Old 02-06-2010, 02:44 PM   #1
One Less Harley OP
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,728
R80G/S upside down brake conversion
I had noticed Nathan's (Boxerworks) G/S at the Georgia Mountain Rally last year and asked him about the upside down lever on his bike. He said it was easy to do, take a grinder and match the cam profile to the back side of the ears. So the seed was planted......
Before picture stock setup
Stock brake location
Remove brake cam and make a cardboard tracing of the original
Cut out cardboard and flip it over like so...
Spray paint to get new profile
Here's the profile.
Start cutting w/ and angle grinder and cutoff wheel. Here's the 1st cut. Hopefully before cutting I don't have to tell you to remove the two o-rings...do I??
...And more. Proceed slowly and hold the grinder flat.
Keep grinding till it looks something like this, this still needs a little work
I was probably paranoid about weakening the cam as there wasn't as much material on the back side. See drawing.
So I added metal w/ the MIG welder then smoothed down the welds.
I then smoothed out the cam where the brakes will sit with a 120 grit sanding pad on a pneumatic angle grinder
Then inserted the cam in the final drive, you will have to flip the brake shoes over and relocate the springs to the opposite side.
I did notice that the springs may touch the OUTER edge of the FD seal. If this was on the inside edge I would be concerned. The reason for this is that the back bone of the brake shoes favors one side. A little hard for me to put into words but you'll see what I mean.
Put the wheel on, not necessary to bolt it in place, you will have to adjust the brake arm to get it in the correct location. You'll have to fiddle with the arm to position it correctly. Bolt the wheel on then adjust the brakes. Ride the bike a bit to make sure the arm doesn't need to be moved. Once you get it in the right location mark the lever location on the cam with a center puinch.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 02-06-2010 at 04:03 PM Reason: typos
Old 02-06-2010, 02:53 PM   #2
BubbaZanetti
for a corrector life
BubbaZanetti's Avatar
Oddometer: 13,156
it would have been easier to just flip the transmission upside down.
Originally Posted by OleGrumpy
Real, red blooded Americans hate taxes.
BubbaZanetti is offline   Reply With Quote
Old 02-06-2010, 03:16 PM   #3
One Less Harley OP
Oddometer: 4,728
I really wasn't hard to do, just tinkering a bit.
Flipping the tranny....Now there's a thought...... Humm... with an upside down tranny maybe the reverse light would be easier to replace, hey it wouldn't leak either!!!
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-28-2010, 06:29 PM   #4
One Less Harley OP
Oddometer: 4,728
I've ridden the bike with the upside down lever, what I don't like about it.
The brake gets tighter when pulled off the center stand and weight put on the rear wheel.
also when ridding and putting pressure on the brake pedal, the brakes feel like they are out of round. I'm not sure why this is happening, maybe the cam shape isn't quite right? To me it feels as if the brake shoes are ridding up and down the cam.
A third problem- even though I tried to mimic the profile of the cam, it is not shaped quite right. The off shape keeps the brake from engaging solidly.
So, my conclusion is to remove the cam and return the lever to the stock location.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 01-14-2014 at 07:08 PM
Old 12-11-2013, 12:14 AM   #5
BMW Fanatic
Oddometer: 6
Upside down rear brake cam conversion.
I also wanted to do this. Please put a couple of pics back on so I can see. How did you route the "pull rod" past the shock ? Or did you use a cable ? If you just ground 2 "mirror image" cams onto the back of the existing cams, did you weld up the original cam faces for strength ?
BMW Fanatic is offline   Reply With Quote
Old 01-14-2014, 07:08 PM   #6
One Less Harley OP
Oddometer: 4,728
sorry no longer have the picts. I was unhappy with pulsing while braking and went back to the original setup.
I traced a pattern of the cam and and made a template then flipped the template over on the cam and cut the cam to the new profile. Hope this explains it well enough.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 01-14-2014, 07:44 PM   #7
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,543
It seems that later brake cams are usable for this without any modification, although I've never tried it. The later ones are just flat.
This:
...instead of this:
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 01-15-2014, 07:50 AM   #8
Jim K in PA
Jim K in PA's Avatar
Oddometer: 1,173
Hmmm - I wonder though if you would get proper leverage on the early style shoes with that later cam. I think the profile of the casting on the end of the shoe changed along with the cam profile. If you use the later cam, you probably have to use the later shoes as well. But, it may make for an easier conversion.
I would like to do this lever flip as well on my '79. I have a spare early cam and rod, and was thinking about pressing off the cam and flipping it, rather than re-grinding the profile.
Jim K in PA
1979 BMW R100T - Otto - Returned to the road - 5/12/11
1975 BMW R90S Hack - Olga - Olga's story - adopted 3/22/14
Viktor - Coming to a thread near you - eventually
Jim K in PA is offline   Reply With Quote
Old 01-15-2014, 06:03 PM   #9
Beemerguru
Beemerguru...G/S guy
Beemerguru's Avatar
Oddometer: 991
I've built 3 of them...but did it a little differently..I cut the cam off, reversed it and had it rewelded back together...
Not me but a local machine shop that does all my crazy welding request.
Never had an issue with pulsing and with proper adjustment and good shoes, no issues with binding
Greg Hutchinson
BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club
http://gregsgssite.shutterfly.com/
Beemerguru is offline   Reply With Quote
Old 01-15-2014, 06:53 PM   #10
One Less Harley OP
Oddometer: 4,728
If I remember right I had to swap the shoes around too..for some reason???
I may have to look into doing it that way...
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 01-16-2014, 06:34 AM   #11
greentreephrog
greentreephrog's Avatar
Oddometer: 77
As a matter of interest, are these us conversions being carried out because of some problem being experienced (perhaps in certain conditions), or is it more a matter of it just looks to be a logical modification to improve clearance?
greentreephrog is offline   Reply With Quote
Old 01-16-2014, 12:31 PM   #12
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,298
Looks, & also ground clearance. However most that do this wouldn't ever suffer issues - so it's mostly for looks.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is online now   Reply With Quote
Old 01-16-2014, 01:11 PM   #13
Jim K in PA
Oddometer: 1,173
What Box'a said . . .
Personally, I am doing to to get the cast brake arm up out of harms way. I have laid mine down in some rocks, and if a "simple" relocation can save my bacon when I am on the TAT, I am all for it.
Jim K in PA
Old 01-16-2014, 01:37 PM   #14
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,523
The only problem Ive ever had from crashing HARD on the right side was a bent rod......I swapped a cable for the rod and have had no problems since. Unitl I actually brake the arm, I don't see a reason to flip.
hardwaregrrl is online now   Reply With Quote
Old 01-16-2014, 03:30 PM   #15
Dmaster
Dmaster's Avatar
Oddometer: 257
I only banged off the adjustment nut once, its a bit bend now but I don't care.
Carry a spare one and a nut is way more easy (I don't even have one lol), and if you want to use the original suitcases you can't flip it up. It wil bang into it. (well at least if I flip mine up)
Dmaster is offline   Reply With Quote
Times are GMT -7.   It's 05:10 PM.
