Old 02-07-2010, 05:49 PM   #1
WacoDirtryder OP
WacoDirtryder's Avatar
Oddometer: 304
R100gspd Gearing Question
i have three R100GS a 88 a 95 and a 92 GSPD the 88 an 92 model seem to be geared lower than the 95 model is there any way to find out what the gearing is on these airheads i dont know if its geared different in the rear end or the transmission?
WacoDirtryder is offline   Reply With Quote
Old 02-07-2010, 05:52 PM   #2
TimTowtdi
TimTowtdi's Avatar
Oddometer: 244
There should be ratios stamped on the final drive. Also the speedometer ratios will be different if they match different final drive ratios. The transmissions all came with the same gearing stock. That does not mean someone could not have changed the first or fifth gear ratios in one or more of them at some time.
Tim
TimTowtdi is offline   Reply With Quote
Old 02-08-2010, 07:26 AM   #3
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
If they are all R100GS they should all have a final drive ratio of 34/11 and the same transmission. The GS's may appear faster that GSPD due to their weight difference.
So unless somebody messed around with a short 1st of long 5th in the transmission or added a European R80GS final drive (32/10) ... your bikes have the same power train from engine to rear wheel. I don't know where the final drives are stamped on the paralever.
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Times are GMT -7.   It's 08:32 AM.
