spin on"oil filter
Confused
hattah79 is offline   Reply With Quote
Old 02-13-2010, 01:45 PM   #92
trussell
trussell's Avatar
Oddometer: 397
sxc
the last of the SXC's were plated 2007, from what i could tell when i was buying my bike, all the same bikes in a model range were plated at the same time, ie 04/07 for the SXC (Ibought my SXC new in July 08), and EXC were later in the year, around august, but then were called the next year model, ie made in 07 and called an 08.
I am not 100% sure about the oil filter, I know my 07 has the two oil filters, and has an oil capacity of 2.1 litres, which includes, 1.4 in the gearbox and then 700ml in the frame.
An added bonus of getting the 07 model, apart from the unreal deals they were doing do to the release of the 690's, was the cush drive, the 06 and previous did not have it, but they offered a factory deal if you wanted to upgrade.
they are certainly a very cost effective bike when you weigh up the cost of a 690 onroad, I think for the next few years the SXC will hold its own as far as resale goes as the demand seems to be fairly high.
trussell is offline   Reply With Quote
Old 02-13-2010, 11:27 PM   #93
rowdy_im
KTM 625 Snowy Mountains
rowdy_im's Avatar
Oddometer: 378
I brought mine new in Dec 2007 but the comp plate said it was made in Sept 06, must be a slow boat from Austria
mine has the cush drive hub
Rowdy
rowdy_im is offline   Reply With Quote
Old 02-14-2010, 01:26 AM   #94
Aussie Steve
Aussie Steve's Avatar
Oddometer: 1,390
Confused
I think you may want to check your sources of info. I am not sure but didnt all the aussie 625s come with oil in frame? I think it was the US ones which didnt (they also got that 625 before we did).
Aussie Steve is offline   Reply With Quote
Old 02-14-2010, 04:01 PM   #95
BigM
Hello :-)
Oddometer: 766
Does anyone know if the 05-07 are identical? I thought they were?
I have an 06, no free cush hub for me :(
Also has oil in frame and spin on filter, IIRC all Ozzie ones did.
Prices for these bikes seem to be holding their own very well.
Anyway after I broke mine, I just got my new one all sorted
Old wheel -
standard spokes,
standard hub,
standard nipples
standard excel rim (2.15inch)
standard 1/3rd gone 60/40 road/trail tire (Michelin T63),
standard tube with rim lock)
weighs in at 13.5Kg
Thats with Aluminum sprocket and brake disc still attached.
New wheel -
thicker 5mm stainless spokes,
stainless nipples
cush hub,
double stamped signature series excel rim (2.5inch)
5ply and 4 play brand new Michelin Desert,
ultra heavy duty tube with rim lock)
weighs in at 15Kg.
Not a great deal of difference, 2 KG doesn't seem like much given the difference.
KTM 2006 625 SXC
Leo Vince X3 Pipe, Scotts Steering Dampner, Woody's Rear Wheel + Cush Hub, Race Tech Gold Suspension, 18L Tank, Bark busters, Trail Tech SCMR16 HID Helmet Mount, Comfort Seat, Bark Busters, Stealth Sproket, Trail Tech X2, Michelin Desert
Cedo Nulli
BigM is offline   Reply With Quote
Old 02-14-2010, 06:18 PM   #96
AllOrds
AllOrds's Avatar
Oddometer: 1,351
What was the cost of the wheel,and Who did it for you BigM ?
AllOrds is offline   Reply With Quote
Old 02-14-2010, 07:27 PM   #97
ranui rocket
Oddometer: 52
subframe
if you want to beef up subframe just get some rod and take end caps off tubeing ,cut rod to about 18 inches and grind one end down to a point ahd hit in with a hammer.you can get it up past the battery nearly to the tank,then cut off excess rod and silastic end caps back on(50000ks with no problems.cheers
ranui rocket is offline   Reply With Quote
Old 02-14-2010, 08:35 PM   #98
BigM
Hello :-)
Oddometer: 766
About $1050 including shipping etc That was with a 92c exchange rate (though not sure what the magic people at my bank calculated it at.)
From Woody's Wheel Works in Denver - there is a vendor thread for him - very helpful, even got a free t-shirt.
Then locally,
rim lock ~$30
UHD Tube ~$30
Desert was $230 or something like that
So all up, its around about $1500 give or take - 2/3 weeks from order to my door.
Once the CC recovers I am considering similar for front.. but I don't NEED it, unlike the fact I needed a rear.... so home renovations might win that war..
Locally no one could be arsed even providing a quote or returning phone calls.
KTM 2006 625 SXC
Cedo Nulli
Old 02-14-2010, 11:28 PM   #99
Canuck in Oz
you still here
Canuck in Oz's Avatar
Oddometer: 628
Originally Posted by Dirt Doctor
Thought you were getting a 950 SE
Yeah.. well.
Put it this way.. I was waitin' 6 months for Jennifer Hawkins to walk into my local... when I finally realized I had to lower my standards just a bit.
Of course, a 10,000km SE asking $13,000 obo popped up the day after my 625 deal was inked.
Canuck in Oz is offline   Reply With Quote
Old 02-18-2010, 12:35 AM   #100
BigM
Hello :-)
Oddometer: 766
Sprockets
What size sprockets do you run front/rear?
For dirt.
KTM 2006 625 SXC
Cedo Nulli
Old 02-18-2010, 12:43 AM   #101
Bronx OP
Bronx
Bronx's Avatar
Oddometer: 1,448
625 SXC horsepower
Does anyone know what the claimed horsepower output of the 625 is?
The 640 is around 53 horsepower.
Bruce
KTM 950 SE
KTM 625 SXC
http://www.advrider.com/forums/showthread.php?t=596286
http://www.advrider.com/forums/showthread.php?t=561584
If you don't get lost it is not an adventure .
Bronx is offline   Reply With Quote
Old 02-18-2010, 12:50 AM   #102
BigM
Hello :-)
Oddometer: 766
43KW IIRC - I can probably look that up if needed.
Looked it up. 40KW+ which is around the 53-55HP range, the 625 SMC is 24KW, I would assume the 640 was between 24KW and the 40+KW, given non-high flow head, diff carbie and less performance orientated exhaust.
KTM 2006 625 SXC
Cedo Nulli
BigM screwed with this post 02-18-2010 at 01:03 AM
Old 02-18-2010, 01:55 AM   #103
peteandheidi
Oddometer: 395
when i ran my 625 on the dyno i got 53 hp. But it was running very rich
Popped the side panel off the airbox and removed the air filter and an it pulled 57hp
Went down a size on the main jet and it cleaned up the air fuel a bit but was still on the rich side and only gained 1 hp
Sold it before i spent any more time on it.
Ran my stock dr650 on the same dyno today and it only pulled 37hp
peteandheidi is offline   Reply With Quote
Old 02-18-2010, 03:02 AM   #104
Dirt Doctor
Geographicallyembarrassed
Dirt Doctor's Avatar
Oddometer: 1,122
Originally Posted by Canuck in Oz
Yeah.. well.
murphys law
just picked up a 990 adv.............still smiling
2014 KTM 300 EXC
2006 KTM 950 Super Enduro
2002 KTM 640 Adventure
2001 KTM 400 EXC Motard
1989 U1700 Unimog Doka-The ultimate support vehicle
Dirt Doctor is offline   Reply With Quote
Old 02-18-2010, 03:02 AM   #105
Lovebus
Oddometer: 23
Cush drive
I have an new 18 x 2.15 excel rim with a 2nd hand KTM cush drive hub for sale it anybody is interested.Got spokes as well(just a bit ratty)
The down side is its in bits.JTR quote about $100 to build a wheel.
$500 its in the fleamarket. (you pay postage)
PM me if interested
Lovebus is offline   Reply With Quote
Times are GMT -7.   It's 10:49 AM.
