Old 02-05-2010, 02:25 PM   #1
One Less Harley OP
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,752
Tanks to fit an R80 G/S
Every now and then someone post looking for another tank for their G/S. If you know of a production tank to fit a 1980-86 G/S this thread is for you. To start with I'll post a few pictures and any info I know of about ones which fit.
Please feel free to add a picture of any other type of tank which hasn't been listed or shown. Also if I am wrong about years, capacity or colors feel free to point it out to me and I will correct.
Please PM me with and corrections, info or pictures,thanks
G/S (stock tank)
Years-1980-86
Capacity- 5.1gal/19.5L
Material Const-Steel
Colors- Blue,white, red( I believe)
Petcock- left side
Gas cap- screw on, tube for vent
Attachment- rear bail hook, front behind head set
Fitment issues- none
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 02-13-2010 at 04:16 PM
Old 02-05-2010, 02:32 PM   #2
One Less Harley OP
Oddometer: 4,752
R100GS
Years- ??
Capacity- 6.34gal/24l
Material Const- Steel
Color-
Petcock- Left and Right
Gas Cap-Locking and vented
Attachment-rear bail hook, front catch behind headset
Vent and overflow under tank
Rear hook for seat catch on top of tank
Fitment issues- vent lines underneath tank to be routed
extra "T" for fuel line on right carb
Locking cap
Tank venting (Front tube) and overflow(back tube)
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 02-13-2010 at 04:17 PM
Old 02-05-2010, 02:43 PM   #3
One Less Harley OP
Oddometer: 4,752
Aftermarket Tanks
HPN Tank (Acerbis)
Years-NA
Capacity- 11.5 gal/43l
Material Const- Nylon (paintable), Polyethelene("Philipps CL 50",non paintable)
Color- Polyethelene (not paintable)White, black, red, blue, transparent
Nylon (paintable) semitransparent
Gas Cap-lockable or screw on w/vent hose
Attachment- front 2 brackets either side of timing cover on frame
rear-bracket bolts to backbone of frame-
Petcocks-left and right
Fitment Issues-oil cooler on crash bar must be relocated,
Note-carries large amount of fuel low so weight is less of an issue
http://www.touratech-usa.com/shop/sh...318AnTk11D1B9A
http://www.hpn.de/english/english.html
BAP Petcock inner 21 mm rubber gaskets available here (bevelheaven.com)
Lft front mounting bracket
TAG Regolarita
Years-1985???
Capacity- approx same as G/SPD 8.9gal/32l
Material Const- fiberglass, modeled after R80 G/S PD
Color-
Petcock- Left and Right, extra "T" for fuel line on right carb
Gas Cap-??
Attachment-rear ???, front bolts at welded on mounts at frame
Fitment issues- needs mounts at front of frame
http://micapeak.com/bmw/gs/gs_bosi.html
TAG Moto
Years-N/A
Capacity- 14.8gal/56l
Material Const-Carbon Kevlar
Colors-paintable
Petcock- left and right sides
Gas cap- type unknown
Attachment- full body kit w/ tank
Fitment issues- custom body kit
Tesch
no picts available
Years-1985???
Capacity- (12.9gal/49l) and (15.8gal/60l) and (2.9gal/11L)
Material Const- aluminum
Color-
Gas Cap-type?
Attachment-???
Fitment issues- ???
Heinrich
Years-1981-84
Capacity- (10 gal/40l)
Material Const- steel?
Color-primed
Gas Cap-screw type
Attachment-???
Fitment issues- ???
This /5 or newer Heinrich was interesting for two reasons: One, the indent in the tunnel area, and Two, the ID tag on the bottom. This tank was made by Werner Reinschluessel, who took over tank production in 1981from Karl Heinrich.
ID tag on lower left- Werner Reinschluessel (RW on the tag) made these tanks from 1981 to 1984, when he transferred the rights over to Jeckel. Code 208 indicates that this tank is made for R80 G/S, and holds 40 liters. The number 743 is the serial number.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 03-26-2010 at 05:32 PM
Old 02-05-2010, 02:47 PM   #4
One Less Harley OP
Oddometer: 4,752
Factory BMW Tanks
R80 G/S PD
Years- ??
Capacity-8.9gal/32L
Color-white
Gas Cap-screw,tube vent
R80 ST
Years- 1982-84
Capacity- 5.01gal/19l
Color-???
Petcock- Left
Gas Cap-Locking
Fitment Issues-???
R65LS
Years-1981-85
Capacity- 5.8gal
Material- Metal
Color- ???
Petcock- Left
Attachment- Bail hook
Fitment Issues- snug to seat, plus rear of tank 1/2 taller at seat.
R100GSPD
Years- 1987-96
Capacity-9.3gal/35L
Material Const- plastic
Color-wht/red 659, wht/green 677,wht/violet 693,green/black,black
Gas Cap-locking
Fitment issues-none,gap left at front of seat
Note-access compartment at top of tank
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 01-17-2013 at 04:59 PM
Old 02-05-2010, 05:24 PM   #5
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,552
Go ahead and add the R100GSPD tank to the list - it fits nicely.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 02-05-2010, 06:00 PM   #6
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
All R65 tanks from 1979 until 84.5.
Basically that means any twin shock R45 and R65 tanks
fit perfectly on any G/S ST or GS of the airhead variety.
Robert
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 02-06-2010, 09:13 AM   #7
One Less Harley OP
Oddometer: 4,752
I've added some aftermarket tanks, still looking fort a Heinrich and specs, haven't got all the BMW tanks yet, just need to add them.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-06-2010, 11:13 AM   #8
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,997
I sent the Hienrich specs and pix to your email...... might have been the one you don't use often...
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 02-06-2010, 01:12 PM   #9
Airhead Wrangler
Adios Mexico
Oddometer: 6,552
R100GSPD
Years- 1987-96
Capacity-8.9gal/32L
Gas Cap-locking
Attachment-rear bail hook, front catch behind headset??
Fitment issues-none??
Note-tool tray on top of tank
Same fitment issues as steel R100GS tank. It´ll form a gap at the base of the seat. Yes, it attaches via the same ´pocket´in the front of the tank used by all the other BMW tanks and the same bale at the back. That isn´t just a tool ¨tray¨ on top. It extends about 8¨all the way to the bottom of the tank and can fit quite a bit of stuff. Also, the capacity is 9.3 gallons, not the 8.9 listed. The steel R80G/S PD tank is 8.9.
Old 02-13-2010, 03:05 PM   #10
acap650
acap650
acap650's Avatar
Oddometer: 715
R80 mystery tank
Sorry to hijak this thread. I picked this up from an Adv ad for my R80ST.
Pic 1: note shape is like R80ST, not R80G/S, not R65
Pic 2: note filler drain and vapor vent tubes. Also, welded on tabs that have no purpose on an ST or G/S
Pic 3: note ST, R65 style filler but with PITA spring loaded flap like later GS. Also note original color - looks like G/S blue.
Clueless in Pittsburgh
acap650 is offline   Reply With Quote
Old 02-13-2010, 03:36 PM   #11
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
You can use the mono lever tank from the non GS bike( RT RS STANDARD )
IF and only IF you do this to the front mount and get the proper rear bracket and drill two holes in the back of the frame. It's not difficult, I have done it.
Sorry, this picture was deleted when the mods were screwing around with picture posting awhile back. if anyone wants to see the mod, let me know
Robert
www.wirewerkes.com
wirewrkr screwed with this post 02-22-2011 at 12:22 AM
Old 02-13-2010, 04:24 PM   #12
One Less Harley OP
Oddometer: 4,752
[quote=acap650]Sorry to hijak this thread. I picked this up from an Adv ad for my R80ST.
It looks like a later r80 GS basic tank to me, they had the tank which ll\ooked like the G/S tank but a locking cap and being a later model probably the venting (I'm guessing on that).
No you're not hijacking the thread that's what it's here for, getting info on tanks.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-14-2010, 11:16 AM   #13
acap650
acap650
acap650's Avatar
Oddometer: 715
[quote=One Less Harley]
tanks.
Thanks and I thought of that possibility. The R80GS Basic was not imported here and there is still what looks like OEM G/S blue under the repaint. I guess anything is possible.
Old 02-14-2010, 12:58 PM   #14
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
yEAH, I doubt if non-US tanks would have US spec flaps etcetera. Actually, it looks like a California spec tank.
my vote is for an ST tank, given the shape is the same and so is the gas cap.
Robert
www.wirewerkes.com
Old 02-14-2010, 01:00 PM   #15
One Less Harley OP
Oddometer: 4,752
R80GS Basic was not sold in the USA???
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Times are GMT -7.   It's 07:07 PM.
