Old 11-23-2012, 06:26 AM   #1216
1ns
1ns's Avatar
Oddometer: 19
Originally Posted by papawhellie View Post
Hi inmates. I entered the world of thumpers yesterday. 82 XT 550 with less than 2 K miles. PO said it had spark but I get none. I would like input here. I ordered the CD rom manual last night from Great Britian and hope to have it next week. If you guys can steer me to some troubleshooting procedures in the meantime that would be great! Maybe someone has a cdi II can borrow or one of the homemade units I saw linked to here I could borrow. I am a longtimer on the YE.com forum and need a helping hand. The obligatory pictures......
You might try without the battery. My XT had regulator problem, but the engine worked fine without battery.
1ns is offline   Reply With Quote
Old 11-23-2012, 02:03 PM   #1217
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,248
Question XT 550 side stand?
Hi, Check the side stand. switch. Un plug it and plug the wires together. ED XT550 FAN!!
BIG ED XT FAN is offline   Reply With Quote
Old 11-24-2012, 01:05 AM   #1218
G600
Oddometer: 461
Hi inmates. I entered the world of thumpers yesterday. 82 XT 550 with less than 2 K miles. PO said it had spark but I get none....
Very nice find.
Have you measured the ignition stator coil and the pickups? You have the ohm values in the manual, and usually (not always) you can spot a faulty coil by simple ohm test.
Big Ed's idea (side stand switch) is a good one, but you can also unplug the black/white wire at the CDI and then check for spark. That way some wiring failures, the kill switch, sidestand switch and ignition switch are taken out of the equation as all engine kill switches turn off the the engine (spark) by shorting the black/white wire to "earth"(black wire).
The lighting system (regulator, battery and all that) have nothing to do with the spark as the XT550 has a separate ignition system. I can not see how the lighting system can mess up the ignition system, but then again weird things happen....
G600 is offline   Reply With Quote
Old 11-25-2012, 02:18 PM   #1219
orforester
Oddometer: 57
I know it is here somewhere, but does anyone have any specs for a luggage rack for 82 XT 550? I was hoping to use the toolbag as well and rack. Put a spare gas tank on the rack.
Thanks, Bob
orforester is offline   Reply With Quote
Old 11-30-2012, 09:14 PM   #1220
papawhellie
Oddometer: 61
Big Ed I know you are the XT man! I was mistaken. The bike does have spark but I am wondering if it is weak. I still don't have the manual. I believe this bike was parked when it quit and not monkeyed with much. Very clean. The carbs were pretty clean. I removed the jets and the bowls without removing the throttle linkage and stuff. Still no hit even with a little huff of starting fluid. Man that plug is hard as crap to get to.
papawhellie is offline   Reply With Quote
Old 11-30-2012, 09:20 PM   #1221
papawhellie
Oddometer: 61
ED is that mixture screw under that brass with the pinhole where the rail connects the carbs together? just noticed it tonight. I am clueless on these carbs. I have fooled with rubber vacuum carbs on my ninja 250 and Kawasaki 440 LTD as well as old 2 stroke mukunis. Who makes these and where is the 411?? Teikei? My ninja developed problems and I would REALLY like to get this jewel thumping. It is warming again in GA. May be sunshine and 70 again before Christmas.
Old 11-30-2012, 09:26 PM   #1222
papawhellie
Oddometer: 61
I could spring for a CDI. Any experience with the model out of Great Britain. It seems to be the value leader at about 160 bucks exchange from the pound. 6 month warranty vs the year on the New Zealand one???????
Old 11-30-2012, 09:37 PM   #1223
BIG ED XT FAN
Oddometer: 1,248
Thumb
I have a guy who is a ex-yamaha tech. He cleans my carbs for me. I ask him on saturday were the mixture screw is. Do you try a new plug? Also, make sure that rubber hose on the bottom of the carbs is not crack.
We had the first snow of the year. Next week we will be back up in the 50s!!
Old 11-30-2012, 10:42 PM   #1224
papawhellie
Oddometer: 61
new plug gappped, rubber hose??
Old 11-30-2012, 10:47 PM   #1225
papawhellie
Oddometer: 61
Thanks, Bob
This guy has a plan Bob. Google is your friend, I had seen this but didn't know where. They must have been badged tenere's in Europe?
http://www.tenere.co.uk/forum/viewtopic.php?f=53&t=807
Old 12-01-2012, 04:04 AM   #1226
Bart
Constant Lurker
Bart's Avatar
Oddometer: 2,962
Just for piece of mind I would start with a new plug and a plug cap. They are cheap and worth replacing. Then if there is still weak spark, it sounds like a cdi.
Good luck and keep us posted on what works.
Originally Posted by Gravity's Dog
"I came to the site for the bikes, and stayed for Jo Momma. I am constantly amazed, revolted, and in love with the ideas I see here. An extreme reflection of the human experience."
Bart is offline   Reply With Quote
Old 12-01-2012, 08:56 AM   #1227
papawhellie
Oddometer: 61
Got a good link on a quality cap that will work. That is something I have never purchased. I order from these folks pretty regularly or I can pop on ebay if the price is right.
http://www.powersportsplus.com/parts...TOR/parts.html
http://www.rockymountainatvmc.com/
Old 12-01-2012, 02:14 PM   #1228
Bart
Constant Lurker
Bart's Avatar
Oddometer: 2,962
Virtually any NGK cap that is of the same shape should work. Any good bike shop should have a selection.
Old 12-02-2012, 11:48 AM   #1229
yamalama
wet coaster
yamalama's Avatar
Oddometer: 1,243
you do a compression test?
check valves?
Chances are reasonably slim that it is the cdi, considering you have spark.
yamalama is offline   Reply With Quote
Old 12-02-2012, 12:56 PM   #1230
Bart
Constant Lurker
Bart's Avatar
Oddometer: 2,962
check valves?
You don't know XT CDI s then.
No offense. All of mine that are bad had spark. It was weak or sometimes acted like it was out of time. I pray it is something else simple though. Compression should be an obvious when you kick her over but a good thought to check.
Times are GMT -7.   It's 03:07 AM.
