Old 02-17-2010, 09:57 PM   #1
Dustodust OP
Dustodust's Avatar
Oddometer: 986
stick welding thin guage ?
What is the best method for welding thin guage steel with a stick welder ( besides getting a mig wire welder )
can it be done ?
does anybody have a trick for it ?
the smallest I can do well is 1/8" with the smallest rod I have found 3/38 7018
is there smaller stick somewhere ?
no matter what if it strikes it will blow through even turned way down
from a cloud of dust we race, then into the dust we return, across the finish line
04 KTM 950 S
04 KTM 525 EXC street plated
Old 02-17-2010, 10:15 PM   #2
P B G
Oddometer: 10,001
Thin metal is a challenge with a stick welder, one way to do this is with what's called a carbon arch attachment, the only guy I know who uses one is oldschool, its basically a holder which has two carbon rods. These rods then form an arc which is used to add filler material. This is very similar to using a torch, which a number of old timers types weld sheet metal with a torch and filler.
Mig of course would be good, but you already know that.
Old 02-18-2010, 12:34 AM   #3
Dustodust OP
Dustodust's Avatar
Oddometer: 986
never heard of that carbon arc deal
I was hoping maybe someone invented a magic rod that i haven't heard of
I tried puddling by backing into it too but that seems weaker than brazing
gee I guess thats why the fencing people like those MIGs for welding up that thin wall tubing
04 KTM 950 S
Old 02-18-2010, 12:54 AM   #4
Skippii
Hookers, my lad.
Skippii's Avatar
Oddometer: 6,505
I was doing this two days ago.
I got some 7014 (by far my favourite low-penatration rod) in 1/16".
I turned my 115v welder down to 35 amps.
Within a few minutes I'd blasted several large holes through the pipe on which I was working. But I suck at welding. Just about anyone will do better than I.
Anyway, these are the rods, and they still seemed to work better than anything else.
http://www.harborfreight.com/cpi/cta...emnumber=96813
"Umm be careful what you say, this is Skippii....
You may get it delivered in the form of a shake or some interperative dance routine that involves nakedness, pizza and a stuffed raccoon..." -DCrider
Skippii is offline   Reply With Quote
Old 02-18-2010, 04:07 AM   #5
Bruce Caldwell
Bruce Caldwell's Avatar
Oddometer: 1,016
Try using 3/32" 6010 or 6011 & run down hill. If you have room you can use a copper backing plate also.
late-braker
Guaranteed not to cause eternal torment in the place where the guy with the horns & pointed stick conducts his business...Frank Zappa
Bruce Caldwell is offline   Reply With Quote
Old 02-18-2010, 04:21 AM   #6
cagiva549
whats a cagiva
Oddometer: 2,454
Just gas weld it , if you have a welder your bound to have a torch and bottles sitting around . Thats how it was done before all the electric processes were invented . Dont use coat hangers , they are trash . go to the welding supply and get real steel rods or coated brass and brase , with just a little practice you can weld like a pro . The thinner the metal the smaller the welding tip . SEYA
David H
00 Cagiva GC
04 9 fiddy
05 ST3 duck
07 KTM 450 EXC
86 Goldwing my geezer ride
cagiva549 is offline   Reply With Quote
Old 02-18-2010, 06:44 AM   #7
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,313
I've had a Lincoln 225 since Nixon was in the White House, and have put more holes in sheet metal I was trying to weld than anyone, so I am qualified to answer this question.
My father was always sending me cracked lawnmower decks and handles to weld. As others have said, 35amp setting (or 40, the Lincoln's lowest setting) and thin 1/16" rod (no bigger) and do everything you can to clean the material where you are welding and the where you are attaching your ground. Also touch up your ground clamp a bit with a couple of shots with a fine file. Cut the rod in half (full length rods are a bitch to strike an arc with), shine up the rod before you put it in the electrode holder. (Anything that reduces electrical resistance helps a lot when you're using low amp settings). Striking an arc by the "scratching a match" method helps. Be careful to keep the rod close to the work to keep from blowing holes through the work. (Listen for the wonderful "frying bacon" sound, not the horrible "VOOOOOF" electric blowing sound). The rod will probably stick. Just be ready for it, release the rod from the electrode holder quickly, use your pliers to free the rod, clean the ends, and go again.
I've been tempted to get one of the Eastwood "stitch welder" attachments:
http://www.eastwood.com/email/defaul...RCCODE=1CJBAN8
but they are $80 (!) now (they used to be more tempting @ $50). $80 is a fair ways toward a low-price wire/MIG welder, which is SO much easier to use, making it easier to make a good weld. The only downside of the MIG I noticed is that it makes more of a mess (spatter and fogging) around the weld than the stick does.
Eastwood sells 3lbs of 1/16" rod for $20 here:
http://www.eastwood.com/welding-rod-...&parent_id=553
What are you trying to weld?
HapHazard is online now   Reply With Quote
Old 02-18-2010, 06:54 AM   #8
cheesewhiz
cheesewhiz's Avatar
Oddometer: 124
Beat me to it!
I welded 16 gauge cold rolled (Metal door frames) for two years with 6011. It's a "feel" thing but with practice can be done!
Good luck.
you're never really lost if you don't care where you are...
'12 Super Tenere / '03 KLR
cheesewhiz is offline   Reply With Quote
Old 02-18-2010, 07:30 AM   #9
Cliff-77
Lost Adventurer
Cliff-77's Avatar
Oddometer: 1,067
Welding
I've done it with 6013"s don't penetrate like others,lowest setting,it's an art,takes awhile to get good or ok,I have welded exhaust pipes for yrs.torch&coat hangers best.Patience&determination,you can do it.
Cliff-77 is offline   Reply With Quote
Old 02-18-2010, 07:45 AM   #10
Zecatfish
XTique Rider
Zecatfish's Avatar
Oddometer: 7,927
+1 on the gas welding.
Google Earth GPS Howto (still a work in progress) use USGS TOPO Maps to layout trails.
http://home.windstream.net/catfish/GPS
The Early Bird gets the worm, but the second mouse gets the cheese.
https://sites.google.com/site/ozarkadventuretours/
Zecatfish is offline   Reply With Quote
Old 02-18-2010, 08:12 AM   #11
P B G
Oddometer: 10,001
Agreed, but many people buy a stick welder because they don't need to screw around with gas bottles and lease on tanks, hydrotesting etc.
Here's a picture of what "carbon arc brazing" and such are.
The arch between the electrodes produces heat essentially equivalent to a torch for brazing.
Its a usable way to use a stick welder on thin gauge metals. The one pictured is not equivalent to a commercial product, but I used to see these things in miller/lincoln catalogs. So I assume someone is still selling.
Old 02-18-2010, 01:06 PM   #12
Dustodust OP
Dustodust's Avatar
Oddometer: 986
Thanks for these tips ALL
i wasnt aware of the 6010 and cleaning the grounds for less resistance
I do have a torch setup , so i'll look for some rod at the local welding supply but all they seem to have is the common industrial stock stuff
I suppose since all welding is basically melting the metal together, gas welding should be as good as arc ...IF the impurities can be left out of the weld joint.
for the amount and type of welding I will typically do, I cant see buying a MIG and if i did I would want a 220 rig with a full size bottle and large $pool
04 KTM 950 S
Old 02-18-2010, 01:27 PM   #13
bobivey
Oddometer: 39
I would suggest 6013 1/16 diameter as it is a fast freezing shallow penetrating electrode. Try this at 40 amps and "push" the arc ahead of the puddle. You can also try reversing the polarity which will but less heat into the work. Good luck.
bobivey is offline   Reply With Quote
Old 02-18-2010, 05:00 PM   #14
C Squared
Now with TURBO!
C Squared's Avatar
Oddometer: 7,221
Yea, what they said 6013 would be my choice as you want easy and penetration will happen anyhow. VERY clean ground points etc. As close to the weld area as possible and clamped to the weld material not just touching.
I "flash" when I do this type of weld. "Flash" the electrode ahead of the joint and bring back to puddle continue.... Less concentrated heat.
Stitch weld and let cool and come back.....Preheated metal burns through faster. Practice til you get the feel.
Good luck.
I can explain it to you, but, I can't understand it for you.
C Squared is offline   Reply With Quote
Old 02-18-2010, 08:42 PM   #15
Iwantabikesobad
Iwantabikesobad's Avatar
Oddometer: 1,080
try this
A friend of mine arc welds and uses another rod at the same time just like brazing. He uses the second rod to take the arc and lets the puddle run down onto the metal below. Its a timing thing that takes lots of practice but works as the filler rod can be much thicker than the intended welded metal.
Good safe riding to all.
Yes it's my Bike, No I wont help ya move!
Proud member of Father & Daughter riding club
09 KTM Adv. The Orange ones are faster!
Iwantabikesobad is offline   Reply With Quote
Times are GMT -7.   It's 02:38 PM.
