Old 02-10-2010, 02:47 PM   #1
jimbee OP
Airhead Intermediate
jimbee's Avatar
Oddometer: 334
R100GS - Replacing Fairing with a Single Headlight
Hello !
There was thread on here with a similar name, but it didn't really address the notion of replacing the fairing and roo bar with a single headlight and different dash/instrument cluster. Anybody have any experience to share....
(a) What was involved?
(2) How much weight was actually shed?
(iii) Any suggestions on a different dash?
(D) How do you deal with no longer having a charge light in the charging system?
(V) DId new blinkers need new relays and flashers?
(6) Did it require other electrical stuff to be hidden elsewhere?
(g) Did you ditch the stock mechanical speedo set up and install a plug at the tranny accordingly?
(8) Any reason not to do it? (Would you recomend it?)
Hmmmm that's about it for right now. Just been daydreaming about this at work for the last week or so and thinking about maybe doing it....
Thank you much! JB
R100GS for going far, FZ1 for going fast, TE250 for getting dirty, and DR650 for when one of the others needs work
jimbee is offline   Reply With Quote
Old 02-10-2010, 04:14 PM   #2
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,066
The pre-1993 (?) R100GS's and R80G/S's ran the configuration you are after....
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 02-10-2010, 04:47 PM   #3
walkingbear
walkingbear's Avatar
Oddometer: 3,604
1995 R100gs
I rigged this R65LS fairing with single headlight to it.
Changed out again into a 89 Tombstone fairing with the small
headlight. Now the bike has been sold and I'm working on another
one.
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 02-10-2010, 05:45 PM   #4
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,704
Gear Box Breather
A zero $ breather replacement can be made from and old or disused speedo cable.
Pull the speedo cable out of the sheath
Cut sheath to required hight to tuck in to where the frame splits the backbone tubes into the rear frame loops.
Install "cable" as per normal but use a solid insead of hollow bolt.
Gearbox will breath but not mist even in extreme circumstances and will not suck water at the first creek crossing.
I replaced the G/S headlight instument nacelle with a polisport trail bike crap headlight thing and saved 1.8kgs. So I guess the G/S unit weights about 5 lbs compared to whatever tons your current set up runs.
The complete nacell including idiot lights is $425.00 AUD I'd expect <$300.00 USD. plus mounting hardware @ around $50.00.
The headlight lense can be sourced from auto supply shop for $8.00 and adapted.$180.00 for the BMW unit.
Edit And a headlight retaining ring & rubber seal @ $95.00AUD unless you can adapt something automotive. end edit
Speedo & tacho are interchangable (?) but only one can be used at a time.
The polisport setup cost me $75.00 installed including new speedo.I built a bracket for the idiot light circut board & ignition switch and mounted it to the handlebar clamps.
The polisport came with indicators that required the bulbs to be replaced with a higher wattage to get the flash frequency right.
The whole unit mounts by rubber straps to the upper fork tubes.
I used an illuminated Sigma bicycle speedometer good to 199.5 kph
It took a bit of fiddling with electrical connections to make it interchangable quickly (30min)
The intention was to have a sacrifical cheap headlight assembly but just like jeans you never fall off when wearing your old ratty pair.
Rucksta screwed with this post 02-10-2010 at 06:46 PM
Rucksta is offline   Reply With Quote
Old 02-10-2010, 06:03 PM   #5
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,478
Tour tech makes a headlight to replace the gs fairing or the headlight on the earlier models. It's very light. It's made to accept the IMO speedo/tach unit. Though you could use a vapor or others.
JT
www.northwoodsairheads.com
www.jefftrappwindsors.com
"Between two explanations, choose the clearest; between two forms,
the most elementary; between two expressions, the shortest."
Between two motorcycles the simplest (DW)
Eugeni d' Ors (1881-1954); Spanish writer.
jtwind is offline   Reply With Quote
Old 02-10-2010, 06:28 PM   #6
squish
Out of the office.
Oddometer: 6,371
Baja Designs sells a decent DOT dirtbike style headlight and winkers
This will cut down a lot on weight.
If I was going this route I'd go full meal deal
And get rid of as much stuff as possible, while making what's left behind as light as possible.
LED blinkers
GPS for speedo
Smaller tach.
High front fender (get a Japanese MX bike aftermarket part less then half the cost of teh BMW or Acerbies stuff.)
On vacation for a spell
squish is offline   Reply With Quote
Old 02-11-2010, 06:26 AM   #7
Infracaninophile
Finding My Way..
Infracaninophile's Avatar
Oddometer: 7,515
LED blinkers
GPS for speedo
Smaller tach.
I wonder if GPS for speedo is legal? I mean, if pulled over for something else will the cop write you up for no speedo?
T.
Infracaninophile is offline   Reply With Quote
Old 02-11-2010, 12:48 PM   #8
squish
Out of the office.
Oddometer: 6,371
T.
Hmmm good question, round here even a bicycle speedo works
IIRC the law says something about and unresettable odometer and that's about and a device to indicate speed.
Old 02-12-2010, 11:35 AM   #9
Mendodave
Road Scholar
Oddometer: 939
Here is mine
I have an R80G/S
I put the headlight from an R80/7 and the instrument cluster from a /6
cluster:
headlight...not a great shot of it..
I don't care about the weight, I want the candlepower!
Mendo
MSF RiderCoach
'81 R80G/S 'Moby'
'82 CT110 "Postie'
Mendodave is offline   Reply With Quote
Old 02-12-2010, 12:13 PM   #10
squish
Out of the office.
Oddometer: 6,371
Some planning, some buying, some wrenching, maybe some swearing...
I don't know the specifics, but I would guess more then 10lbs and less then 30lbs judging from the weight of my bike's stuff when I had it off.
Homemade ABS, it's easy to work and cheap to get.
Charging system will not work with out the light or some sort of resistance.
It's pretty easy to make up some simple idiot lights.
If you use led you will need something to keep them from fast flashing.
Not if you take off most of the electrical stuff that's up there
but you will need to deal with some loose wiring
You lose posepoints, wind protection and stock connections.
Which are often better thought out then aftermarket solutions.
Purist might come knocking on your door with pitchforks and drive shafts...
Old 02-12-2010, 06:07 PM   #11
jimbee OP
jimbee's Avatar
Oddometer: 334
Thank you team.
Mendodave I dig that simple old school look you've got going on - it is what I kinda have in mind.
Originally Posted by Mendodave
Squish - thanks for the specifics. Do you have any pics of the final product?
Ruksta I love your zero $ breather idea!
Good Point SB - maybe not too hard to do with some stock parts out of the ol'bmw catalogue. It would still kinda be stock then.
Old 02-12-2010, 06:44 PM   #12
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
here's a shot of the stock 88 look.
bmwblake is offline   Reply With Quote
Times are GMT -7.   It's 05:27 AM.
