Old 02-05-2010, 08:43 AM   #1
GAS GUY OP
MILE EATER
GAS GUY's Avatar
Oddometer: 3,340
throttlemeister vs. kaoko throttle lock
i am getting ready to install throttle lock on a 2009 gsa and was wondering wich one i should buy.does anyone have experience with both??
GAS GUY is online now   Reply With Quote
Old 02-05-2010, 08:50 AM   #2
kjclark7
kjclark7's Avatar
Oddometer: 1,340
i had a throttlemeister on my honda blackbird for a number of years and my biggest complaint was my hand not being able to grip the smooth surface to engage the lock. i just purchased the kaoko but have not actually used it yet. it just looks like it will be better (easier to engage) plus a ton of guys on here use it and love it. i say go with the kaoko
2009 BMW R1200GS Adventure
2008 Yamaha FZ-6
1983 BMW R100RS
2013 KTM 350 XCF-W
kjclark7 is offline   Reply With Quote
Old 02-05-2010, 08:52 AM   #3
flyrodder
Donny, please.
flyrodder's Avatar
Oddometer: 3,093
I've had a Kaoko for 3 years or so on my 06 and now my 09. Really like it. My Dad has had one on his RT for a while now too.
"It's sorta like a combination of camping in your Grandma's back yard, and a Frat party. " --fifthcircle
flyrodder is online now   Reply With Quote
Old 02-05-2010, 09:00 AM   #4
MeanMoe
one really mean cat
MeanMoe's Avatar
Oddometer: 2,906
I had the same complaint onthe Throttlemeister then I found an ad in Vendors for a slip on wheel that is knurled and that solved the problem. The fix was cheaper than buying a new throttle lock. If buying new, get the Kaoko.
MeanMoe is offline   Reply With Quote
Old 02-05-2010, 09:03 AM   #5
whisperquiet
whisperquiet's Avatar
Location: 62298 in lovely corrupt/bankrupt Southern Illinois
Oddometer: 933
I've got a Throttlemeister on my '07 GSA.....get a Kaoko. The Throttlemeister looks good, but I am not impressed with the operation of it.....a Vista Cruise on my buddy's '08 GSA works even better except for shortening the grip surface.
whisperquiet is online now   Reply With Quote
Old 02-05-2010, 11:50 AM   #6
oldairhd
oldairhd's Avatar
Oddometer: 52
Bob's BMW Wrist Rest
The Wrist Rest from Bob's BMW is another, less expensive alternative. I like mine so far. Installed in minutes on my "new" '05 R12000GS, it seems very high quality, works great.
A Google search will find a very negative report on this product on IBMWR. Not exactly on the Wrist Rest, but on the optional matching left side bar end. To this I would say, "WTF!" Neither OPs opinion of this product nor Bob's BMW customer service in any way matches my own experiences.
However, keeping an open mind, as a precautionary service item I will annually remove and inspect--couple of minutes. Not a bad idea, anyway.
I just want to ride my motorcycle and not be hassled by The Man.
oldairhd is offline   Reply With Quote
Old 02-05-2010, 11:56 AM   #7
TonyA
beta tester
TonyA's Avatar
Oddometer: 1,159
Another friction solution
I had the same complaint on my Throttlemeister, so I added a strip of that high-friction tape material used to add traction on the edges of stair steps. Solved the problem.
"A voyage whose two ends were out of sight - a voyage sufficient in itself."
"Master and Commander", Patrick O'Brian
IBA 31991
TonyA is offline   Reply With Quote
Old 02-05-2010, 12:08 PM   #8
crea58
crea58's Avatar
Oddometer: 82
I have the TM on one bike and the Kaoko on another, the Kaoko is functionally better. I can't seem to get the TM adjusted correctly.
crea58 is offline   Reply With Quote
Old 02-05-2010, 01:01 PM   #9
Das Boot
down periscope
Das Boot's Avatar
Oddometer: 199
I have had the original style Throttlemeister and the new "black milled" Throttlemeister that allows for pinky finger operation. I like mine a lot and do not have any complaints at all.
Das Boot is offline   Reply With Quote
Old 02-05-2010, 01:16 PM   #10
BCC
I know better
BCC's Avatar
Oddometer: 8,319
My bike has the kaoko and wife has the new finish throttlemeister on her r12r. I like the throttlemeister slightly better. I find my hand sometimes resting on top of the kaoko on longer rides.
Living the fullest life means leaving a history of goodness behind you for others to remember.
Cherish the memories------Ken OBSC
BCC is offline   Reply With Quote
Old 02-05-2010, 05:23 PM   #11
GSA GIRL
2010 R1200GS Adv.
GSA GIRL's Avatar
Oddometer: 103
How well does it hold speed when you take you hands off of the bar for a minute or two of rest?
Alicia from The Left Coast.
GSA GIRL is offline   Reply With Quote
Old 02-05-2010, 07:01 PM   #12
nokaoiken
Oddometer: 199
I have the Kaoko also and like it but have no experience with the TM. I know you didn't ask but I tried the paddle wrist rest 1st and didn't like it. It was cheaper but I felt unsafe using it. A couple of times I accidently put too much weight on this when coming to a stop and was going too fast in a hurry.
nokaoiken is offline   Reply With Quote
Old 02-05-2010, 08:39 PM   #13
OkieTom
OkieTom's Avatar
Oddometer: 632
I have the Throttlemeister on my 05 and have zero complaints. Easy to set and release and holds speed well, maybe some people just don't have them adjusted properly ???
"If you have to ask,
You wouldn't understand"
2005 1200GS "The Big Red Pig"
OkieTom is offline   Reply With Quote
Old 02-05-2010, 09:08 PM   #14
gsnova
Oddometer: 11
I have the TM on my 08 GS. good quality and finish. But as others' feedback, you need to improve the control ring friction or you can order the optional milled ring.
gsnova is offline   Reply With Quote
Old 02-05-2010, 09:16 PM   #15
onesaintsfan
BigJohnHart
onesaintsfan's Avatar
Location: McComb MS, where men are men and sheep are nervous
Oddometer: 1,318
Kaoko all the way
Look the throttlemiester is not grooved and with the handguards on the end it is hard to turn them. GO Kaoko
John Hart McComb MS
2003 Ducati 999s "Christine"
2008 BMW R1200GSA Mary Jane
2005 Chaparral 210ssi " Native Sun II "
onesaintsfan is offline   Reply With Quote
Times are GMT -7.   It's 06:44 AM.
