02-09-2010, 09:39 AM
#1 | ||
No Guts No Gravel
Oddometer: 21
F800GS headlight upgrade
Has anyone tried the Osram Rallye 65 watt H7's in their 800gs yet. I was considering an HID kit but was hesitant after doing some research and thought I would try the bulb upgrade first. Standard H7=55W=1400 lumens, Osram Rallye=65W=2100 lumens. On paper it looks like it might be a viable upgrade although I'm aware the high performance bulbs won't last as long as the stockers. Would be worth the cost to me if there is a definite improvement. I live in the heart of Whitetail country.
02-09-2010, 09:54 AM
#2 |
Really, Really Cool
Oddometer: 3,338
What in your research made you hesitant about HID's?
My HID's use only 35 watts and light up the night. |
02-09-2010, 01:37 PM
#3 |
Oddometer: 103
Hid Burns
some lads have been reporting a burning or smoking of the silver surface inside the headlamp with the use of HIDs.
Jay. Just because I stink of petrol, look like shit and still smile doesn't mean I've not been having fun! Soldiers Do It With Their Helmets ON!! |
02-09-2010, 02:12 PM
#4 |
consummate n00b
Oddometer: 96
I put one of these on my 650GS: http://www.kbcarstuff.com/4300k_Moto...it_p/mc-4k.htm 3200 lumens, and no problems so far.
Besides the improved visibility and illumination, I like that there's no filament to break, so it should last longer than a halogen. replicant screwed with this post 02-09-2010 at 02:17 PM |
02-09-2010, 03:59 PM
#5 | |||||
No Guts No Gravel
Oddometer: 21
Read this and thought I would try the bulbs first. This does not apply to HID lamps that are designed for HID. I just can't afford that type of lighting right now. This article is about the conversion kits.
02-09-2010, 06:29 PM
#6 |
Just Stroming along
Oddometer: 1,318
Save your money, just get a V-Strom best lights in the industry out of the box.
02-09-2010, 07:26 PM
#7 | |
No Guts No Gravel
Oddometer: 21
02-09-2010, 11:04 PM
#8 |
b00b
Oddometer: 172
I put a 100W on the high beam side. the only one I could find was a cheapie 'ricer' bulb with a blue tint to the glass, but it has made a significant difference, and the light output is not bluish thankfully.
No issues with heat, but I dont leave my high beam on all the time. LINKY greenthumb screwed with this post 02-09-2010 at 11:10 PM |
02-10-2010, 04:50 AM
#9 |
Oddometer: 3,482
I was thinking that maybe the CAN-bus would shut down the headlight if it was drawing too much current but if you're running a 100W I guess THAT ain't happening ....
Also ... I can see the lawyers now ... and on this one I have to agree.... So... the CANBus system on my client's bike shut down the headlight during a midnight run at 100MPH because it was drawing 74W and that was 10% over spec as this was best option to protect WHAT exactly....?
02-10-2010, 09:16 AM
#10 |
Oddometer: 135
Most HID kits are 35W and are not likely to melt a plastic headlamp housing (on the other hand, those 100W "ultra-white" bulbs will certainly melt a plastic 55W rated housing). I haven't heard of any Buell plastic headlamp housings melting (and they're only about 4-1/2" in diameter) when using these HID kits, and while the noted article above is technically correct about the optics variation when going to a "HID kit", the fact remains that the amount of light produced by the "cheap" HID kit is huge compared to a halogen 55W bulb. Even with "not correct" optics, the amount of light focused out front of the bike is greatly improved with a HID setup. If I can buy an HID bulb kit for $35 vs. $300-$400 for an HID headlamp assembly, sorry, no comparison, I'll pocket the $300 (and I don't even own a KLR.......
02-10-2010, 05:33 PM
#11 | |
Really, Really Cool
Oddometer: 3,338
But,....... they're brighter. Seriously though, I've had..... I mean, umm, a guy I know has had his HID conversion kit for a year with no problems. They don't burn hotter than halogen, in fact I think they put out less heat and use 35 watts. I can see, I mean my friend can see much better and not just directly in front of the bike as stated in the article. Oncoming cars never flash at me. Him. My friend the outlaw HID haver. ![]() . |
02-10-2010, 05:49 PM
#12 |
Oddometer: 2,500
Osram
If someone tries the Osram bulb post back with before and after pics/review if you can.
02-11-2010, 09:00 PM
#13 | |
I need supervision
Oddometer: 1,050
CAN Bus(Controller Area Network) is a communication protocol for the various ECU's to communicate with each other and to share information. The ZFE is the body electric control module that acts as a fuse box. Only the curcuit protection is electronic and resets itself when the overload condition is no longer present, instead of using replacable fuses. It will shut off the light if the aftermarket bulb used is putting the lighting curcuit in a overload condition, thus saving the wiring from overheating and starting the bike on fire. If the end user of a product modifies it in such a way as to compromise its design, not even the slimiest lawyer would have a case. Earl |
01-09-2013, 01:33 PM
#14 | |
UK GSer
Oddometer: 2,361
I used to ride predominantly at night on empty(ish) roads, so had full beams on a lot of the time. A couple of weeks ago, I noticed condensation on the inside of the high beam lense for the first time. Could be the weather we're having here, but I've never had it in winter before, even in snow. This evening I was checking my bike over in prep for a rally and looking at the high beam again, I noticed the reflector (silver surface) inside the head light unit of the main beam appeared to have flaked off in places, showing black plastic behind. It's not that well illuminated in the garage, so I'll take a closer look outside tomorrow, but it looked pretty bad.
I like my bike because I can overtake 4x4s down farm tracks with a week's worth of shopping on the back. |
01-09-2013, 03:35 PM
#15 |
Oddometer: 3,482
Yeah... big problem is that once the reflective coating starts to go ... the problem feeds on its self....
darker = more heat absorbed = hotter = more damage = .....
